How about Sprite/Midget brakes? They're in that size range. note--drums would need re-drilling
theDreamer started following Registration Plate
The plate USA 7S is registered to a Grey 2014 Mini Paceman Cooper 4x4 which the last MOT showed having 76,862 miles. No personal info available. Sound like a car owned by anyone here?
Bumping this, and a new question. I am asking if Marina/Ital 8" rear drums can be changed over to Spitfire 7" drums? Doing this offers a few benefits: Spitfire parts are easier to source. Front ans rear brakes are copesetic with a common vehicle. The brakes are smaller and lighter for a lighter car.
It would be cool if it was someone on here, but it could be a Rugby plate too.
Johnnyb2016 started following Registration Plate
Good morning All, Currently in the U.K. on holiday. We were in the Bedford area heading to the train station when I saw a car, not a 7, parked in a drive way with the registration number “USA 7S”. Wasn’t fast enough to get a picture, but wonder if it belongs to someone on here?
thebioverausaa joined the community
Got this sorted. Ended up being the Caterham installed connectors (on both sides) that were not fully seated. Improved my multimeter skills! Wish I found it sooner…
Black Beauty (her name from before my garage) had the best ergonomics for me of any car I’ve ever driven, even if your feet are skewed a bit to starboard. The layout made great sense, decent luggage allowance and a spare tyre. To my eyes one of the best body designs ever. And arguably the most fun to drive in it’s responsiveness. These pics from LOG 34 in A’ville. Bob Dance checking her out. We’d met him a in 2012 at Classic Lotus in Hethel, after Lotus were the featured marque at Goodwood Festival of Speed. Getting three cars ready to show was a fun day. -
Austin David started following Software: the perfect routing/mapping app for group rides?
- 1
empti started following Europas that have graced our garages, as well as the Sevens
@Colorado7er Josh, have anything?
It's hard to tell, but the first photo looks like it has lowered floors.
SENC started following Series 2 brake shoes?
Assuming you have the Standard 10 rear axle and brakes, the following link to a resource in the library here should be helpful. As Scotticus recommended, Ken Gray at Dave Bean may be a very helpful US resource. As may Ray at Rzd Enterprises. But if neither have what you need, Google around for Standard 10 resources in the UK - there is a Std 10 club that is quite useful. When I replaced mine a few years ago, new old stock was readily available - though I don't remember if through one of the above resources or through ebay. Also check Kelvedon, SJS, and TTR. If you have a different rear axle, you may need to find alternate resources.
CBuff started following Main beam wiring
https://www.caterhamlotus7.club/forums/topic/261100-headlight-dipped-and-main-beam-problems/ this may give you some ideas on where to look. Although it’s likely a bit different wiring layout. maybe use a tracer to find where the cut out is happening. https://a.co/d/07OC6834
antonelo1968 joined the community
ketonovaketousa joined the community
Hey all - nearing the end of my 360R build and am trying to sort out an issue with the main beams (high beams). Dipped (low beams) headlights work with the switch. But when I turn on the main beams, either with the dedicated switch or the flash to pass switch, the main beams do NOT come on, though the dashboard indicator does come on. Here is what I’ve tested: - Headlight relay works - Main beam fuse is fine - multi meter shows power at the fuse and at the relay as expected. Somewhere along the line, power is being interrupted to the headlights. Given neither main beam works and neither switch works, I’m guessing a connection somewhere. Thanks in advance for any thoughts. Full build can be found in the build threads…
Tim, you have to go to the Triumph guys for the cars that used the 7" (Stanpart) Standard 10 ,TR 10 axle and shop for those parts. There are many here who have S2s who could give a quick answer. I hope they do. Tony Weale writes, "The series 2 use the cheaper but similarly sized axle from the standard triumph, eight, ten and companion range of cars , which was almost out of production by 1960. Axle supplies, though , lasted for another eight years." If that is what you have. Rear brakes may have been changed out to suit the 7 and another owner may have so checking that is something. I reccomend pulling a drum and measuring the inner diameter and brake shoe width. Get any part numbers off the shoes, drum back plate, drum, and axle. An interesting factoid, a Standard 10 axle from the 60s still has a lot of part interchangeability with the Ital/Marina axles of the 80s. I will look for the info for the Triumph Standard 10 brakes. Another thing, what you find will not likely have the correct shoe compound. Shaving down the middle of the shoes may help prevent lockup. Here is a relining specialist https://porterfield-brakes.com/manufacturer/brake-shoes/ From Tony Weale Per Weale, rear brake shoe PN for 60-68 S2 Standard Axle is "MGR21", which may be an early Caterham catalog PN. Per the Caterham Lotus 7 S2,3&4 Service Manual reprint, Section J 10, Rear shoe PN for "M.S.1"= "120131", which may be for S1 Metropolitan axle. Then M.S.3 =8260. Unfortunately in the illustrated key to axle components list, he brake shoe PN is not listed, sec H 5. But it would be a Lotus PN. The Dave Bean catalog gives this You may want to call Ken @(209) 754-5802 Must join the club to buy. Excellent prices https://www.standardmotor.club/standard-8-10-etc/braking-system-1/brake-shoes-adjusters-brake-springs-and-fitting-kits So far, it appears that the Spitfire 7" rears are identical to the Standard 10, but the back plate may not be. I don't know if there is any offset issues with springs, etc. I will update this post with new info.
- Last week
Need the brake handle and cable please
Considered, but I hope for smaller so as not to obstruct flow to radiator
