blubarisax
Everything posted by blubarisax
  1. Sounds like we will have a good Se7en showing!
  2. Gas situation all squared away. I'll see you guys there. Ron, are you out there? You should join us. Karl
  3. I should make it, just need to figure out how to bring along some extra race gas!
  4. My car is similar and tips the scales at 1270 with a full tank and windscreen, but no weather gear or spare tire.
  5. I should have known it sounded too good to be true... I have driven at MMC and enjoyed the track. It was a fairly quiet day and I felt like I had it all to myself.
  6. I spoke to them and they sounded very serious and confident they will finally be getting the project off the ground. They expect construction to take a year. No cash is being taken until construction begins...
  7. Sounds like a great day at the track. I'm jealous!!!
  8. Does anyone have inside information on this project? The track configuration sounds fun and it is not as expensive as some "private club" style tracks. It is only 75 miles away from NYC and plans on being run like a HPDE event. Karl http://alpinesignature.com/
  9. Mike, All the mods look great! How do you like the aero screen? Do you wear a helmet when driving around Jersey City? (maybe not such a bad idea) Karl
  10. Great detective work Mike. My brake reservoir setup looks exactly like your original configuration. Guess I better replace it ASAP. What kind of hose did you use? Bob, yes, the hoses are not under any pressure. Karl
  11. I'm at Lime Rock on Saturday, but Sunday would work for me. I want to see Croc's secret weapons!
  12. Mike, are you using synthetic fluid? I had no problems before I switched. Karl
  13. Sunday sounds good to me! I'll be at Lime Rock that Saturday with SCDA.
  14. Sounds like Wilwood line is good. Wonder if they have any spiffy carbon fiber lines?
  15. Mine sweat too when the humidity is very high, I suspect we have the same setup. Only noticed it a couple of times when it was near 100% humidity. I have changed brake fluid several times this summer (uprated rear brakes/bias valve/Pagid pads/race master cylinder) and have not noticed any black flakes. As long as you have fluid in the reservoir and the fluid is not contaminated it should be safe, right? I'm sure you have thoroughly researched the best hoses...please share your thoughts.
  16. I miss Ben...
  17. I replaced the ACES ubit in my car wirh the Shift--i and like it a lot.
  18. Mike, did you know that you can get ceramic brake rotors with loads of carbon fiber in them? (Thake that!) The CF duel is on... Perhaps I'll re-skin my car in CF to keep up with the Crockmobile http://www.carbon-bits.com/
  19. They work good for me too. The mirrors taks some fiddling to get the tension adjusted properly though.
  20. I've got the standard Caterham exaust. To get the car to pass the 88 db limit at Lime Rock, I put in a modified Dynatech Vortex Insert Cone (inserted just after the collector and before the muffler) and that did the trick. While power seems just the same, I do miss the louder sound on the track. It makes me think I'm going faster!!!
  21. Yes, they are located in Germany. I got the one inch weave and the light weight wingstays. They look great with the 5" CF headlights. So far I have resisted CF rear wings, although both Mike and Ron have them...
  22. Check out Mog-Racing.com. I got a sent of 8" front wings and they are great. Not sure if they would give you a package price or not, but you may be able to save a little. Karl
  23. The back saver is more like a gooey memory foam than anything else. I need the extra room in the seats and this foam brought me a little further out.
  24. My dear wife made me back and seat pads using Backsaver foam from Pegasus. She covered them in Alcantera to match the seats, it made a world of difference. Karl
  25. I already thought about... one has to have limits though...
