Friday I picked up a Caterham with the Ford SVT motor from a local autocrosser in New Mexico. I have been interested in Sevens since I first rode, and eventually drove one in 2020.
I have a few questions I could use help figuring out, and forgive me if my search-foo has failed me:
1) How can I tell if this is an imperial or a metric chassis? It is registered as a 2007 Caterham SV, but the VIN indicates a 2006 code. I don't know how to tell the difference between brazed and tig welds. I was told it was metric, but found a spare set of blinker covers with paperwork indicating it's possibly imperial.
2) What is the correct way to check the oil level on the raceline sump? The dipstick in the engine is too short (seems broken), but the PO included another OEM dipstick that he used to check the level. The part number is 978M6750DA and seems to be an OEM Ford Focus dipstick that crosschecks to an SVT motor too. Using said dipstick the oil level is at the max mark.
3) The reason for my dipstick question is that after driving today I noticed the oil pressure hovering right above the red mark at hot idle, which should be around 1.2 or 1.4 bar if the scale is linear (17-20psi). Pressure climbs to 4 or 5 bar by 3k RPM. Is this normal oil pressure for this engine and this wet sump? It's about the same as my Miata at hot idle if the gauge is correct, but want to verify.
4) Any information on how to access the ECU and adjust the calibration is highly welcomed. HP Tuners says on their website that the SVT is supported, but when I tried to read the PCM with my MPVI4 it did not work. Scanning/Datalogging reads the ECU as a Ford unit, but wasn't as useful as others I've worked with.
I need to address some maintenance items right away (timing belt, valve cover gasket, and radiator) then I want to track and autocross with it a few times this year. Very excited to have a Seven and join the community!
  • Like 3
8 minutes ago, Vovchandr said:
Congrats!
Can you post a picture with the hood off?
Nice cat-ception.
Thanks! Here you go
Your oil pressure is fine I believe.... altho I'm not familiar with your motor.  That tic mark is 2 bar so you are showing 1.5bar or 21.7 psi. if I'm eyeballing the gauge right.  My older Vauxhall does the same....right there full hot idle and 4 bar plus at 3k.  That is also a wet sump.
Not sure about your dipstick issue but if you are not getting a red eye oil light warning you should have enough in the sump especially if you were fine cornering at speed.
Your Cat looks nice and congrats.
Thanks for confirming the pressure is within reason :classic_biggrin:. Yep, it is about halfway between red and 2 bar. Oil is Mobil 1 5w-30, ~4.5 qts based on notes from PO I just went through.
And here is a picture comparing the length of both dipsticks. Yellow handle is the one that shows full. Oil isn’t registering in the shorter one.
Congratulations on your new purchase!
A 2006 should be a metric chassis.  If you PM me the VIN then I can decode it for you and confirm the year, etc.    But from looking at that engine bay it looks like my past 2004 and 2005 SV's with the SVT engine.
I expect it will be a Ford Oak ECU unit.  ECU usually is in roof of passenger footwell.  Quite sophisticated for their time.  However, I assume you put your OBDII reader on it and could not get a reading?  I used to be able to get a reading off my cars albeit with a bunch of fault codes (missing fuel tank, evap emissions, etc).  They are tunable and open access - no password needed.   Just need a tuner who can do it or the software that will allow you to adjust the settings.
I appreciate the info, Croc! Sent you a PM with the VIN.
The ECU seems to be an Oak unit as you described. I did connect to the OBD port with HPTuners’ VCM Scanner and read the fault codes you mentioned (EVAP code etc.), no faults related to the engine. What I mean to say is that I couldn’t run a datalog, although I didn’t try with the engine running, only ignition on-engine off. The VCM Editor, the tuning side of the software, was not able to read the firmware or OS though. Do you know which software I could use for tuning on my own?
I wouldn't trust the dipstick unless the previous owner confirmed it's accurate. Raceline's installation instructions for the Zetec wet sump state to scribe the dipstick after the initial oil fill of 5L. However, because not all oil is drained during an oil change, adding 5L now will be too much. On my old Duratec with their wet sump (also 5L upon initial oil fill), a refill was about 4.5L when the oil was drained via the sump plug, and about 4.75L when siphoned out via the dipstick tube. Unless someone has the specifics for the Zetec, it's probably worth a call to Raceline to get their recommendation.
As Croc said, CONGRATULATIONS on your purchase!  It is a great looking car and has been well kept!
Very minor point here, but it must be a 2006 as the 2007s came with the "50th Anniversary" badge on the nose.
Taber
I usually change fluids, always the oil, when getting a used vehicle to have a start point for maint.
I'd drain the oil from a hot motor and measure the amount....it should be, as you note, about 4.5.  I'd refill with the same amount then measure/mark the long dipstick for a reference point.  This if you cannot source an original one.
No I dont sorry but I bet a dive into Focus forums will surface what they use for tuning.
Great points, thanks for that. I will follow up with him and ask how he arrived at his conclusion, but it seems it is somewhere in the ballpark of accurate.
Taber
Thank you! It is well kept, and the battle scars it wears make me feel at ease when I track it :D
Thanks for the reminder. I should check the transmission and diff fluid. I plan to change from Mobil 1 to Valvoline VR1 or Amsoil and when that change happens I'll measure how much comes out and go from there.
No problem. I've been reading on Focus Fanatics that SCT is the current software available when used with an older dongle, but at this time I don't want to invest in a new tuning suite. I'll give it some time and see how the engine runs the next couple of months before making a choice.
On the ECU - it is a Ford EEC-V. Application is 2002-2003 Ford Focus SVT. As Croc said - for the time, it was quite sophisticated (MAF sensor; ECU-controlled fuel pressure).
The Raceline sumps for that application are famous for breaking dipsticks right at the upper oil range window (upper hole). The yellow stick should be accurate.
Congratulations!
Cheers,
-Bruce
