JohnCh
Administrators
Everything posted by JohnCh
  1. According to time stamp, @Croc and I posted that same question within a minute of each other. Scary... -John
  2. Very cool! Not sure which is more impressive: the drone's tracking ability or your restraint to drive a 620R below 35mph on an empty country road. How far away can the drone continue tracking the car and what happens if you exceed that range because of a momentary lapse in restraint? Does it maintain that last position and wait for the car to return? -John
  3. I hate intermittent electrical issues. I had something similar on my car a few years ago. After proactively replacing a lot of stuff, the eventual fix was a new engine loom. Not as drastic as it sounds given I hacked together the original out of the Ford loom that came with my engine and the replacement was professionally made. Easy things to check: First, any commonality to when this occurs? Engine hot? Engine cold? After engine fan kicks on? etc. When the engine is running normally, start shaking parts of the engine loom to see if that triggers the condition. You're trying to expose a broken wire or connector for a sensor, fuel injector, or ignition. Disconnect the sensors, ignition coil, and injector plugs then check the pins for corrosion or if one pin is further down the connector than the others, indicating it is not fully seating with its mating pin on the other connector. (note: if shaking the various wires results in bad kitty mode, check the pin seating depth as that could be the cause.) Clean all your engine grounding points with some very fine sandpaper. Murphy's Law fully applies to intermittent electrical issues. It might not be one thing that is egregiously bad, but rather several little things that in aggregate create the problem. Hence the reason I needed to replace my loom. If all that checks out, then I'd move on to the bad sensor/coil pack theory. I'm sure other (and better) advice is incoming. -John
  4. I've been told by a shop that has tuned a lot of Duratecs on the dyno over the years that max power correlates to AFR in the 12.5:1 - 13.3:1 range and to shoot for 13:1. I agree with Graham that those numbers are not ideal at full throttle but not likely dangerous on a stock 420 engine, particularly given they richen up at high rpm. BTW that torque curve is really, really flat! -John
  5. Longest solo was ~750 miles (Portola Valley, CA to Centralia, WA) after buying my original Westfield. The plan was to make it another 90 miles to reach home, but I discovered the headlights were dead and it was getting dark. Longest with a passenger was ~640 miles (Lafayette, CA to Vancouver, WA) on the way back from USA2005. Would have tried the remaining 180 miles to home, but it started raining pretty heavily when we reached Portland. I can only recall getting stuck 3 times in over 20 years of se7en driving: Alternator pulley on the crossflow self-destructed while on my morning commute, which stopped the water pump from pumping. It's the only time I've ever had a car overheat in 40F degree weather while driving 70mph. Shortly after returning from USA2005 the alternator bracket broke. Throttle cable broke while in stop and go traffic. It fell down, shorting against the alternator's 12V+ connection while part of it was still touching the oil impregnated air filter. For those wondering, that combination does turn the air filter into a flaming torch. -John
  6. Some additional tools I throw in my tool roll when touring: Self-fusing silicone tape. Good for hose leaks or as electrical tape. Duct tape Pocket multimeter Wire strippers/crimpers and a few spare crimps and splices ECU comm cable for laptop -John
  7. JohnCh
    2005 USA2005 tour photos
    @Vovchandrwould do a great job! Here is the route book from the 4-day tour I mentioned above to get you started. It was based on the USA2005 route book and will give you an idea of things to think through during the planning process. -John NorCal 2008 Route Book - 0830 no euii.pdf
  8. Finish 2.4L Duratec Build my incoming Caterham Sell the 420R engine and all the other kit parts I don't need Register Caterham Sell Westfield (although I may delay this until 2023) Blat, blat, blat! -John
  9. 40 amps is pretty common in these cars. I've had a Denso 40 amp fitted since 2004. With halogen headlights and big SPAL fan both running when idling, the volts drop a bit, but not enough to cause issues. The volt gauge returns to normal levels as soon as the revs rise. In addition to having the alternator checked, it's always a good idea to clean the major grounding points. -John
  10. I tell people factory-built cars are available in other countries, but the only way to get one legally in the US is in component form. I try to avoid the term kit car since many people still associate that term with the old VW-based kits which then leads to the question "So it's a Beetle?" As for queries on price, my default response is "more than my wife thinks." That usually stops the conversation, particularly when she is standing next to me. -John
  11. That's a nice feature. Is there a similar bracket on the rear of the chassis, or are you only expected to go off the road backwards? -John
  12. @SENCI don't think the Invision platform supports that, but I'll look into it. Unfortunately, images inserted into a post are handled very differently on the backend than those inserted into a gallery, creating its own set of problems. A big one is that unlike a post, gallery uploads are not resized to reduce storage requirements (and for posts, reduce page load times.) That means we either have to implement small file size requirements for gallery uploads, requiring people to resize images before they upload them, or we have to limit the number of images per person. There is a long standing ask for Invision to change this and give admins the option to auto-resize gallery images, but nothing yet. -John
  13. JohnCh
    @VovchandrAll it takes are a few people willing to invest the time necessary to handle the myriad of logistics and a sufficient number of people with se7ens who are willing to commit the time and money to attend; both of which are easier said than done. Speaking from experience, odds and planning difficulty are inversely proportional to the number of cars committing. Biggest tour I planned spanned 5 nights and 4 driving days with 9 cars committing and 2 dropping out at the last minute. I can't imagine the effort required for anything bigger. Something at the USA2005 scale is off the charts difficult.
  14. Version 1.0.0
    106 downloads
    Caterham Assembly guide from October 1988
  15. Sorry @Croc it looks like your account may have been infected with a virus during last night's upgrade. -John
  16. Should be working now. It looks like the global settings were being overridden by conflicting settings buried within some user groups.
  17. It's a user setting that provides album owners with a level of control. Please see the help article on albums. -John
  18. I'm sure many of you are wondering what happened to the home page layout. After prompting from @Vovchandrto better expose the gallery functionality, I've implemented a way that doesn't involve custom code but does come at the expense of pushing the list of forums further down the page. To offset this, feeds were added to the right that highlight new topics, popular topics and new downloads. There are no changes to navigation or Activity Streams, so any links in your favorites that go directly to an Activity Stream will continue to work unchanged. I'll do a poll in a couple of weeks to gauge opinions once everyone has lived with it for a bit. If people hate it, we'll revert, if people like it, it will stay. Below is a brief description of each feed. Simply click on an image or post within a feed to access it directly. 1) Rotating image feed displays up to 30 random images from the Gallery. The feed is refreshed with a new group of images each time you visit or reload the page. 2) Newest Topics - displays the 5 newest topics on the forum. 3) Popular Topics - displays the 5 topics with the highest post count. 4) Newest Files in Downloads - displays the 5 most recently uploaded files to the Downloads section. Note: if you are viewing the forum on a mobile device, feeds 2, 3, and 4 will appear below the list of forums to maintain readability of that section. -John
  19. Every forum member can share their photos in the Members Album located in the USA7s Gallery. You may do so either directly or by creating an Album associated with your account. Paid Club Members may create up to 3 albums and upload images as large as 6mb. Registered Users thresholds are 1 Album and up to 3mb per image. To add an image to the Members Gallery, click the + Create button at the top right of any page, then select Gallery Image from the drop down. On the next screen, click Select then choose Member Albums and follow the prompts to add images to either a new album, your existing album(s) or directly to the Members Gallery. When creating a new album, you have the option to allow comments and ratings for the images it contains. You can change this at any time by going to the album, clicking Manage album then edit. To view the album of a specific member, or to view your own album(s), visit the user's Profile page, then click the Albums tab. To access all the images within an album, click on either the album title or one of the preview images from that album.
  20. thanks @anduril3019 and @coffee break @Vovchandr numbers are essentially flat over the past year. Stay tuned for a survey. Hoping it comes reasonably soon, but given supply chain issues... -John
  21. I appreciate the input and wish others were as vocal as you have been over the past two years, so we have a broader view of what people want (hence the survey I mentioned.) I may be a little sensitive to the gallery suggestions since you have made them many times before and I'm running out of ways to say "I hear you, but..." Sorry about that. Bottom line, the forum is in a much better state than it was 11 months ago, but it can be so much better. I just want to ensure we are thoughtful about any changes and start with the objectives, then map the features/changes to those objectives. Without that, it's difficult to prioritize between them and the result is a lot of activity, yet the underlying metrics we are trying to achieve are unchanged. Simple example: if a key objective is to increase engagement in the forum, key metrics to support it might be 1) number of new threads/month, 2) number of posts/thread, and 3) number of posts/member/month. There is a funnel view for this that starts with visits to the forum, progresses to conversions of these guests to Registered Users, then into the 3 metrics above. If a feature improves the visits, but the conversion from guest to registered is unchanged, did that feature make an improvement that we care really about? Conversely, if the objective is eyeballs and people prefer viewing images to reading posts, prioritizing any features that support forum engagement would be questionable effort. The examples above contain some hyperbole, and shouldn't be taken as absolute, but it's the best I can do while multi-tasking in a meeting As a next step, I'd like to explicitly identify our objectives, the metrics that reflect achievement of those objectives, then identify the features/changes that support those metrics, ideally in a way that allows us to measure any correlation. It's going from strategy to tactics to quantifiable proof of success or failure. -John
  22. @Vovchandr I wouldn't expect people to click a text link that simply reads Text Link. You need to compare apples-to-apples or the data is useless. Having a graphic that reads "Win a Caterham" then comparing click through rates to a text link that reads "Win a Caterham" is the correct methodology. For a text link to work, it needs to be descriptive. As for Facebook, again, apples-to-apples. A forum feed is never going to have as much new information over a 3-day period as a FB feed that spans dozens of pages a person may follow. There is a significant scale difference. That said, I hear you, and we are thinking about additional functionality, but I am not adding functionality that increases overhead. That means no custom code, and only plug ins that have strong user feedback. I need to go through a test matrix every time the software is updated which can happen monthly. One reason we have stability is we only have one plug in that is at risk from these updates. It has a large user base with a long track record of not breaking and was thoroughly vetted. @croc and I are thinking about running a survey to get feedback from our broader community to understand potential changes that would drive engagement. This isn't a revenue generating forum where capturing eyeballs is the objective. The reason I'm here, and the reason I volunteered to take over admin duties from Mazda is because it's a valuable resource and pleasant place to hang out for people who are interested or own Se7ens; it's the combination of the people and the knowledge base we've collectively created. Provided other members feel the same, I'd like to pursue improvements that help us take those benefits to the next level. If having a rotating image gallery at the top of the forum is what the broader group wants, then we can pursue that. Thanks, John
  23. Both good ideas, but as soon as we start doing customization, things get very difficult to manage and someone else would need to take over. The reason we went with this software is it gave us a ton of reliable functionality out of the box. Now that we are 11 months in with no issues, I may be able to add a little more native functionality as time allows. As you are aware, this is volunteer work for me, and I have to balance time invested with my day job and personal commitments. -John
  24. I've tried to make the site intuitive, and self-help enabled, but there is always room for improvement. As for the Community Map, yes, it's being used, but I'd love to see more people take advantage of the feature. And if you are reading this but haven't put yourself on the map, see the dedicated Help Guide which even contains tips for maintaining your privacy -John
  25. Have you tried this style of ball joint separator? I used this one from HF on a particularly stubborn set of front ball joints on a 993. I cranked it down really hard on the first one until I feared something would break, then let it sit in place while I prayed to various deities. After about a minute, there was an unholy bang and the ball joint popped out. The tool created enough force on the other ball joint that it actually bent the threaded end which then had to be removed with a cutoff wheel. -John
