JohnCh
Administrators
Everything posted by JohnCh
  1. Although it doesn't indicate this is the upgraded MC, I believe this is it. The giveaway is the really thick mounting flange AP use for this model. https://caterhamparts.co.uk/master-cylinder/29-brake-master-cylinder-13-16-all-de-dion-cars.html -John
  2. Here is another S2000-powered car on throttle bodies with amazing sound, but this time it's on a closed course so nothing other than pylons are at risk. Nice to see @Davemk1 setting another FTD at an event last month. Hopefully he starts posting about his autocross exploits this season (hint, hint). Rumor has it that he's been successfully defending the Se7en's honor against a local Ariel Atom. -John
  3. I received the same email. Given my car went to QA a couple of months ago and has been sitting ever since due to a missing cooling hose and grill for the 620 nose cone, I can empathize with your pain. I suspect the shipping delays will make this an even longer process and may turn this into a winter project. Oh well... -John
  4. Walk around video here. It certainly is...unique. -John
  5. I was surprised to see @BlueBDA's car on BAT when I checked it this morning. Like Kitcat, this has always been one of my favorites; great color combination and a fantastic engine. -John
  6. Westfield Mega S2000 (Honda S2000-powered model) on throttle bodies. Great sound. Not sure about the two-way traffic on that road though -John
  7. I moved the original post to the correct forum, so locking this one to keep the discussion in one place. -John
  8. Nice recent battle between two Caterhams at Pacific Raceways in the Seattle area. Are the drivers anyone here? -John
  9. Check RockAuto, but remove the spaces in the part number which their search tool doesn't seem to like or automatically remove. Also, not to raise a seed of doubt, but is it possible you transposed those last two letters? When the penultimate letter is A that designates it's for the 4-cylinder implementation. When it's B, then it's for the V6 version (the last letter identifies a very minor revision to the pattern, so typically a part ending in B is the replacement for the part ending in A). Birkin may use the 4-cylinder version but both Raceline and Caterham use the part intended for the V6. This post shows the differences between them: -John
  10. BTW if they do show as on, then the notification mails are likely getting caught in your spam folder. -John
  11. @Moifnotifications are on by default. You must have inadvertently turned them off. Please see this help guide that walks through how to turn them back on and modify the settings based on your preferences. Thanks, John
  12. I know this is a very unlikely scenario, but if your odometer is wildly pessimistic, it could result in a lower mpg calculation than the car is actually returning. -John
  13. When my Duratec was in 420-ish guise (same cams but with Jenvey's), it would generally return low 30's on high-speed sections of tours. The car has a windscreen and very large wind deflectors, both of which negatively impact aero, but that is partially offset by the 3.62 diff vs. 3.92 in your car, which translates to 3079rpm at 70mph. I typically average 25-26mpg in normal use; no freeways, running errands in town, back road blasts, and bursts to redline. -John
  14. If that's a concern, I'd do a test install of the seats and measure remaining space to see how close it is in your specific car. If you want to be thorough, but don't also want to temporarily put the carpet in place, drape a smaller section over the tunnel along with a piece of the KOOL Mat and see what happens. -John
  15. Interior heat has never been a real issue for me except on brutally hot days in traffic. I'm not running any form of heat barrier on the footwells or tunnels, but my exhaust manifold is ceramic coated. Might be something to consider. I agree with others regarding sound dampening. It may help with some driveline noise, but it's kind of like opening a pint of ice cream and rather than eating the entire thing, you reserve the last spoonful because you are trying to lose weight. Is your waistline really going to notice that nod to restraint? Probably not... Best form of noise reduction in a se7en is a good set of earplugs. -John
  16. My car uses a swirl pot and has zero issues with starvation. Another option to consider is the Holley Hydramat. Unlike the swirl pot, no secondary pump is needed, and it doesn't require tank removal to fit. No first-hand experience with it yet, but I am using one in my upcoming build. -John
  17. Wow, that's an impressive improvement, particularly over 6300 rpm. Do your driving impressions correlate with the dyno results? -John
  18. This site has a lot of information on the various Sierra diffs that might help: http://www.super7thheaven.co.uk/components/sierra_rear_differential/ -John
  19. Someone who successfully raced in the Westfield Speed Series for many years provided me the settings below which he arrived at after significant testing. From a wear perspective, the front tires don't like that much camber on the street, but it definitely helps out in the corners, so it's a tradeoff I've been willing to make. Rake is a pretty important setting for a Westfield with IRS. Make sure you set that using the factory measuring points. Camber Front: -2.5 Rear: -1.5 Toe (total) Front: 16 min toe out Rear: 24 min toe in Chassis Rake +20mm rear to front -John
  20. It has a name. In fact, a hint was provided in one of the photos shown in this post of my engine build thread. -John
  21. Bruce sent a few photos of my car this morning. It's complete but still waiting on silicone hoses and the 620 grill before it's ready for pickup by the shippers. If all goes well, the crates should be in my garage by mid June. I've seen a number of photos of cars this color in various lighting conditions that reveal it can go from a very bright green in direct sunlight to a little goldish in shadows and indirect light as in the factory shots below. I suspect it will prove to be a love/hate color. I'm just hoping I love it. If not, I suppose I can always keep the Westfield -John
  22. Interesting. That confirms Ford either made a running change at some point or decided certain Duratec installations didn't require the port. -John
  23. Andy, I wasn't referring to the alignment pins that locate the cover to the block and head. Rather, I meant the port over the timing chain tensioner that allows you to insert the pin that holds the plunger in place (see blue arrow). Every cover I've seen has this port with threaded plug, but Esslinger made a comment that they like that Mazda cover because it has this feature. I interpreted that to mean not all covers include it, but that could be wrong. It seems odd that would not be universal. -John
  24. Looks like it and it even appears to have the port for the timing chain tensioner pin. And it's cheap! I paid a lot more than that for the used one and the best price I found at the time for the Mazda version was over $200 new. -John
  25. My understanding is the 2.3L and 2.5L are interchangeable, but I would confirm that using a Ford parts search. As I recall, Esslinger uses this particular cover because it has a port over the timing chain tensioner that enables you to insert the pin that holds the plunger in place. My 2.0L has this same port, so my guess is that Ford may have removed it at some point, and Esslinger standardizes on the Mazda item which continued to use it. The Mazda part number is: L3AW-10-500. However, the part I received from the Mazda dealer (mazdaswag.com) was hideous. The worst new casting I have ever seen. After receiving my photos, they confirmed another recent sample sent by Mazda was in the same condition and appears to be the new norm. To their credit, they refunded my money without any pushback -- really good customer service. I then purchased a used one from a wrecking yard and spent time cleaning it up. That casting was much, much better. -John
