Lotusfan
Everything posted by Lotusfan
Caterham badge wanted/LOTUS badge offered
Lotusfan replied to jordway's topic in Parts For Sale / Wanted
@jordwayhere’s a pic of the new style Caterham badge. I forgot that there are locating pins on the back. and @TMRL7 here’s the Lotus badge -
@TMRL7I have a Lotus badge, new in the box from Lotus, that I would swap for yours. I’d love it for my car. @jordway I also have a new style Caterham black plastic badge for you if you’re interested. I’ll post a pic later. -
@SourceI have a very similar car to yours. The original owner actually ordered the kit from Caterham to install the bell housing dry sump, but never installed it. I have it, new in a box. Someone was kind enough to email me an installation document and this may help you with your system. Here you go... Vauxhall Dry Sump System_master.doc
Lotusfan replied to slngsht's topic in General Sevens Discussion
@The FuselageYes, please do share your VT loop route. My son went to UVM and we just love the area. Best beer ever! -
@cmoist Thanks for posting the file and for the sendcutsend recommendation. I'm sure that I'll use them for something, if not an emblem. What thickness do you recommend for the emblem in stainless?
Curious, where did it end up going to?
Congrats. Very sharp looking! The grille is a cool detail. -
Understand that everyone has their own reasons, best of luck with the sale. I’d suggest that you put it back on BAT. I suspect that you’ll get every penny you have into it back and will have had a pile of good stories and fun for free.
The trick is figuring out a new ECU that will work with the current crank position sensor and trigger wheel. You can mount another trigger wheel and sensor but it's more work and some fabrication. Please post what you end up doing.
Forgot to add, while the tillets are "adjustable", in practicality they really aren't. Doing it over, I wouldn't bother with the rails.
The problem with the bench type of seats is that there is nothing between your head and the rollbar. Consider carefully how a stupid driver at a stop light could easily make a head crash into a roll bar. Race type roll bar padding is meant to protect with a helmut on and while it's better than nothing, this is really something to consider, as well as whiplash. Switch out the bench or attach something to the roll bar to act as a head rest/support. (And plan on the job taking A LOT MORE time and involving A LOT more cursing than you thought possible).
Proposal for a new 2021 Sevens HPDE in SC - Gauging interest
Lotusfan replied to Croc's topic in National Events
Uncertain but intrigued. -
Count me in Ross. For those of you who aren't familiar with Ross, he and his cross country trips are the real deal and if he's supporting the Roundup River Ranch, that's good enough for me. 11,500 miles - OMG! Ken
So my wife has a 2018 XC60. Great car. The advanced cruise and lane departure features really do make long distance highway cruises less fatiguing, but while all of these features are great now, I wonder if they are going to leave the vehicle impossible to keep in 10 years when they start to fail and are just too expensive to repair. I can see failure of these systems leaving the car dead. 10+ years ago options like air suspension and xenon headlights were nice to have, if you still have that car now they are liabilities as they fail and are expensive to repair. All of the auto-violet stuff, likely even more expensive and unrealistic to repair. I guess I'm just too cheap to consider $50K+ vehicles disposable.
2009 Volvo XC70 T6. Rides and handles well. Tons of space. Fancy option gadgets are starting to fail now which are annoying. Next time going for simple, but I'm guessing that is no longer really possible.
Yoram, Congrats on your choice - Sounds great. I have no actual experience, but the UK based Lotus Seven Club forum is filled up with posts on the virtue of half hoods from Soft Bits for Sevens and Oxted. These can be had with zips overhead which makes getting in and out with them on easier. Getting in and out with the full hood on is comical for just about anyone who isn't a 100 lb gymnast. My guess is that they know a bit about rain in the UK, so this might be something to think about, perhaps deleting the full hood. Back to Volvo wagons for a min - did you replace xenons with the non-xenons? I'd love to do that so that I could get back use of my clock, miles to empty, etc which are all covered by the headlight failure warning thrown by my xenons which light but don't steer any longer.
Congrats on the choice! A side benefit of the S3 is the inspiration to not gain weight! Yoruma nd Vovchandr - Very cool that you are into Volvo wagons. I have a 2009 XC70 (our third) with 150K on it and there is just no reasonable replacement available. It needs some relatively expensive things (accessory belt, xenon headlights that work but throw a fault code, and rear hatch struts, tires) that don't really make sense but how else could I spend a few thousand and get anything close to take me to the next 50K miles?
I think I would try to fill the crack with glue by expanding it with the screw, then remove the screw and put a small clamp on it. If that doesn't hold, fill the holes with epoxy, then drill small pilot holes and use smaller screws with washers to fasten the lenses. Only costs a bit of time and glue to see if it works.
The other factor to consider that has not been mentioned is what seats are in the car. The original owner/builder of my car spec'ed that the seats be the old style bottom and bench back as he was tall and fit better in those, pulling out the bottom and fitting a formed bag for racing/track. When I got the car I put Tillet's in. Tillet's are definitely a more narrow fit and how wide you are (shoulders s well as hips) makes a difference. I'm 5'11, wear a large/XL shirt, and when I topped 190lbs it was definitely time to lose weight as the fit was getting tight in my S3.
I believe it is triggering off of a 60 -2 tooth wheel, but I was not able to find or figure out what the position of the sensor is at TDC to use the output to trigger a different ecu (in my case an electromotive wasted spark system). If you find out more in this regard I would be very interested.
Going coast to coast without a clue
Lotusfan replied to SanderGA's topic in General Sevens Discussion
I'm curious, what tools are you carrying with you? -
Glad you're all set! Safe travels. What an epic way to get to know your HPC! -
Here’s a pic of my clutch pedal stop as well as the cable end. Have you checked where the arm is when the clutch is fully depressed? Is it’s travel limited by the hole in the bellhousing?
