Dave W
Everything posted by Dave W
  1. Reducing Buffeting in a Seven I have experimented with reducing wind buffeting on my Locost for several years now. The high vacuum “ low-pressure area” behind the front windshield is worst then if you are on a bike at the same relative road speed. I have tried several approaches to reduce the buffeting. Some worked, others did not, I have no way of measuring buffeting but these are my general findings for the various modifications. Winglets will reduce buffeting around 10 to 15% depending on size. The attachment should allow some air to pass between the screen and the winglet. Laying back the front windshield an addition 5* reduced buffeting by about 10%. It helped mostly at lower speeds and no change at higher speeds. A solid Plexiglas wind screen behind the seats, attached across the full width of the roll bar and at head height did not help. I also experimented with cutting down the screen with a gap on the top, gap at the bottom, and both top and bottom gaps to allow some air to fill the low-pressure air behind the windshield. Using solid Plexiglas did not help, It actually made it worst. Side doors, without the top. My doors are a lot longer then most. They run from the front of the windshield all the way to the roll bar. They reduce buffeting a good 40 to 50% when compared to an open cockpit. A Bikini top, you still have high vacuum area, but a high percentage of the air flow is behind your head. It reduced buffeting in the 30 to 40% range. Fixed sun visors that help defect the wind up over the top of the cockpit did help about 10%, but the visors probably need to 6 to 8” wide. My visors are only 4 ¼” wide, and worked the best when set about 20* from horizontal. Make up air, I have a defroster, and a 5 speed heater fan, but I can not feel any difference in buffeting with the system running. I would venture to say that it would take a lot more air volume then a typical heater fan could put out. For the 5% of the Sevens that use bikini tops, I just installed a rear window that attached across the full width of the roll bar just a couple inches behind your head. The car was tested with Winglets and a bikini top installed. With a full width windscreen i.e. rear window, installed it increased the wind buffeting.” This is without doors” and the results where basically the same that I had with a solid wind screen tested without the top installed. But with the bikini top installed the air flow is back and forth alternating from the left side to the right side. Air flow was verified by using a single turf hanging from the roof bow. I design the rear window with center sliding section this allowed me to adjust the center opening. Adjusting the rear opening 1 or 2 inches wide in the center section had almost no effect on the buffeting. I next tested the windscreen with about 20 to 25% of the total rear window area opened in the center section to allow air to suck out into the low-pressure area behind the windscreen. A moderate 20-25% area opening actually reduces the total wind buffeting probably in the 10 to 15% range Vs a completely open rear area. It was more effective the higher the speeds. It was tested to 100+ mph and it prove to be even more effective at reducing the buffeting at those speeds when compared to a completely open rear area. Using an opening in the center area of the rear wind screen appears to work much better then trimming off the top and bottom of the full width Plexiglas windscreen and warrants further testing without a top installed or the used of an open mesh type wind screen which allows air flow. Your results may vary; Dave W If anyone would like pictures just drop a PM to me.
  2. Martin I think it might be wise to extend that skid plate pass the front edge of the bell housing, after looking at your photo. The extra wt would probably be worth the piece of mind. Dave W
  3. YUP I live in Michigan were the state bird is the "COLD PATCH". We have pot holes big enough to swallow a seven, and it will take them three weeks to find you! I've broken my rear exhaust hanger four times, the exhaust is the lowest point on the car. Luckly I have a sump skid plate and this year an unbreakable exhaust hanger "I hope". Dave W
  4. Clubmen of Michigan The Spring Blat on May 16th is a GO. Arrival time for coffee is between 10:00-10:30AM at the Ann Arbor Zeeb road Big Boy restaurant off of I-94. The weather gods predict a sunny but cool morning for the start of the Sunday blat. The projected low for the morning is 50* with a high of 69* and 0% for rain. We will leave a little after 10:30AM. We will make a gas stop before heading North on the Blat. A little less then half way into the run we will stop at a road side park for a pit stop. We plan on stopping for lunch about ¾ Qtrs of the way into the blat. See ya there Dave W
  5. Alan Any auto parts store can show you 10 to 15 pages of these switches. You just need to know the temp you want and if the switch is normally open or closed. I would take the old switch with you, so you can compare the wiring connector. But it is easy to change to either a spade or stud connector. Dave W
  6. You can buy a gallon of acetone for less and it will clean the black aluminum oxide off the surface in a flash. just used good rubber gloves and be careful not to get it on other surfaces. Dave W
  7. “Clubmen of Michigan Spring Blat” The Spring Blat will be on Sunday May 16th. The blat will orientate west of Ann Arbor and South-East of Dexter. We will meet just off of I-94 at exit No. 169 “Zeeb Road” which is about 2 miles west of the M-14 and I-94 junction. The rendezvous point is the Big Boy restaurant, located at 497 North Zeeb road, 48103. [734-213-8200] Arrival time is between 10:00 and 10:30 AM. Take the North Zeeb road exit off of I-94, the restaurant is a ¼ mile north of the exit. A little after 10:30AM we will finish off the coffee, then stop next door for gas before heading north on Zeeb road. We will head towards Dexter and then to Pontiac trail. The Blat will make a western loop towards Hell Michigan and then down to the Waterloo Rec-area. Actual road time should be about two hours and 85 miles. We will make a pit stop 38 miles into the blat so the BECs can top off if they’re carrying a spare gas can. The spring route will consist of about 60% new roads, with the rest being the 09 fall route. About 3/4 of the way through the blat we will stop for Lunch in Chelsea at the Las Fuente 350 N. Main, 48118. [734-475-6092] I’ll supply turn by turn route tickets. I’ve pre-run the route and have flagged the turns [LH or RH] that do not have road signs at the intersection. Warning: Ann Arbor is 6th in the USA for speed traps if you plan to come through Ann Arbor or across on Jackson road. Dave W If you expect to attend, please send me your E-mail address or a phone number in case we have to go with a rain date. If we go with an alternate rain date, it will be post around noon time on Friday the 14th. Dave.whitt@Metalsa.com
  8. That's just the plastic pieces in the pick up, I bet you find a lot more in a complete stripe down. Any idea what it is from? Dave W
  9. Thank you Nathan, You dates choices are noted, I plan to give everyone severals weeks before the final selection is set. Dave W
  10. “Clubmen of Michigan” I’m in the planning stage of organizing some more blats in southern Michigan. At this point I’m looking at these 2010 tentative spring, summer, and fall rallies dates. But this year I would also like to start at different locations across South-central Michigan so we have a little different mix of roads. Please PM me if you have weekend preferences for any of the dates posted below and if a Saturday or Sunday works best for you. We are looking at a later start time around 10:30 in the morning, it seemed to work much better last fall, because it makes it easier to reach the departure location plus it’s warmer. Actual Blat time is just over two hours, not counting, the stop for lunch or gas/pit stops. Tentative locations and dates Spring: Ann Arbor-Dexter, . . May 15-16th or May 22-23rd Summer: Howell, . . . . . July 17-18th or July 24-25th Fall: Mason, . . . . . Sept. 25-26th or Oct. 2-3rd Please let me know your preferences. I’m open to any and all suggestions, plus if you know of any local conflicting race or rally dates, please contact me through the forum or E-mail. Thanx Dave W dave.whitt@dana.com dave.whitt@metalsa.com
  11. I replied directly to you before I looked on the forum. This explains the design. It's a tray type. That should work pretty good. Thanx for the picture Dave
  12. A PM has been sent, I could not find any pictures of the baffle/sump design the link. http://www.abperformance.co.uk Dave W
  13. Josh Before you put in the baffles, get a section of piano hinge. Then add a few holes to the bottom of the baffles, then screw the hinge over them so it allow the oil to flow towards the oil pick-up screen while cornering. You do not want to do this again. could get a little $$$ Dave W
  14. The Blating weather is just around the corner Spaz. It's time to start the motor swap. I just shoveled all the piled up snow in front of the Seven's garage door for 2 hours. The temp is suppose to hit 45* in southern Michigan this Sunday. I plan on cleaning a lot of dirt and mud of the car late sunday afternoon. Dave W
  15. Dave W
    The Hydrant
    Sent the link to Dave Watkins. I'm sure he will enjoy it. Dave W
  16. I would question "The Camber Tire superior in-line stability". The stabiltiy issue is probably not an issue on the race track, but on the road with a light Wt car, it is highly likely to cause the vehicle to pull to one side unless the tires are prefectly matched side to side in pairs. I spent two weeks in the britter cold tracking down a suspension design problem, that ended up being a cambered tire miss-match. On the track probably OK, on a light Wt Seven, I would wait until someone else can prove that the camber thrust is not a issue or they can control tire profile that good, before I would put my money down . Dave W
  17. I gave up on polishing the fender spats after 3,000 miles. It was impossible to get them to shine. I then used a 220 flap wheel on the surface in a vertical pattern so they have an etch type surface. They now get cleaned with steel wool and bug-tar remover/polish. Only takes a minute or two to get them clean. The bottom inch of fender is cover with bedliner which has to be touched up on a regular bases. I just added some short mud flaps last year which did cut down the sand blast affect by about 50%. Dave W
  18. Santa left a new flywheel under the tree, so I'm out in the garage every nite this week until 9 or 10:00. I Just add another layer. If I'm lucky I can open the garage door this weekend and let some of the 21* warm air in, while I'm droping in the motor/trans. This is perfect weather you do not even have to hold the wrench, it just sticks to your paw. But it is a pain when your air tools ice up and will not work. Dave W
  19. I just used 5/8" contruction foam glued to the tunnel, foot wells and sides. Probably less then $10, and less then 2 lbs. No heat problems at all. besides adding insulation, make sure you are getting the heat out of the engine bay. Dave W
  20. I would try higher shock setting. I have GAZ shocks with 160lbs springs on the rear. I'm running 12 clicks on the rear, or a little above middle way in damping range. Dave W
  21. The Fall Rally on Oct. 10th is a GO. The MSN weather gods now predict sunny but cool weather for both days of the weekend. The rally arrival time is being moved a little later to 10:00AM because the projected low temp for the day is a coolish 36* with a high of 57* in the afternoon and 00000% rain. We will leave a little after 10:30AM. We will be stopping for gas before heading out of town. About 30 miles into the blat we will stop at a road side park for a pit stop and to top off the fuel tanks for the BEC Sevens carrying a spare gas can. Plan on stopping for lunch around noon. See ya there Dave W
  22. Rally up-date for October 10th Arrival time at the Big Boy restaurant in Mason is between 9:30 and 10:00 for coffee and route tickets. A little after 10:00 AM we will start the blat down route 36. We will stop for gas in Mason before we head out to Dexter trail. About mid-way through the run, we plan on stopping for lunch at Curleys near Grass Lake. Lunch break at noon: Curley’s Pub & Grill 12227 Seymour Rd Grass Lake, Mi 517-522-3500 Actual road distant has been reduced by about a 1/3rd compared to the summer route. The Projected weather forecast has a morning temp of 47, and an afternoon high of 55. The kicker is the 70 to 80% rain, for both October 10th and on the 11th rain date. The rain is also projected into the early part of the week with no clear weather breaks in front or behind the weekend. If this weather pattern continues there’s a high probability that the rally will be Cancelled. If we go with the Rain date or cancellation, I will post the change on this web site by noonish on Oct. 9th. Fair weather Dave W Dave.whitt@dana.com
  23. “Clubmen of Michigan Fall Rally” The Fall Rally will be on October 10th “Saturday” starting in Mason Michigan, 48854. We will meet again at Bob’s Big Boy restaurant, 660 North Cedar Street [517-676-4401] but we will have a little later arrival time, approximately 9:30AM. The restaurant is located just off of route 127 which runs south out of Lansing Michigan. You will want to get off at the Mason exit number 66 for route M-36. The restaurant is about a ½ mile south of the exit. A little after 10:00AM we will finish off the last cup of coffee and either add or subtract layers of clothing for a hopefully dry 35-60 degree temperature. We’ll start the blat down route 36, stopping for gas before we head to Dexter trail making a big S.E. loop down through the Waterloo Rec-Area. Actual road time should be about two and half hours. The route will consist of about 50% of the summer route with the other half being new roads. We will keep the best roads from the summer run and add some better roads for fall. Rain date is October 11th “Sunday”. If we opt for the rain date I will posted the notice by noonish on the October 9th, on this web site. I’ll supply turn by turn road list and will pre-run the route, plus flag the turns that do not have road signs. Dave W Dave.whitt@dana.com
  24. We are looking at another rally either the first or second weekend of October. It would probably start in Mason Michigan again. Please PM me by next Monday if you have a preference for the 1st or 2nd weekend of Oct. Thanx Dave W
  25. Dave Watkins' wife, "Jan" took a few pictures at Big Boys, I'll see if we can get them posted. The other Dave W
