I will be starting from scratch on sourcing an Xflow dizzy. Lucas and Bosch seem to be most common. And one might think between the two, the Prince of Darkness would get the pass, but then maybe not. I now have to take Dizzy 101 and see what the Formula Ford and Escort boys are using. Im already setting rocker gaps I might as well set points gaps too. I will have a E-bomb proof car for sure.
Steve, sage dizzy advice that will gi into my dizzy notes. But looking for the context here...🤔 Are you saying that I need to go back to points & vac with this carb? My current dizzy is an Aldon setup for DCOE 40s and A2 cam, no vac. A detail I hadn't noticed till now, the manifold the carb was attached to, for a Cortina GT/E, doesn't have a vacuum nipple, or an obvious port on the carb. 🧐
Please share you findings!
420 CSR progress, Purple People Eater ;) 😈
IamScotticus replied to UglyFast's topic in Build Threads
I don't know if it would ever happen, but were I in this situation I would be wondering if a moving of operations from Kent to an Asian location would be happening. And hoping my car got out before the exodus. If I were an executive at VT holdings, that would be the plan. -
New Caterham model- The "Super Seven 2000"
IamScotticus replied to Mark IV's topic in General Sevens Discussion
Is this ths first SV to be offered with clams as standard? -
Its soooo..... Wait for it........ P u r r r r p l e -
I get cost. For me, protection from a pouring is well worth $300. Im thinking that something that does the same job, or can be fashioned into, can be made much cheaper. The cheapest thing I know is painters drop sheeting for coverage of floors. If I could find the right adhesive, I could easily fab up a perfectly fitted cover. Materials costs would be under $10.
@papak who's nose is that? Does it fit a Cat?
Rule #1: I am cheap. Rule #2: You are cheap. Now that's out of the way, how can I make a thin, stowable, plastic rain cover that I can draw taught enough to not allow water to pool? And cheap enough to dispose of without too great a loss? Typical S3 size box is 12x5x4
I would use them for long term storage with wheels off. Or a long body project. But not for wrenching on. I would have all 4 stands connected.
If you read Jake Lamont's book, How To Build And Maintain (yet legal) Formula Ford Ford 1600 Engines, [available from Pegasus Racing] Jake's first advice on the preparation of these carbs as found on page 75: "The first order of business is to remove all of the choke plates and actuating mechanism and toss them in the trash." I realize this advice is for race car prep, but could it apply to me as well? Hmmmm🤔
The carb was purchased on Fleabay. All the screw heads are perfect. I don't see any signs of previous work. I don't see any visual evidence of shaft bearings or bushings. There aren't any on the diagram. This 32/32 is a late 60s carb that lasted until the introduction of the 32/36 progressive which has shaft retaining bushes on both throttle shafts that bush the shafts in the housing. I think they are plastic.
At home recovering from Sinuplasty and turbinate reduction. Believe me, any surgery to the nose sucks. but the roto-rooting was successful and it will all be good. During thd lucid moments, breaks in the pain fog, I managed to start tearing down the carb. So, I have a question to put to the gallery.... How far should I tear this down? Shall I leave the throttle and choke plates on the shafts? I ask because I could clean around them and I wouldn't have to worry about the screws coming out later. I believe this carb is untouched. Special thanks to Carburetor Shop for an excellent parts diagram.
I have read a few times that many prefer the aeros over the "airbrake". I have a set that came with my car but they came off first thing. they were attached directly to the scuttle, which was very "used" by a previous racer owner. I was going for pretty and the classic look so new scuttle and full wind screen and the wipers went on. I can tell you the full scren buffetting is punishing if your ears happen to be in the turbulence. Therefore side screens and ear protection for me. I would prefer this to a rock or shard to the face any day. Personal vehicle dash cam:
Series 2 Pre-Cross Flow Distributor and Ignition Timing
IamScotticus replied to Henry VII's topic in General Tech
Fuel pressure regulation... The electric pumps are the usual suspects for over pressuring. I am going back to the mechanical Ford as well. It delivers 3psi consistently regardless of engine speed. Either way, both kinds can fail and the mechanical can leak fuel into the oil. Yes, either way get a fuel regulator set to 3 psi and a way to test pressure with a gage. hey, Formula Ford uses mechanicals on the Kents. -
no, we don't ask. We bring extra clutch cables and spark plugs with us. -
Most likely had an axle upgrade. maybe a Quaife LSD too. Lucky you. $20k car -
Um, yes. That engine is coming out for a refresh. If you don't get the lower oil seals done, the oil will get to the clutch. Good time to do the main bearings as well and check crank balance and flywheel runout. Send me a PM and I will mail you an extra copy of a Dave Bean catalog. I great source fir parts and technical is Burton Power in the UK. A good source of info is Classic Ford magazine. A lot of good archived info. See if your car happens to be listed on simplesevens.org -
Welcome to the forum. Hope to see pics of '62. Left hand drive? You're asking fir a lot of stuff that needs a tuners touch. Idle issues could be many different things. Its a goose chase to tell you to look here, then there, etc. Just be reslistic that what you change now, may not be the fix. One of the best ways to get to know your 7 is to know the various cars it has parts from. For your engine, buy a service manual for the car that used your engine. Probably a Mk1 Cortina or Anglia, not sure about it. My limited expertise, if you call it that, is if you hace DCOEs, you need a dizzy with electronic advance. Caterham had put the Aldon on the Xflows. There are others like Petronics. You will want one programmed for your ignition curve and cam. But for idle, you have to check fuel pressure, carbs for float level and leaks, check spark plug wires. Don't be so quick to blame the timing. Pics! and buy this book https://www.amazon.com/Lotus-Seven-Preparation-Restoration-Maintenance/dp/185532153X -
Good suggestions all. looks like the flange diameters on these is a secret. The 5 hole has been a standard for a while.
The 90s Cat VDOs are 6 bolt with a 2.25" bolt circle and a 2.125"/80mm flange dia. Edit: doesn't compute..correction coming I measured my tank depth at 8.25" deep.
