On another note, anyone wonder like I do who's kit this car started life as?
http://www.ebay.com/itm/231173629252
That's certainly different. :rofl: I'd like to take a closer look at the car. In one of the photos, the upper A-arm looks to be bent rearward. :ack:
Visual aids :svengo:
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/SEsAAOxy4fVTFm-y/$_57.JPG
A search of the internet turns up the following verbiage when it was for sale in Moorpark, California, last year (off a .FR based classified site no less):
2011 V8 Lotus 7 Replica with exclusive fenders!
modeled after a 1972 lotus. All hand built!
CLEAN TITLE
Completely street legal!!
This is not a car for every one. This is a very stiff drivers car. Its pretty much like driving a motorcycle, you need to be aware of your surroundings kind of thing. You need to be very interested in being a driver to drive this car to drive it normally. This is not recommended as a daily driver.... unless you have the spine of Hercules.
This is raw power and a raw car, you get feed back from everything. No computers trying to tell you what to do... just you and the road.
now on to the details...
SPCNS SB100. Only 500 of these kinds of cars are registered a year. Its very difficult to get these replicas STREET Legal! Custom square frame.
Weight is about 2000 pounds wet.
Engine:
302 V8 built Small block Ford
rougly to 1200 miles on car. (recorded 550 speedometer mileage not accurate speedometer cable broke but drove about 600 miles after it broke)
Edlebrock 4 barrel carburetor
Rpm alluminum Intake manifold
Custom exhaust and headers ( Heat Wrapped)
Blower Pulley aluminum
Full Custom Aluminum Valve covers
Accel spark plug wires
stock distributer
new battery ( rear mounted for better distribution)
Drive Gears ( Have a brand new set of regular chain drive gears and chain)
Extra Valve cover gasket and water pump gasket
Full custom tig welded aluminium Radiator
Secondary radiator for better cooling
Edlebrock air cleaner
new v belts ( I would switch to flat belts... v belts are dumb )
new alternator
has power steering and power brakes
Wilwood master cylinder
Wilwood slave cylinder
Stock brakes from 84 mustang gt
Interior:
Recaro Faux seats
5 point locking harness
lotus shift knob
Auto meter gauges ( fuel, rpm, tach, oil pressure, voltage, temp)
carbon wrapped dash, steering column, and emergency brake trim
vinyl center console
carpeted floors
4 point roll cage
12 gallon full custom aluminum fuel cell
autometer fuel sender
plexi glass front custom windshield
plexi glass rear windscreen
Custom vinyl doors that are completely removable with windows
Exterior:
Fully custom LeMans designed fenders only one in the world like this ( plasti dipped in black, can peel them off and have a smoother black underneath)
They are made of steel and are solid, you can stand on them!
Forte 17x7 wheels with good tires
Full custom and removable front clam hood with custom vents and hood scoop
vinyl trunk covers
rear tow hook
Front custom carbon wrapped splitter
Custom Rear Diffuser
rear carbon wrapped fenders
LED tail lights
Harley Davidson Headlights
custom turn signals
Suspension:
Showa Full adjustable coil-overs ( height, dampening, rebound)
adjustable links
custom made pretty much everything. ( control arms, a arms, etc)
Mustang disc brakes front, Drums rear
Edited by mrmustang
I don't know how everyone else feels, but I really like the look with the extra body panels in the car posted above. I know, I know it's extra weight and not needed, but there must be some benefit to the bodywork as far as aerodynamics besides the interestingly good looks.
I agree with Jackal…looks cool.
I'll throw an :iagree: in there for 'cool' factor.
Is it just me, or does that engine just not sound quite right? Wonder why it has so few miles on it after 11 years. The CA SB100 registration is definitely a plus for anyone in CA.
Engine sounds cold, oil might not be thick enough, there's a lot of valvetrain noise. Also something is vibrating/hitting something. They should have taken the video from the exhaust side.
Man I have never seen or heard about that car around KC. Not a Missouri or Kansas license plate. Russ
Gauges, rear diffuser, exhaust, and turn signals that are hard to see from any direction other than straight on? Oh and the fuel cap is odd. Is that a just a twist off/on or is it lockable?
Edited by jlumba81
Ad states: Car came from Birkin America through Texas Motor Works in Arlington Texas.
Would this Zetec engine produce the stated 205hp?
I thought I posted this previously but was obviously having a senior moment...
2012 Caterham R300 with 5 miles on the clock at Chariots of Palm Beach at $50k (rounded up)
http://www.chariotsofpb.com/Inventory/InventoryDetails/tabid/2245/company/CHARIOTS/vin/SDKLDK3NS11070411/Default.aspx
While this is a Bentley and Morgan dealer and a very strange place to see a Caterham, I acquired my 2004 yellow Caterham SV roadsport through them in 2008. They are excellent to deal with, very reasonable in negotiations and very efficient. I would happily deal with them again. They are right next to Palm Beach FL airport so easy in and out. I have no affiliation or background on this particular Caterham though.
How do you get a 2012 r300 with only 5 miles on it? Build must have taken some time. I do like the "non-smoker" in the ad. Either way its a few $k cheaper than a new build.
its actually fairly common to have kits sitting around unbuilt. I know where there is a 2006 kit still in its crate. 2012 kit maybe sold late 2013 and only finished building in 2014 - not unreasonable.
