IamScotticus
  1. wow...
  2. The engine out. do it.
  3. 1. make score marks on the flanges so you put the shaft back on in the same orientation. 2. The differential flange bolts are not usually high torque items, so removing and assembly isn't difficult. Drive shafts are usually simple items. Now is a good opportunity to take it to a drive shft shop and have the balance checked, any repairs done and grease toped off.
  4. I know we're all joking around here, but Id like to add.. The Skyline wasn't seized because it was a Skyline, But because it wasn't on the manifest "Smuggle". The issues with the car can be resolved one way or another, but falsification can't be dealt with kindly. Customs is mostly focused on drugs , IPR violations and terrorism now. They don't care what it is as long as everyone is truthful about it and its clean.
  5. can you rotate the shaft to look for zerks? they can be very hidden in a u joint. Is there grease slung in the tunnel around the joints? Your joint looks clean, like sealed bearing, but I don't know if sealed would have circlips. I have a loose shaft (not really) and it looks a lot like yours (I hope not) Flip it over and there is a grease zerk
  6. I know the "nobody wrenches on my car but me" thing, lol. Those Vaccaro wings, or farings, were they sold as such or are these your own creation?
  7. This is golden advice.
  8. Standard Caterham key. This one is my Xflow key. No ECU. STARTER SWITCH Morris Minor Lowe & Fletcher SWH116X Nieman type BHA5215
  9. It's a distributor; a component of non-computer controlled engines. Im just being cute. Ignore me. But if you wanted to put in an all mechanically timed engine, the Kent crossflow is still a viable engine with lots of parts support and 55 years of tuning knowledge available.
  10. No PATS required Yes, im trolling ☠️
  11. This is your niche! Get the market!
  12. @Alex-Ks1 OK, so where's the 7 kit from you? lol
  13. I would treat it like consulting an attorney before a starting a business selling roadkill meat pies, what could go wrong? Call a broker or a friend who knows the business and ask if you need a broker. If your import passses thrthe port and Customs swimmingly, great. If not, the time and storage fees can add up. I do know that Customs doesn't care about your storage fees and they may not answer to you at all.
  14. Maybe in ten years EV components from complete cars will be cheap and available to cobble something together?
  15. You definitely want a Customs Broker working for you. Not because you can't do it yourself, but because of the investment you have in this. The brokers know the importation language and are in regular communication with the inport specialists.
  16. After attending few courses on throttle steer from YouTubiversity Im considering stepping down my sway bar from the 5/8(red bushes) it is now to a 1/2. Anyone want to swap out? I have the 90s uprated live axle suspension with balls on the bar.
  17. Ship could still be moving but its signal delayed
  18. I don't have a Zetec so I can't suggest an exact location. But Ive had a oil catch can/oil separator on my personal vehicle. These things can be condensation traps because they house or circulate hot air while a flow of cool air surrounds the can creating condensate in the can. I removed it when it was collecting more water than oil. Therefore I would try to avoid placing it in a direct air flow area like the frontal area. Further back like foot well mounted perhaps. Hope this helps.
  19. For someone who has the chops to knock out a full car, thsts a fantastic experience and achievement. I believe a structurally superior chassis is much better than a 60-70 year old rust gamble. Steel is steel, no matter what name it has on it. For a guy without the skill sets to build, saving 5k/year for four years and buying a complete 7 is better for him. It may take four years to save the money, but a DIY project will likely drag on for ten. Then life often has other plans. Get into a driving 7 car as fast as possible and start enjoying driving a seven.
  20. On the spaghetti models, I think the purple line is most likely.
  21. @Alex-Ks1 Are you for a front mounted motor? mated to a transmission?
  22. Thats probably a good thing
  23. I think it's already here
