speedwagon
Everything posted by speedwagon
  1. just picked up a Hofmann dual lift vs-300 for $400. it is a free standing symmetrical lift, 5000#, screw lift, made in Germany. gives me a small one as a companion to the Rotary. it is 3 phase and after I inspect it will add a start/run capacitor since it will never see the rated load.
  2. the tps is a variable resistor and sensitive to heat and almost always made by the cheapest bidder. In this case i would just change it, as it happened without you changing anything. john
  3. That is not too much power, as there are more than 2 positions to the footfeed. I would change the clutch, and for now renew all the rubber while the engine is out for reliability. Keep the fuel injection in your area as it is far better suited to the altitude changes. Drive it and then decide what YOU want. A de-tune on the turbo should be easy and as I stated, the foot pedal is your best waste-gate. It is a very pretty car and someone has spent much time and money on it.
  4. having muscled around a sprint / supermodifien in the 50s and with a 36 ford street rod with much modified suspension. I am not a bit bashful to say that my superformance 7 fills my desire to have a track T roadster. Respect others choices, they may be better. Remember Jim Hall schooling the elate in group 7 with a chevy v8 and powerglide of all choices. My hero of all time is smokey Unik.
  5. looks like you have all the answers to the which hoist? question. And I do love your redneck rotisserie. hope you don't mind me stealing your idea? john ( as I will)
  6. I live in the rural az desert. SO. I employ all of the above, plus. none of the electronic seem to work, have found the moth balls that come in a ventilated plastic bag to be best in engine compartments. But they do not bother the wiring in my 66 Ranchero that doesn't have any wire made with soy. Redneck mouse traps work well outside and in the shop as does Hawk all weather bait chunx, that I screw to a piece of plywood. This spring I had made up about 30 of these and had them in a box on the floor for later use, left the door open and the next day all the poison was striped from all the plywood pieces. (really slowed down the rodent problem). I have about 1/2 square mile to patrol all by myself. All the small trees that I plant get killed by the rabbits if not fenced, (planted 2 oleander bushes and didn't think to fence them and next day all that was left was 2 stumps) but no more rabbits that year. I was hoping that they would grow up and provide feed for the cowboy welfare's cows. the main problem is the wires and spark plug wires are the most tasty (my elderly backhoe has no problem, nor does the little kubota diesel. But I do love it here amongst the damn republicans. john
  7. The glass "was" custom made for the s-1. but the present superformance no longer supports the s-1 {orphaned} so it is unobtainable. But I met a glass guy in salt lake who said he could make glass to fit anything. unfortunately no longer have his contact. But the day is coming. john
  8. Having had so many and varied jobs ( 13 w2s in one year and worked for some more than once), at 80 I cannot write a full resume of skills. But I will second the last suggestion by "Pokey". When I joined the Navy at 17 they tested us all and put us where they had a need. for me it was electronics technician (so different from my thoughts that I had to look up what it meant). I was not happy with that, but excelled and stayed in the troubleshooter category for my whole life (mostly physics related though quite general and encompassing in nature). But to sum it- learn what the strengths of your nature are, and look there keeping in mind that one naturally likes what they are good at. So consider making it a hobby related decision. and above all --be an opportunist!
  9. BTW to previous post-- I also carry a rx7 doughnut aluminum wheel and tire from the 4 bolt rx-7 as a spare. is light and looks decent and fits the superformance s-1 pattern.
  10. I use a scissor jack from a RX-7 fc 86-90 it is aluminum and weighs little, is strong enough and should be easy to find. And the handle is also aluminum. john
  11. I am 80. And was looking for my last auto. Looked at a porch macan and liked it, but the reliability was horrible. So next- electric and came to the conclusion that only a hybrid with a 50 mile range before the engine was needed and home solar charging capability would work for touring the country without hassles. So found a 94 ford conversion van with the 5.0 and 80k on the clock. room- about 20mpg with good tune- decent handling with good shocks,tires,and sway bars. residual life longer than a new porch or many other new cars for that matter. my house is nearly "green", I can afford the gas, and the electric option is not viable, nor will it be in my life time of driving. My 7 , glass buggy with a turbo 2010 VW and a 66 Ranchero with a 408 Windsor provide the excitement. Am a techie, but simple is more likely to save you from walking. And when the unavoidable war with china= no chips/no drive- in addition to the short usable lifespan that we now have. If in my life span there is a viable made in USA electric car there will be one in my garage. john "part of aging is narrowing of the mind".
  12. Presently have a Meyers Manx clone with a 2010 VNT turbo-ed (250+hp) air cooled vw, 14" wide dirt tires on back. Will go most anywhere, runs at freeway speeds, has heater, and does well in a long gravel curve power drifting. It is easy to find a place to stress my ability (within my property). it and the Superformance S1 will be here when I croak. Also have a smooth bodied rotus chassis and a sorta "lightning" clone is coming together. and many more unnecessary vehicles appropriate for a 80 yr old.
  13. lways wanted to build a track T roadster for the street. this would have fit the bill, but bought the superformance s-1 and the itch was scratch with a solid gold scratch-er. The urge is well satisfied. john
  14. I remember using these solid state delay off timers. years ago. googled a search for then and they are still available, and cheap. https://www.google.com/search?q=delay+off+timer+12v&ie=utf-8&oe=utf-8&client=firefox-b-1 remember using the mars brand and you can set the time you want. Worst case you would need 2 NO WAIT they might just turn off after each blink. but it is worth investigating. john
  15. sent you a pm-- I live in golden valley about 20 miles away from you, john
  16. have 2 rotary powered 7ish cars ( superformance s1, and a rotus chassised like a Lola mk1) both are mix fuel (dirty) one is carburetor (pain in rear) 1 na and 1 turbo-ed. both have an ideal torque curve for a light car. rotaries are becoming old school and not for everyone. But, I have seen pictures of a Rotus with a gm ls aluminum block in it. Would buy except for overabundance of toys and years (not left). john
  17. a word to the wise-- "wide-band" (air fuel meter) and if you wish to keep your engine, in the dash preferable. When leaned out at high power an engine will resort to burning aluminum. and quickly. At 14,000 feet, in the sprint to the finish, I lost 3 pistons in a Corvair engine with 30lbs on the manifold. It happened in less than a mile. Drove it down the hill, and when torn down the rings were still intact but you could see into the crankcase where half the pistons used to be. Besides a wide-band will make tuning easy even with a carburetor engine. john
  18. Is the sensor actually in the coolant? or in a well? You should not be able to wiggle the sensor installed directly in the coolant without it leaking. If it is in a well then perhaps wiggling it would cause contact with the well to effect the reading. And if your dash is not sufficiently grounded and using the capillary as a secondary ground there could be some contact hear that could effect the reading. All will be clear on this perplexing problem when the solution is found. john
  19. On my superformance s1, I replaced the tie rod boots with shock boots that were bought at NAPA. somewhere there is the part number. remember it being vw and the cost to buy new was at the time about $40 ea for something that rotted out in about 5 years. since the s1 was made in south Africa too and possibly by the same people or at least known to them. Any how the original part #on the boot traced back to some vw product. Since the new superformance does not support the s1 they are not forthcoming with source info. will try to look for the folder today. john
  20. Color is important-- but-- not that much. My road color (darker grey/blue) xj jag has the most close encounters followed by the medium dark 7. The problem is US, even those of us who have experience with motorcycles in traffic. We do not naturally notice smaller objects, we are programed to notice what is easy. I have read that our view is like a computer screen and sometimes is not refreshed unless we do something to refresh it. Be aware, drive as if you are in a large Mexican city and being stalked by bandits. (or the insurance fraud sters) It will improve your driving and lessen the risk of some cotten head like me looking right at you and then pulling out. We is the problem. john
  21. have a pair of 15" rag tires from the early 60s on the back of my fiberglass dune buggy, they get to 85mph regular, non English speakers not so well. wouldn't trust a current offshore tire when new. But it would be interesting to see unbiased data as there are about 4 yr old coopers on my xj8.
  22. Even if you fed the valve through the intake the rotor would have busted the valve up into little pieces and spit it out. fake photo.
  23. John to John What are you running for or from? and are you sure the voters deserve either of us? And as usual Croc gets the last word in first. I do have an affiliation, but it is yet to come. Yes this is the most considerate place on the internet.
  24. I have a rotus chassis with a sort-of 60 lola mk1 body clone. And a superformance to compare. Rotus rides entirely too hard for me (but may be that it has Carrillo coil-overs rather than the original- too much spring?. The chassis is of comparable workmanship and uses stock toyota bushings in the suspension. Also both were of a 50 or total run and I would expect design changes for both during the run. And, even I cannot build the perfect car the first time and doubt that the complainer or even Chapman could. john
  25. back in the 50s USAC did not allow exposed roll over protection, just what was under the head rest. My first drag car was a flat head ford frame with just a wheel and a bar stool wired to it, no radiator (hoses out of the to to the bottom. times have changed.
