Here we go again. 25%
Good and bad news. Good news is the car is running on the new ecu and means it can be tuned / driven. Bad news is I'm travelling for work starting wednesday, and will be back around memorial day, if that can scratch your itch. happy to help you try the car out.
Makes sense to me.
Faster. I never drove the car with the fast rack, but on a road course I can't image needing anything faster than the normal ratio.
Silber started following Birkin: What is this device?
For what its worth, with my Birkin having a Duratec and my FPR a different unit, the location is the same as yours: This is an old picture I pulled from my other thread, with an arrow added to point out the FPR.
wdb started following Birkin: What is this device?
It certainly appears to be a regulator, and fuel makes the most sense. But it also appears as though only one of the barbed tubes is connected to a rubber line. That seems odd if fuel is going through it. Is there a third connection, perhaps on the underside?
It looks like the same FPR I ran in my fuel injected Birkin. I think mine was an Aeromotive.
clarexinnusa joined the community
tnttim started following WestTexasS2K
In case it matters, this Birkin is fuel-injected.
m2711c started following Birkin: What is this device?
FPR? edit: Fuel Pressure Regulator?
I'm York area, so not too far. Let me do some measurements and get back. Pics came through fine.
@Vovchandr is right. An adjustable FPR. Scott
Thanks everyone for your comments/feedback. I also reached out to Caterham and asked the question and no response so far. Does anyone have the dimensions of that tank? If I had that I can do some measuring. From the photos I have found, the chassis tubes in front of the engine timing cover is similar in design except that newer frames have a hole where the chassis tubes meet for the tank to mount to. I haven't checked mine to see if it has that. I'm using the photos below without permission, the one with the tank pictured comes from https://www.caterham7diaries.com/post/dry-sump-tank-install The one of the imperial chassis... from racecars direct. Issues with the tank in front of the engine aside, I'd prefer the ease of that over modifying the passenger footwell, which I believe I'd have to do on my car to get a tank there. I did reach out to some local folks today and I could have a triangular tank fabricated for far less than the 900uk, plus shipping and tariffs (ouch). I think a triangular design using .125" aluminum sheet without the curves would be easy to draw up in Fusion 360 and the aluminum bungs/fittings are available at a variety of places on the internet. The only concern would be proper oil/air separation. The Caterham tank appears to deal with that with internal plates, probably drilled or slotted, for the oil to flow down through. Thanks, Scott
