JohnCh
Administrators
Everything posted by JohnCh
  1. Reactions are a way to quickly respond to a piece of content -- post, gallery, article, or download -- with a simple icon. Reaction options are: To give a Reaction, look for the Like icon (Heart-in-a-circle) in the lower right corner of any content, tap the icon or hover your cursor over it, then select your Reaction icon from the choices that appear to the left. If you wish to remove or change your Reaction, simply click the X next to the one you selected and start again. You will only see the X next to Reactions that you have submitted. Hover over or click any Reaction to reveal who submitted it.
  2. We now have Reactions available that enable people to post a reaction to any piece of content using an intuitive icon. Options are: To give a Reaction, look for the Heart-in-a-circle icon at the lower right of any content, tap the icon or hover your cursor over it, then select your Reaction icon from the choices that appear to the left. Before anyone asks, yes there are other gamification features available such as Leader Boards, Badges, and Reputation Scores. Some people love those in a forum, but I have heard from others here who expressly do not. Because these options are not something that a user can turn off, and they do bother some in our community, I am consciously choosing to not enable them at this time. That means the forum may not be quite as engaging as some would like, but it won't be bloated and turn others away. We are all passionate about a simple, basic, no-frills car (writes the person who's building a car with traction control and heated seats -- yeah, I get the irony). I'd prefer our forum reflect that spirit. Cheers, John
      • 4
      • Haha
      • Thanks
      • Like
  3. When researching it, I discovered the mistake is very common on Invision forums with many admins requesting changes to allow partial implementation to eliminate those oops moments. e.g only allow people to post status updates to their own profile page. For now though, it's all or nothing. -John
  4. I'm actually playing with this in the test environment. Stay tuned. -John
  5. Thanks for that offer! If I run into a bind, I will let you know. Most things I do should be pretty simple. I'm hoping something like emachineshop.com will suffice, but there are a number of machine shops in my area with good reputations if they don't work out. Cheers John
  6. Thanks, and you're correct, I'm using an FDM printer, so that won't apply. My current plan is to use the printer for rapid prototyping, then have any parts machined based on the CAD files. Thanks, John
  7. Which type of filament did you use for this? I will likely print some parts for my build, but I'm not clear on the best option for the heat, grease, and oil it could see under the bonnet. As for your compressor brackets...wow! Almost too pretty to hide under the back of the car. Thanks, John
  8. There is a feature in our forum software that enables you or anyone else to post a status update that appears on your profile page. Anything posted there is public for anyone to see -- even spam bots that troll the web. Unfortunately, people miss the text in the status update box that indicates this is public information and confuse it for a Private Message (see portion circled in red below.) On many occasions, I've removed phone numbers, email addresses, and even home addresses when someone has made this mistake. Because the proper use of this feature is so rare, and the privacy issues created when it is used incorrectly are severe, I am making the decision to turn off Status Updates. As per Invision, who makes our software, this is the only option as the feature is only fully on or fully off. Thanks, John
  9. @cemaykan this may solve the problem of needing to keep your speed below 35mph. With a top speed over 135mph, it should have a better chance keeping up with your 620R BTW just noticed this is in General forum and have moved it to the Video forum to make future discoverability easier. -John
  10. Differing opinion here based on my experience. Only the middle of the underside is blocked. Since I rarely do transmission work, that has not been an issue for me. I have access to underneath the engine (both front and rear engine cars), diff, suspension, brakes, and can raise the car to make it easier when working on the top of the engine. Perfect? No, but it's a huge step up from jack stands with a normal car (see my earlier comments about the Westfield). Compared to a two-post lift, there are no arms to step over/duck under when working on the corners such as when bleeding the brakes and it lives under a car so takes up no space. That doesn't mean it's better than a two-post -- transmission work is difficult and although you can sit under the car, you can't stand -- but it does have its own set of advantages. Not for everyone, but no regrets from me after 10+ years of use. -John
  11. I've had a Bendpak MD-6XP for over 10 years. It works very well for most jobs, however, the one car I don't use with it is the Westfield. I find it's much faster and easier to get that up on Esco jack stands using a low-profile jack than it is to move one car off the lift, then drive the Westfield over it. -John
  12. @Bruce K the inboard front suspension was driven by ride and handling improvements, not an effort to increase top speed. See this PDF from Multimatic about the CSR suspension project scope and targets. A more aerodynamic brick is still a brick BTW although Multimatic did do aerodynamic analysis as part of the larger project, my understanding is that was focused on reducing lift, not drag. Someone else may know definitively. -John
  13. Twenty plus years ago I was torn between the Lotus Elan and a se7en but eventually opted for the latter. Although I finally scratched the Elan itch three years ago, I went with the fixed head coupe version rather than the convertible since the Westfield handles open air duties. If I were buying a car now and se7ens didn't exist, I'd go with the Westfield XI. For me, part of the se7en charm is the extreme exposure to the elements which you don't quite get in an Elan even if it's a drop top. -John
  14. The pivot pin for the tensioner arm went in this morning. Between putting the pin in a deep freeze overnight and heating up that section of the head with a propane torch, it didn't take too many taps with a hammer to drive it in place. Once that was done, the remainder of the timing assembly was installed, along with the water pump and thermostat housing. However, as @Croc predicted, I didn't have time to dial in the cams. Hopefully that happens next weekend. -John
  15. Direct link to the Birkin Yahoo Group Photos.
  16. The votes are in, and the decision made. If you factor in the fact that 96 people visited this topic, but only 15 chose to vote, that means the overwhelmingly favorite response of the group was the hidden option: I don't even care enough about this to vote. Since there is no downside at this point, I'll keep it up. At a minimum, it's probably a nice thing for first-time visitors. If you don't like the changes, the simple workaround is to update your favorites to point to your preferred Activity Stream rather than the home page. If you aren't familiar with Activity Feeds or how to use them, see this help topic. John
  17. I didn't realize you were bringing someone with you. Thanks for the heads up! -John
  18. Um...I got it from you! It was included in the Birkin Group files you sent for us to publish after Yahoo shut down their service. -John
  19. Finally picking this back up after some unavoidable issues meant the head didn't arrive until 10 days ago. Last weekend after installing the ARP head studs, dropping the head gasket and head into place, then coating the washers and nuts in ARPs lube, I began placing those last two items onto the studs in preparation for the torque sequence. That's when I discovered there were 10 studs, 10 washers, but just 9 nuts. I didn't count the nuts before opening the bag so I can't confirm I was shorted, but I did it all in one area of the bench and searched everywhere afterwards. Either it is shacking up with all my missing socks or it never made the trip. Regardless, a replacement was ordered and arrived Friday. Head and cams in place and torqued: Below is the factory VVT front cam cap setup. Unlike the non VVT engines, which use separate caps for each cam, this uses a one-piece cap for both and has provision on the intake side for a solenoid that drops into the downward facing port on the right. The Raceline VVT delete replaces the factory solenoid with a machined part with journals that maintain oil to flow to the intake cam journal. Because I purchased a new, bare head, the pivot pin for the timing chain tensioner arm needs to be installed, but that turns out to be a very tight fit. Before trying to configure some type of press, it's getting an overnight soak in the freezer with attempt number two happening in the morning. One of the interesting things about the 2.5L engine is it doesn't use a lower guide for the oil pump chain but does use a larger tensioner. The first picture below is from the CSR 260 engine assembly manual. Although Cosworth doesn't use that guide with their dry sump, you can see the two bolt holes for mounting it circled in red. The second photo is my engine and as you can see, there are no holes. If I have time tomorrow, I'll time the cams and button up the engine. -John
  20. I went with heated seats too. I figure they are good for those days when I'm torn between wearing a light jacket and risk being too warm or wearing just a shirt and wishing I had worn the jacket. -John
  21. The Thackeray washers fatigue from vibration and eventually break, so given the price, it's a good idea to replace them while you have the carbs off. One thing to consider: Thackerays on the bottom and rubber grommets on the top. The Thackeray failure rate is much higher on the top studs, but the rubber grommets fail over time from fuel leakage. This arrangement, recommended by Dave Bean, optimizes for both. -John
  22. Given it sat outside for 15 years and even had a "tree" growing through the bonnet, the car looks in remarkably good shape. Any signs yet that rodents attacked the wiring? -John
  23. That first paragraph is from their Octane Booster instructions and the fl oz options match that product, not the ZDDP. Really poor editing on their part to mix the two. -John
  24. Thanks Bill and Tom. I'm using part of the native Invision functionality, so keeping it won't add maintenance overhead. The work to enable it is done and the effort to turn it off will only take a few minutes. I did a double take when I first saw her photo. Unfortunately, non-se7en photos will continue to show up unless we make an edict they are not allowed in public galleries, which seems like overkill. Perhaps the best option to minimize those is to encourage public shaming when they show up -John
  25. As mentioned in this thread announcing test changes to the forum home page, it's time to vote. Do we keep those changes or revert back to the plainer home page? I'll keep the poll open for a week to enhance the drama. -John
