MichaelD Posted November 22, 2015 Posted November 22, 2015 Does anyone have experience using the Motive Power Bleeder on their Caterham? 1. What master cylinder do you have? 2. Which unit do you use? 3. Did you bleed 1,2,3 or 4 at one time? 4. In the end is this cheaper that letting the shop do it? Thanks for your feedback.
Sean Posted November 22, 2015 Posted November 22, 2015 Does anyone have experience using the Motive Power Bleeder on their Caterham? 1. What master cylinder do you have? 2. Which unit do you use? 3. Did you bleed 1,2,3 or 4 at one time? 4. In the end is this cheaper that letting the shop do it? Thanks for your feedback. I use a SpeediBleed model, the K400 as found here. The cap provided screwed right on the Caterham MC on my car. I like this one because it hooks up to a tire, and you dial up the pressure required on the gauge - about 5 psi was all it took. It makes the whole process very easy. Even I could do it! Worked on brake and clutch MCs. I bled one at a time. It still didn't take long. Unsure what a shop would charge, but this is one of those jobs I would have feared doing by myself before, but find it really easy now.
MichaelD Posted November 22, 2015 Author Posted November 22, 2015 Thanks. That look much easier to maintain pressure while bleeding one at a time and flushing the MC. Does your car have the Girling MC?
bsimon Posted November 22, 2015 Posted November 22, 2015 (edited) Gunson's Ez-Bleed for me. A little awkward in that you need a sacrificial spare tyre to power the rig, but effective nonetheless. I found the key to good fluid changes is changing colors. I regularly switched between ATE Super Blue and ATE 200 (same stuff, just two different colours). ATE can no longer sell blue fluid in the U.S. since it was discovered by DOT to be ... blue. (It took them 20 years to discover this.) All brake fluid in the U.S. Must be Amber or clear. There are dyes available now for "off road use" that can be had to colour the fluid of your choice. Edited November 22, 2015 by bsimon
Sean Posted November 22, 2015 Posted November 22, 2015 Michael - Yes, kind of. I have the Girling MC for the clutch (5/8") and the AP Racing MC for the brakes. Bob - The SpeediBleed is functionally identical to the Gunson, except that it has a valve with a gauge in-line, so when you remove the tire to get to the brake disc, you hook it up to that tire, regardless of the inflation pressure, and just dial in whatever pressure you need to push the fluid through the lines; too little pressure is less problematic than too much! Care to ask how I know?
bsimon Posted November 22, 2015 Posted November 22, 2015 too little pressure is less problematic than too much! Care to ask how I know? Unintended paint solvent blow? The gauge and hand pump would be a nice addition. I've seen a nice bleed system made from a small garden sprayer on instructables or some such website.
MichaelD Posted November 22, 2015 Author Posted November 22, 2015 Is there a dye sold in the US that works well?
bsimon Posted November 23, 2015 Posted November 23, 2015 The dye I saw was on Jegs, summit, or some such hot rod site. I can't seem to find it again. I may have seen UV dye used for tracing leaks and thought it was something else. UV might work, but turning off the lights and using a black light adds a lot of labor to the task. Looks like the color change trick is no longer valid. I guess I'll have to flush by volume from here on out.
fastg Posted November 23, 2015 Posted November 23, 2015 (edited) I just use the easy bleeder from Harbor Freight. I think I got it on sale for $19 used it on many cars and motorcycles, http://www.harborfreight.com/brake-fluid-bleeder-92924.html Graham Edited November 23, 2015 by fastg fix spelling
jlumba81 Posted November 24, 2015 Posted November 24, 2015 (edited) I just do something similar to . Found the kit I use. Just empty it after each wheel and rinse with water after each use. Edited November 24, 2015 by jlumba81
scannon Posted November 24, 2015 Posted November 24, 2015 I've tried a number of power and vacuum bleeders over the years with not a lot of luck. I prefer the two person method and there is one trick I use that gives a really solid brake pedal. Once you are comfortable that clean fluid is flowing and all the air is out, do one more pump and bleed before moving on to the next brake, but this time close the bleeder valve while the fluid is still flowing, i.e. before the pedal gets to the floor. This prevents air from being sucked in through the bleeder valve's threads when the pedal hits the floor.
slomove Posted November 24, 2015 Posted November 24, 2015 (edited) I used the speed bleeder check valve nipples for a while and they are easy enough to use when pumping with the pedal. But they are even better with a mity-vac style pump on the nipple. Just pull vacuum, open the nipple until it starts bleeding and watch that the reservoir does not drain fully (in that case I close the nipple and refill the reservoir before continuing). I don't worry about fluid color changes but keep bleeding until I refilled the reservoir 2 or 3 times plus another time for the other side caliper. Takes less than 10 minutes for all 4 corners. Edited November 24, 2015 by slomove
Slonie Posted June 1 Posted June 1 I was debating over what model of bleeder to get (if any) and I do have at least two data points. One, they make a 1.75" adapter for Girling MCs which would appear to be the appropriate one for our* cars. (previous discussion here). *your car may vary, Two, the common "European" adaptor for Motive also appears to thread onto this Girling MC just fine — my friend lent me his and we threaded it on, pumped it to 9-10 psi, and left it for 5 minutes with no loss of pressure. So I think I'm going to give it a try. Notably though, my friend also didn't add brake fluid to his bleeder as is suggested, preferring instead to remove it periodically to add fluid to the MC reservoir. The upside is not having to clean it afterwards (as well as, maybe, making less of a terrible mess if the seal was broken while pressurized. In any case, I'll report back when I actually use the bleeder, which will hopefully be really soon.
chrisp993 Posted June 3 Posted June 3 (edited) Just used my Motive bleeder with the European adapter to fill the system on my new build. Previous cars I have followed your friends path of leaving my Motive "dry" and relying on the fluid in the reservoir but this time, since I was filling a dry system, I filled the reservoir and put the balance of 2 quarts of fluid in the Motive tank. Straightforward and much less hassle. The only downside of putting fluid in the Motiv tank is some waste fluid (so, say $5) and cleanup, which was completed (after disconnecting!) by draining the excess and pouring in some alcohol / water mix then using the Motive pump to flush that through the tubes, then letting everything air dry in the sun 👍 Edited June 3 by chrisp993 1
CarlB Posted June 3 Posted June 3 I have had a Motive bleeder for a long time and used both ways described above. It has always worked for me. Some proportioning valves are difficult to bleed if you do not put them on the highest setting. The Motive brake bleeder will not work on late model cars with ABS is you get air in the ABS system.
savagete2860 Posted June 4 Posted June 4 I also use a Motive bleeder on my 420R and my Lotus Elise many times before that. Its pretty darn easy and works great. I agree doing it wet does waste fluid, thats my only complaint.
