Everything posted by Dave W
Before you start, mark the four tire spots on the floor. Then with a level, and a long straight edge shim under the scales to get every thing level. Don't be surpised if the garage floor is more then 3/8" off in that short span. I used a paint pencil marked the locations and required shim right on the floor. Dave W
Look at Speedway or E-bay, for the type of mirror that clip on to the rain gutter seam use in the 40s and 50s cars. They clamp on with two small set screws. No holes required but will leave marks where it is clamped on the windshield up-right. Dave W
PM sent. Dave W
prepping for a tour - whats the list of maintenance?
Dave W replied to twobone's topic in General Tech
After looking at slomove's list, I'm not complaining about 2 exhaust hangers, a water pump, and a windshield, in 22,000 miles. But I think I'm going to check my fuel lines this weekend! Dave W -
Roberto The first thing I would do is remove the thermostat and place it in a pan of water and slowly heat it up to see when or if it will open. If it is not a air lock, and it does not sound like it, then high probability that it is the thermostat. If you do get a new thermostat I would drill an 1/8" dia hole in it to help with filling the system and removing the air. Dave W
I have mud flaps that clear the ground by about 3". There is a definite reduction in the stone chips in the spats and fender. But I still have a lower band of about 4" that gets a lot more sand blasting on the spats. Probably about 2" ground clearance to the lower edge of the flap may be the ticket. I just made them to a lenght that I thought looked the best if flaps can look good? Dave W
My old MG had a cork valve cover gasket with the same problem. I found an after market rubber gasket for the cover and was able to use the same gasket over and over between valve adjustments. The other thing is to make sure the valve cover sealing surface to straight and is not bent from over tightening. Dave W
To be on the safe side, I would mark the engine damper at the 34 or 35* that you want and checking the total advance at 4000 RPM with a timing light. I would also run the engine a little higher to verify that all the advance is in at the 4000 RPM. Dave W
I drove my Seven "once" on a section of un-plowed road with 3" of snow. Progress was only about 5 MPH at best. You are actually lower then any of the other vehicles that traveled on the road so you are pushing all of the snow in the center between the tracks. I think I would pass on the DD. Fair weather and dry, Dave W
Mike Time for a new Bosch cap and rotor on that cross flow. There are stock pile of cheap rotors floating around for the cross flow that cause nothing but problems. "black in color with type rivet design" Dave W
If you going to get the mount welded, go ahead and reinforce or gusset the area that is cracking at the same time you repair it. It not that much more effort once the mount is removed. Dave W
I do not think my car is close to 50 yrs old, but it might be a fun one day event to visit. It would be less then a 150 miles for me. I can't tell if the auto-x type track is open to all cars? Dave W
Also the rolling radius of the tires should be taken into account. I would put the trans in high gear, and turn the engine over by hand [5 or 10 rev] and count the tire revs. I would bet that you do not have a the typical over-drive top gear but a 1 to 1 ratio. Dave W
I,m using a 1974 shortern Sprite rack. Which gives me about 2.5 to 2.6 turns lock to lock. The rack travel is 1.78" per rev. As mentioned it all depends on the steering arms that you are using. Just figure that you need about 20* of turn angle for a road car, for the tie rod attachment point on the steering arm. Dave W
It appears from the photo that there is enough space that you could remove the center eye mounting brackets and re-position them much lower on each side of the diff, so you would get a raising rate suspension. Dave W
Josh Yup those engine rebuilds alway take 3 times longer then they should. Hope you got out last nite before the rain started. We should still have a few nice days before the frost-bite weather is here. Dave W
The selector could possible be out of adjustment or the dog slightly bent. There is a punger on each side of the trans trail stock located on each side of the shift lever. The selector shaft contacts these pins to resticts the travel to align the shift dogs. I would try adjusting the stop to see if it would help. If it does not help you may have to tear it down to inspect the shift fork shaft and the gear set. It might be easier to just find another trans if the adjustments does not work. Count the number of splines on the output shaft first. [20 or 22] so the drive shaft will mate up to the tranny. Dave W
Slomove I would try to find a lower rose joint with a larger 12mm I.D. and smaller threaded male end and just use a longer bolt and spacer on the shock. If you can not find the matching size, then you could use a female joint and install a two diameter stud with the correct threads on each end to connect to the bar. Dave W
Was out for almost three hours. Left a little after 8:00AM and 48* outside, return just before 11:00 and it was up to 61* out. Had the heater going the whole way. Very little traffic and sunny. When I got back I had to take the nose off and clean the dead sparrow out of the grill and rad. Dave W
I would suggest that you put a little RTV on the I.D. of the cap, before installing it. I had a cap blow off from a back fire. Since adding the RTV, I have not had any problems. Dave W
Ditto on Valvoline racing VR1 20/50, if your engine has an aftermarket cam. Made sure the oil being used has the ZDDP additives. Also most of the oils with a diesel rating will have ZDDP. Dave W
Love the DUCK, When he is driving are you straped to the rear rack? Dave W
Try Kinetics just $38 per LH/RH lite, in parts section http://www.kineticvehicles.com/ Dave
I just added a couple small brackets under the roll-bar mounting bolts, so I could attach a cargo net on the rear deck. But you are limited to how high you can stack bags without messing up your rear mirror slight line. Dave W
