Everything posted by BruceBe
Tom - this current product is designed to work with the newer gauges and calibrated for the later fuel sender assemblies. We are considering a version of the product that will work with the older gauges and tank/senders. We have a car in the shop right now with the older setup, and will be gathering the necessary sender level data. Cheers, -Bruce
For 2016+ Caterham fuel gauges, we have a tool-less, plug-in corrective module that provides a much more accurate reading. Most importantly, it reduces range anxiety due to the stock setup reporting prematurely low remaining fuel levels. Just plug it in between the gauge and the harness. Caterham Fuel Level Correction Module Cheers, -Bruce
Actually, with the roller barrel intake, much of the grime you see accumulating is due to intake reversion - un-burnt hydrocarbons accumulating. For vehicles with a bit of mileage, the only comprehensive way to get all the grime out is to remove/disassemble/clean the rollers. Otherwise, the grime that accumulates between the valve and bore gets wiped back onto the valve surface. Cheers, -Bruce
Tracsport T9 Semi Helical Gearskit Options
BruceBe replied to PJJackson's topic in General Sevens Discussion
It’s also possible that the powertrain is moving slightly under the reverse loading of decel, and you’re getting some other vibratory noise related to components contacting each other (tunnel, exhaust, etc). And if it’s more pronounced at a certain rpm, something might be resonating as well. Cheers, -Bruce -
We have these particular T9s in several race cars competing in our Caterham spec-series (CC4) in the Pacific Northwest. Everyone’s ears are tuned differently, but no one has reported that sort of asymmetric noise pattern on the over-run. I’ve personally driven each of the vehicles in anger on track as well without noticing anything. The previous comment about the diff is worth consideration. These gearboxes have proven bulletproof over several seasons of very hard racing with, at times, some abusive gear changes. We run Redline MTL. cheers, -Bruce -
Rear uprated ("race") brake upgrade finally done
BruceBe replied to KnifeySpoony's topic in General Tech
That’s a bunch of brake hose in that install. Is the entire rear circuit now hose? Brake component wear is very much a function of the circuits you drive, and more importantly, the driver’s approach to the braking event. This kit allows you to decelerate faster, earlier in the brake event, rather than waiting for the weight transfer to the front of the car in the “pedal squeezing” phase. And because the rear is doing more work early in the brake event, before the front is doing much, overall braking distances are shorter. To maximize the benefit of this kit, you’ll need to change the way you brake a bit, becoming a bit more aggressive early in the brake event, and remembering to modulate out a little as the weight transfer takes place. Cheers, -Bruce -
Just finished my 420r build have ride height question
BruceBe replied to notoriousjje's topic in General Sevens Discussion
To eliminate tire/wheel sizing variables, we use an angular measurement/reference at the front LCA, and then also set rake based on an angular reference ( by adjusting the rear). This usually works out to be nominally close to CCs published numbers, but not with all tire/wheel combinations. Deviation from that is a performance compromise, but that’s ok as well in a mixed-use car. Generally, raising the platform will increase toe in the front and reduce camber. So, if you make a big change to ride-height, those settings should also be re-checked. And as John pointed out - vehicle should be loaded with driver weight, half tank of fuel, and tires at desired hot pressures. Cheers, -Bruce -
We have three CSRs in the shop right now. They have been quietly offered here in the USA almost continuously, and are a model in which we specialize. -Bruce
David, Your ordered Sigma upper radiator hose was OOS at the factory for quite some time. It finally came back into stock in the UK, and is in a consolidated parts shipment that was caught-up in Customs last week. As many know, parts availability for non-current models unfortunately tends to fade quite quickly at the factory. We did miss a single email from you on 7/25 - sorry about that. Thanks to Croc/JohnCh/CatManDo for jumping in while my back was turned. -Bruce
Nice pose with your legs up in the air :-) Generally, you should be able to reach behind the gauge, loosen the lock ring (backing it entirely off the gauge, and pull the gauge forward. This allows you to install the module on the front side of the dash. Then, simply push the gauge back in, align the face, and thread/tighten the lock-ring back down by hand (no pliers/tools please). -Bruce
This device has been installed in vehicles for a while now (two local cars; one in MI). The goal was a DIY install, and the packaging needed to be developed. There is just too much variation in dash harness layout, and physical difficulty in the car, to build something that required crimping and significant mechanical manipulation of wiring under-dash. Just unplug the connector at the back of the gauge, and plug it into the module. Then plug the pigtail of the module back into the gauge. It doesn't get any simpler than this, unless the gauge matched the sender in the first place :-) @CBuff - order received, thanks. -Bruce
Caterham CSR Rear Lower Damper Bracket Upgrade now available
BruceBe replied to BruceBe's topic in General Sevens Discussion
Hello everyone, We now have our second production run (16-sets) of these corrective upgrade CSR rear lower damper brackets in-stock and available HERE. -Bruce -
The Naturally Aspirated Caterham Seven Is Dead
BruceBe replied to CBuff's topic in General Sevens Discussion
The 485s are a bit "special", so there is a particular supplier issue that would require a hefty engineering effort to overcome. -
Hello everyone, Beachman Racing is pleased to announce the release of an upgraded rear lower damper bracket for the Caterham CSR. We have developed the new part over the last 10-months, and the brackets have been installed on both street and track cars for several months. We embarked on the project, due to perceived issues associated with the original Multimatic/Titan part, brought to our attention by CSR owners. Incrementally improving the Caterham product is not new to us, and this upgraded damper bracket falls right in line with our engineering foundation. The upgraded bracket assembly offers the following benefits: Use of 6061-T6 Aluminum for the bracket body, which eliminates the potential for stress corrosion cracking (SCC) associated with the original alloy (2014-T6) 30% increase in relative strength, by thickening critical loading areas and completely revising the bushing system associated with the damper mounting Corrosion resistance by design - in addition to utilizing 6061-T6 and anodizing the bracket body, all bushings/spacers are made of Al-Ni-Bronze, and all parts are coated with a non-hardening aerospace corrosion inhibitor. All new hardware is zinc coated. Exclusive upper pin design - we completely re-engineered the mount for the upper wishbone, utilizing a 140Ksi shouldered bolt. This captured bolt avoids both the use of a custom-machined pin, as well as a fastening system that relies on aluminum threads. We had a soft release of 10-sets for our initial production run, and the next run of 16-sets is underway. For a more detailed description of the product, the installation instructions can be found HERE. The introductory sections describe the CSR rear suspension architecture, and go into more detail with respect to the benefits of the upgrade. One can also get a sense of the install. Many thanks to the owners who placed their trust in us while we developed this product. Croc gets the credit for first bringing this to our attention :-) Vroom, vroom! -Bruce
- 1 reply
- 2
Oh don't you worry, there will be more surprises But, we'll get through them. -Bruce
John - glad we've got it here and delivered in one piece. The Roulette Green is a winner. -Bruce
BruceBe replied to slngsht's topic in General Sevens Discussion
Larry - thanks so much for the kind words. If I correctly recollect, that CSR could be the last factory *260* imported into the USA. Croc is right - it became possible to order the CSR chassis once again, but only equipped from the factory with the 210HP 2.0L. So, I guess you're both right. Take the winter to eat well, exercise/rest, and reconsider the self-imposed ultimatums. Of course, if I can be of any help, please do not hesitate to reach out. Cheers, -Bruce -
Thanks to all with experience on this in CA. Clearly, Caterham Sevens are delivered as kits, and have an assembly manual. Tom - you might be on to something with the pre-built Hillbank approach. I've always winced a bit, when they put together demonstrators like that. Cheers, -Bruce
Quick Show of Hands - Caterham 6-speed
Thanks guys. Not a lot of 6-speeds running around. Cheers, -Bruce -
How many folks are currently running the Caterham close-ratio 6-speed, or would be interested in a Caterham 6-speed if it were available? We're currently evaluating our investment level, in supporting this gearbox moving forward. This is the Type-9 derivative, not the newer Mazda-based gearbox (5-speed). Cheers, -Bruce
New USA7s Instagram and Facebook accounts
BruceBe replied to JohnCh's topic in General Sevens Discussion
Sounds like a good idea for extending reach and awareness. It's also encouraging that the approach and guidelines for the use of those two additional outlets still retains a center of mass here on the forum. IMO - that part is important. Cheers, -Bruce -
Caterham doesn't make any of its parts
BruceBe replied to Vovchandr's topic in General Sevens Discussion
Mark 2 Golf. -Bruce -
Well, there are a bunch more pins on the CSR tach. In the end, power, ground, and a tach signal make a tach a tach. What year is the chassis? Armed with two sets of schematics, and pins/shells from Caerbont, one could probably get most, if not all chassis side features working on the new tach. Cheers, -Bruce
VW produced a lot of cars over the years. -
We have both of these tachs (58055 and 71261) on the shelf. I'm a bit surprised that the 71261 you have is 2-coil, but, there are clearly multiple generations of these tachs. To be specific, we have the 58055A, which is the current CSR tach listed on the UK website. You can always reach us at info@beachmanracing.com Cheers, -Bruce
