Mouscaterh started following HPC Questions
JohnCh started following Caterham feature in Avants Magazine
The latest issue of Avants magazine has a nice article on Caterham that was pulled together with the help of some Seattle-area owners and features some very nice photography. https://www.avants.com/magazine/the-benchmark-for-lightness?
- 5
CBuff started following What you wish you knew before giving your 7 to a local mechanic
I have to imagine (even with the less expensive mechanic options). Multiply that by the number of cars across multiple countries requires @Croc to keep the work revenue coming in. last I heard that 2021 unplanned stop vehicle is still there. Not to mentioned how many cars (@crocaliasbringatrailer) has that no one knows about. I look forward to continuing to invite myself down to njmp and eventually tour the garage-mahal when all the cars come home to roost. Hopefully I’m not using a walker at that point.
activtestode joined the community
Ah. https://www.autoblog.com/news/trump-plans-25-tariff-on-european-cars-prices-could-surge
FalconResistor joined the community
As I'm waiting for my kit, I don't actually see a new tariff. The news articles from today say that after a year, the US/UK trade fell by 25%, is that what you're referencing? He did remove a whisky tariff today after dinner with the King during a toast... which is the dumbest way to do trade policy I've ever heard.
Here we go again. 25%
Good and bad news. Good news is the car is running on the new ecu and means it can be tuned / driven. Bad news is I'm travelling for work starting wednesday, and will be back around memorial day, if that can scratch your itch. happy to help you try the car out.
Makes sense to me.
Faster. I never drove the car with the fast rack, but on a road course I can't image needing anything faster than the normal ratio.
Silber started following Birkin: What is this device?
For what its worth, with my Birkin having a Duratec and my FPR a different unit, the location is the same as yours: This is an old picture I pulled from my other thread, with an arrow added to point out the FPR.
wdb started following Birkin: What is this device?
It certainly appears to be a regulator, and fuel makes the most sense. But it also appears as though only one of the barbed tubes is connected to a rubber line. That seems odd if fuel is going through it. Is there a third connection, perhaps on the underside?
It looks like the same FPR I ran in my fuel injected Birkin. I think mine was an Aeromotive.
