JeffersonRaley Posted April 12, 2023 Share Posted April 12, 2023 FedEx just delivered this new motor from Raceline. 2.5L Duratec. It made 297bhp @7400rpm on the dyno when they tested it. Can't wait to get it in my Birkin. 1 1 Link to comment Share on other sites More sharing options...
Bartman Posted April 12, 2023 Share Posted April 12, 2023 Wow, that will be a handful of fun. Good luck with the install and setup. Link to comment Share on other sites More sharing options...
JohnCh Posted April 12, 2023 Share Posted April 12, 2023 Wow is right! Do you have dyno curve you can post? Did they use an exhaust manifold dimensioned similarly to yours when they did the test? Thanks, John Link to comment Share on other sites More sharing options...
JeffersonRaley Posted April 12, 2023 Author Share Posted April 12, 2023 33 minutes ago, JohnCh said: Wow is right! Do you have dyno curve you can post? Did they use an exhaust manifold dimensioned similarly to yours when they did the test? Thanks, John Here is the curve. I'm running a 1.75" diameter header from Tom Carlin. It's a gorgeous header! They used a similar header and ITBs, but not exactly what I have. So I might be a little higher or lower in power. Of course, it'll gain a little as it breaks in too. Link to comment Share on other sites More sharing options...
Vovchandr Posted April 12, 2023 Share Posted April 12, 2023 16 minutes ago, JeffersonRaley said: Here is the curve. I'm running a 1.75" diameter header from Tom Carlin. It's a gorgeous header! They used a similar header and ITBs, but not exactly what I have. So I might be a little higher or lower in power. Of course, it'll gain a little as it breaks in too. Link to comment Share on other sites More sharing options...
JohnCh Posted April 12, 2023 Share Posted April 12, 2023 That looks like a fun curve! Are you running a 4-1 header? If so, what is the size of the exhaust? Did you have to go to 3" for those power levels, or are you at 2.75"? Thanks, John Link to comment Share on other sites More sharing options...
JeffersonRaley Posted April 12, 2023 Author Share Posted April 12, 2023 Here is a pic of the header I got from Tom Carlin. 2 Link to comment Share on other sites More sharing options...
Bartman Posted April 12, 2023 Share Posted April 12, 2023 A Stainless work of art that is. Link to comment Share on other sites More sharing options...
7Westfield Posted April 12, 2023 Share Posted April 12, 2023 HO LEE CHIT Link to comment Share on other sites More sharing options...
windsurfer Posted April 13, 2023 Share Posted April 13, 2023 I guess he was pretty happy not to have to create a gap for the steering collum to got through. Very nice torque and hp curve btw! Link to comment Share on other sites More sharing options...
NeoBear Posted April 18, 2023 Share Posted April 18, 2023 You know I have the same motor except one of my Pullys is in a different location. I told Tom I wanted the 2.5 a dry sump and left the rest up to him when I bilt the car. I haven't put mine on a dyno but I wouldn't have thought they are making anywhere near that without FI. Pretty awesome buddy! Link to comment Share on other sites More sharing options...
papak Posted April 19, 2023 Share Posted April 19, 2023 (edited) Did Tom weld up the header himself? Great job! I have an earlier iteration and I still haven't decided if that three-piece header flange is a blessing or a curse. Motor envy!! Edited April 19, 2023 by papak Link to comment Share on other sites More sharing options...
NeoBear Posted April 19, 2023 Share Posted April 19, 2023 13 hours ago, papak said: Did Tom weld up the header himself? Great job! I have an earlier iteration and I still haven't decided if that three-piece header flange is a blessing or a curse. Motor envy!! I can tell you trying to get everything lined up on the 3 piece was pretty miserable, there is an order you want to do it in. The rest of it was pretty simple though, only had to make a slight modification to the resonator cover/guard. Link to comment Share on other sites More sharing options...
oilteq Posted April 19, 2023 Share Posted April 19, 2023 Wow! That will be fun. What size tube comes out of the header, and what are you doing for an exhaust pipe? I have what Dick Brink called a big tube header on my 2.0 Duratec. The ID coming out of the header is 2 3/8', but it was going into the original Birkin exhaust pipe with a 2" ID. I bought a muffler, some stainless tubing, had a flange made, and found a guy that could weld stainless. Now it is 2 3/8" from the collector to the tail piece. Link to comment Share on other sites More sharing options...
