I have a very early pre-lit Westfield with the Sprite/Midget running gear. I am 6’ and around 190# and I fit well into the drivers seat.
My car uses the front suspension uprights, hubs and brakes, steering rack, engine, gearbox, prop shaft, and rear axle assembly.
The mechanical parts are available since they come from a car with a suspension and running gear that was mostly unchanged for a dozen or more years. Engine parts are readily available and other than a lawnmower it couldn’t be simpler to work on. I would recommend the Midget section of mgexp.com for information and resources on the running gear.
The only drawback is the transmission’s lack of synchros on the first gear — selecting it should only be done while stopped. However, the A-Series is a long-stroke engine and produces enough torque at the lower end of the rev range that is really isn’t a problem. Just be aware of it the first time you drive the car.
