williamwashere Posted 3 hours ago Posted 3 hours ago I got my car delivered about a month ago, but unfortunately, it doesn't sound like they ship the battery anymore, so it arrived with no battery. I needed to source my own. I looked at a few of the options I had and figured I would try what they're using for the new horse-powered cars, which is the NOCO NLP20 lithium battery. The tray from Caterham, I could order, but it's sometimes out of stock and sometimes a little expensive, depending on tariffs. The last time I ordered from the UK for parts, it got held up in customs for a long time because they didn't send all of the documentation. That made me decide I should go and design my own and get it cut specifically for the battery and specifically for the car. I also wasn't sure whether or not the new horse battery would have the same holes and fit exactly the same way. Maybe the ECU was different. I don't know. I whipped this up, printed a prototype, and then I'm going to order it out of aluminum. I'm curious if anybody sees anything obviously wrong or something I hadn't thought of. Once it’s complete, I’ll be happy to share the design files so you can order your own, and I will crosspost this to the 3D printing section when it’s complete. Thanks for the feedback! To be done on the next iteration, I’m going to make the tray a couple millimeters shorter in the front, and put a rubber spacer or something on the bottom to give it a little more grip.
Origin7 Posted 3 hours ago Posted 3 hours ago Great job! If you are going to make this out of aluminum, I'd consider using the full width of the bracket for the mounting tabs. See picture. Aluminum is more susceptible to fatigue failure than steel.
