speedwagon
Everything posted by speedwagon
  1. I have a car on a Rotus chassis it is sound, easy to work on and room for a ls v8 if wanted. This car has non-standard drive train but should be able to get parts, has patina but at 6k would make an excellent entry car for a slim budget.
  2. And just one more thing--Small frontal area--- means BIG fan the biggest that will fit and big wire to run the fan. With a fan relay near to the fan with direct wire (large #10 or larger) with both an auto on(by temp) and a switch (on the ignition circuit so you don't forget and leave the fan on manual after parking running the battery down. john
  3. some how missed this thread earlier. There are only 54 of us with Focus engines but the heat problem is far worse with a rotary in #22. (a quick side while I still remember -- it runs in my mind that the rear end is from a Ford sierra, whatever that is. mine has a 8 bolt cut down camero) The wiring is the worst thing about these cars, fuse box is a source of eternal problems and all the wires are under sized and run willi-nilly with little or no protection. replace the fuse box and rewire the whole car paying special attention to the fuel and ignition circuits. Since mine had a bovine experience that gave me the opportunity to consider scrapping the nose cone I have tried several options. First tried a 93 rx-7 radiator with a rx-7 oil cooler high behind it and separating the air flow so that they both got clean air. Present configuration (not tested as yet) is similar using an 4 core aftermarket aluminum radiator from a 70s rx-7 that will require just a couple of slight bumps in the nose. Same oil cooler but with an auxiliary oil to water cooler to pre-cool the oil. the inter-cooler will be mounted high and back and receive air "cowl induction". Have not started rebuilding the nose as yet, but have decided to dis pence with the bars and perhaps sharpen the edges to increase frontal opening. Am also considering a "skid pan" just back to the oil pan trying to create a vacuum of sorts under the car. Sorry for rambling but once started just kept going. good luck to all BTW everyone should consider a tank mounted fuel pump for better cooling and longer life. john
  4. my Superformance resided in Ticaboo and there are some real nice although higher speed (and more dangerous) took it from bullhead to boulder on the burr trail once (bit rough and dusty) now in lower desert. john
  5. I use "point replacements" in my VW engines and always carry a spare set of points. Have found that the Pertronixs units are no better than the other Chineeze ones.
  6. Am going to make a few guesses, There are a vast number of thermister manufactures and very few are likely to be in good ole USA. The quality will vary all over the place. Automotive gauges being made to sell, the accuracy is going to be below the desires of most of us. And the buyer will usually not be discerning enough to know whither his gauge is off by 10% at 200 and most certainly not notice a much greater inaccuracy at 100. What I use to check my gauges is a digital infrared thermometer. (mine happens to be a harbor fright from chairman mao's junk store) Point the dot at the sender and get a readout. to check it's accuracy point it boiling water on the stove and correct for elevation to calibrate. The tool is also very good for checking exhaust pipe temperature differences. You can see an almost instant change when the fan turns on and a low performing or lean cylinder shows up readily. So will a poor electrical connection if it is conducting current and there is voltage drop. Cheap tool for what use you get out of it, originally bought my first one years ago for about 500 when doing electrical/mechanical troubleshooting. john
  7. Move to Arizona. Titled my newly acquired (Fake) Lola bodied Rotus last Monday. Took 15 minutes. Had a Texas title with make "ASVE". He asked what it was, showed him a photo and said "kit car". He asked what it might be cost and I told him what I'd paid. He gave me a title for a 1995 ASVE and collected $35 including a 2 year registration. Love it here and besides it is sort of warm. john
  8. AH the generous ending!!!
  9. Leaving Tuesday am for Houston to bring home the Lola MK1 clone. couldn't resist and likely will get it going as is before restructuring it to turbocharged with an rtech stand alone. Have a warehouse of turbo rotary parts. john
  10. My 2 cents, as a superformance owner, I say get a quote from this man with a history of support. during this rebuild I will likely remove the superformance label to prevent embarrassment. car is ok-- needs much sorting and some redesign (and a fab shop for replacement parts)
  11. Thanks for the very informative thread even with the engineering wewe contest. In Hilbiliese the discription is; brakes are grip times leverage with the elements of consistency and control being more important. This discussion helps pave the way there. john
  12. Am near Golden Valley, 18 mi from Bullhead with Superformance S1 #22. And warm.
  13. It is a dune buggy, pure and simple, with a high amount of polar inertia to effect the handling. As for the dak-dak being short on beans-- My meyers fiberglass clone has a 2010 with a vnt25 turbo that is quite competitive
  14. Rick; I live near Golden Valley, AZ. Am about 90 miles from LV 4 miles off hwy 93. the car is a Superformance S1 which is a little more generous with space than most 7s. It is up on a dolly getting an engine transplant and not running but we could easily vacuum out the interior for a seating. john 970-640-4804
  15. I like the color. The brakes on some S1s are a bit hard, the fix is to get one size smaller master cyl for the front and move the present front to the back. Have not done mine yet as it has been getting a heart transplant for two years now. But also to consider would be a different brake pad compound from Wilwood as even a soft pad won't ever wear out. Also on mine the balance bar was out of adjustment. john
  16. love the welding cart-- they all really need the storage drawers and none have them. thanks, john
  17. Being the not so proud owner of an XJ8, the last thing I would want is a SUV made by TATa. the ford English model is just too "needy" to take out of easy reach of a tow truck. Just cannot imagine that things got better with new ownership.
  18. Restrorider you are on the right track, electrics are the biggest problem with the s1, rest is mostly quality parts some from unknown sources, windshield being the worst.
  19. my s1 is raised up with 15" rims and higher street profile tires. Will clear a 5" rock but no more. Has a rear so tight it might as well be a spool, and has been on snow, ice, sand, mud and dirt. It is as good as it gets hydroplaning , and has been over the Burr Trail (75mi) in southern Utah at speed, is great fun on gravel sweeps and esses but not necessarily fast as some. Still handles better than almost all on the road. Life is a compromise.
  20. Did not mean to infer that the Superformance S1 is a poor handling car. it is though quite comfortable on long trips. I no longer race but can attest that the car handles quite well and is more adjustable than most to suit your style. but as a run of 50 it is more expensive to maintain due to lack of replacement parts and support. Mine has rotory turboed power with a gm 8 bolt rear and is even more so. But had I built a "track T" roadster that handled as well with full top and heat good enough to drive in a blizzard the maintenance could well be worse. The car will be with me when i croak. john
  21. The superformance would be a deal as a road car, but you must be or know a good fabricator if you own one. Also $ quite similar to my xj8 sport in that respect.
  22. Tranquillo! tranquillo, I was attracted here and continue to return, I do not actually belong even though owning a sort of seven and being well over 70. I have driven over 700 miles in a day in it and it would be my favorite road car (although if the xj8 jag could be trusted it would slip ahead for comfort). Some of us here know far more, have more funding, are more fanatic, are more attached to the original brand, and may even be a little more proud, but all contribute and should be accepted for what they are-- just as imperfect as the rest of us. Sorry just had to speak.
  23. Agree with BusaNostra. 58lbs core weight without flywheel bell housing and accessory drive. That and a tbo of 500 hrs makes the Mazda rotary that's in mine look good. It is a directed toward the aviation market. Rotaries are not for the faint of heart but do produce a lot of power for weight and size/shape.
  24. have taken a poll and Jon Stewart won the debate the other night while absent.
  25. Have a question. How does the intercooler location work out? I have a Superformance S1 that is getting upgraded to a fresh T-ll street ported 13B and have considered a "close to cowl" location as the frontal area is used up with oil and water cooling and the more rear location would be much neater. Had cooling problems with old na engine with the original S1 radiator and oil cooler but it was tired. Now have a fb alm radiator and a fc oil cooler with a beehive in reserve for added oil cooling if needed. It is not easy being different. thanks, John
