  2. Bumping this, and a new question. I am asking if Marina/Ital 8" rear drums can be changed over to Spitfire 7" drums? Doing this offers a few benefits: Spitfire parts are easier to source. Front ans rear brakes are copesetic with a common vehicle. The brakes are smaller and lighter for a lighter car.
  3. Today
  4. It would be cool if it was someone on here, but it could be a Rugby plate too.
  5. Good morning All, Currently in the U.K. on holiday. We were in the Bedford area heading to the train station when I saw a car, not a 7, parked in a drive way with the registration number “USA 7S”. Wasn’t fast enough to get a picture, but wonder if it belongs to someone on here?
  6. The CA SB 100 was, among many things, desirable about this Caterham. But I’m happy, within a week, a passionate Minnesotan flew out to make a deal.
  7. This was the connection at issue (factory wired side)
  8. Got this sorted. Ended up being the Caterham installed connectors (on both sides) that were not fully seated. Improved my multimeter skills! Wish I found it sooner…
  9. Shame to see that SB100 sticker leave CA... pure gold right there. How many SB100 CSRs are there... not many I'd wager.
  10. Yesterday
  11. Black Beauty (her name from before my garage) had the best ergonomics for me of any car I’ve ever driven, even if your feet are skewed a bit to starboard. The layout made great sense, decent luggage allowance and a spare tyre. To my eyes one of the best body designs ever. And arguably the most fun to drive in it’s responsiveness. These pics from LOG 34 in A’ville. Bob Dance checking her out. We’d met him a in 2012 at Classic Lotus in Hethel, after Lotus were the featured marque at Goodwood Festival of Speed. Getting three cars ready to show was a fun day.
  12. I was gonna ask about a "better" app for planning rides, but it got away from me and I just made something. Vibecoded, anyway. The app itself is just planning; actual turn-by-turn routing is Maps or Beeline (or anything that can use GPX export). Who wants to help me test and share feedback? The concept is a fairly straightforward maps (Google maps) experience to add a series of waypoints to build a long route. Once the route is set up, it can be shared, edited, or navigated. Smaller routes (<10 waypoints) can go straight into Google Maps. Each leg from here -> Waypoint can be navigated (click -> send to maps). The whole route can be exported, then imported into Beeline or anything that reads GPX. For Beeline it's a few clicks to create a new ride from the export. Mobile experience is the same, works surprisingly well on a handset. The sample route below should be viewable here: https://route7-prod.web.app/route/Bj6Gm4GZKw3U Message me a gmail address and I can whitelist for editing.
      • 1
      • Like
  13. It’ll be going East to Minnesota!
  14. Dang Darren, was hoping to see you with this car in person at least once before it went! Is it at least staying local?
  15. Beautiful car. Enjoy your new ride! When I went to check out an Esprit V8 earlier this year, the owner has a white Europa Special in his side yard, completely taken apart to be restored. The owner also has a Esprit S4 and a Elise. He said the Europa handles the best among all these cars.
  16. Caterham fish and chip run 2026 lots of Caterhams
  17. @Colorado7er Josh, have anything?
  18. It's hard to tell, but the first photo looks like it has lowered floors.
  19. Assuming you have the Standard 10 rear axle and brakes, the following link to a resource in the library here should be helpful. As Scotticus recommended, Ken Gray at Dave Bean may be a very helpful US resource. As may Ray at Rzd Enterprises. But if neither have what you need, Google around for Standard 10 resources in the UK - there is a Std 10 club that is quite useful. When I replaced mine a few years ago, new old stock was readily available - though I don't remember if through one of the above resources or through ebay. Also check Kelvedon, SJS, and TTR. If you have a different rear axle, you may need to find alternate resources.
  20. https://www.caterhamlotus7.club/forums/topic/261100-headlight-dipped-and-main-beam-problems/ this may give you some ideas on where to look. Although it’s likely a bit different wiring layout. maybe use a tracer to find where the cut out is happening. https://a.co/d/07OC6834
  21. Hey all - nearing the end of my 360R build and am trying to sort out an issue with the main beams (high beams). Dipped (low beams) headlights work with the switch. But when I turn on the main beams, either with the dedicated switch or the flash to pass switch, the main beams do NOT come on, though the dashboard indicator does come on. Here is what I’ve tested: - Headlight relay works - Main beam fuse is fine - multi meter shows power at the fuse and at the relay as expected. Somewhere along the line, power is being interrupted to the headlights. Given neither main beam works and neither switch works, I’m guessing a connection somewhere. Thanks in advance for any thoughts. Full build can be found in the build threads…
  22. I'm thankful this sold quickly, saved me from making a terrible decision 😂
  23. Tim, you have to go to the Triumph guys for the cars that used the 7" (Stanpart) Standard 10 ,TR 10 axle and shop for those parts. There are many here who have S2s who could give a quick answer. I hope they do. Tony Weale writes, "The series 2 use the cheaper but similarly sized axle from the standard triumph, eight, ten and companion range of cars , which was almost out of production by 1960. Axle supplies, though , lasted for another eight years." If that is what you have. Rear brakes may have been changed out to suit the 7 and another owner may have so checking that is something. I reccomend pulling a drum and measuring the inner diameter and brake shoe width. Get any part numbers off the shoes, drum back plate, drum, and axle. An interesting factoid, a Standard 10 axle from the 60s still has a lot of part interchangeability with the Ital/Marina axles of the 80s. I will look for the info for the Triumph Standard 10 brakes. Another thing, what you find will not likely have the correct shoe compound. Shaving down the middle of the shoes may help prevent lockup. Here is a relining specialist https://porterfield-brakes.com/manufacturer/brake-shoes/ From Tony Weale Per Weale, rear brake shoe PN for 60-68 S2 Standard Axle is "MGR21", which may be an early Caterham catalog PN. Per the Caterham Lotus 7 S2,3&4 Service Manual reprint, Section J 10, Rear shoe PN for "M.S.1"= "120131", which may be for S1 Metropolitan axle. Then M.S.3 =8260. Unfortunately in the illustrated key to axle components list, he brake shoe PN is not listed, sec H 5. But it would be a Lotus PN. The Dave Bean catalog gives this You may want to call Ken @(209) 754-5802 Must join the club to buy. Excellent prices https://www.standardmotor.club/standard-8-10-etc/braking-system-1/brake-shoes-adjusters-brake-springs-and-fitting-kits So far, it appears that the Spitfire 7" rears are identical to the Standard 10, but the back plate may not be. I don't know if there is any offset issues with springs, etc. I will update this post with new info.
  24. Last week
  25. Need the brake handle and cable please
  26. Need S2&3 wing brackets
  27. Considered, but I hope for smaller so as not to obstruct flow to radiator
  28. Wayne, thanks for the quick reply. I do have a shipping drop in Buffalo NY or they could go to a friend in PA. As to selecting a shipper, I don’t have a clue. The key would be the packaging. My experiences with having delivery companies pack have not been overly positive. If there is anyone one you could recommend, it would be miles better than my guessing. Regards, John
  29. Looks that way to my eye, too.
