CarlB
Everything posted by CarlB
  1. I found this on the internet but can't find much on the Portuguese company trading a NOVA Motorsports. " Goodyear executives have confirmed that Turbalvoroco Unipessoal LDA, trading as Nova Motorsport (Nova), will buy “certain assets used in the manufacturing and sale of” Avon-branded motorsport tyres. Nova has also acquired “the brand license, traditionally used in the manufacturing and sale of certain motorsport tyres under the names ‘Avon Motorsport’ and ‘Avon Racing’”. Tyres & Accessories understands that Nova plans to continue the production of some of the Avon Motorsport product range independently from Goodyear."
  2. This forum is very important to me. Membership is a small price to pay for all the benefits. Thank you JohnCh & Croc
  3. What do you feel when driving that conveys control or fun? For me I love the in-your-face direct feel of a Caterham. I love the sensation of being close to the rear axle that is nothing more than a sophisticated solid axle. I used to race go-karts and they are driven off the rear axle I love the feel conveyed from the De Dion axle, it is like a go-kart with more power so you can change the handling balance with your right foot. I get the part about bumpy roads. There are limitations. An independent rear suspension would be better over bumps, but the car would feel different.
  4. Evans waterless cool is Propylene glycol. Regular anti-freeze is ethylene glycol. It might have a surfactant in it to break the surface tension, but the real point as Croc pointed out is the high boiling point. It does not have the heat transfer rate of water, and the coolant temperature will be higher, but because of the high boiling point the system will not run under pressure. one of the unique applications of it was in high performance engines with localized cooling issues. Water would boil in the engine water jacket in a localized spot. An example might be around the exhaust valve, and then condense back to liquid. The result could be detonation. In the 1980s the guy who started this company and the reverse cooling idea got money from GM to work on it, and Chevy built a production engine with reverse cooling for a few years.
  5. https://www.youtube.com/watch?v=bIdri2LZMZs What are the little piles of dirt around the curves in the track? Is it just the dirt removed for the curbs, or something else?
  6. Here are two shots of my car. One is an autocross with a locked brake, and the other is a Dominion raceway in Fredericksburg VA.
  7. I am looking forward to being there. Really missed not being able to have the event last year and seeing everyone.
  8. You are using the same technics I typically use with one exception. When I get the part hot, I have found using candle wax helpful. Hope it works for you.
  9. Len Terry might not have gotten a chance to build this suspension system, but he did design the 1965 Indy 500 winning Lotus with Jim Clark driving.
  10. I haven't modeled the Mumforf link either, but it looks like the roll center is fixed to the two bolts on the car. The two bell cranks allow the differential to roll but not move laterally. It would be very interesting to have a suspension design that allowed equal lateral roll center movement towards the inside of a turn.
  11. You are correct, I do not have a O2 sensor or a catalytic converter. If you have one O2 sensor before the cat you can just put the sensor in the new pipe. If you have two sensors you will need to have a tuner turn off the second O2 sensor in the ECU.
  12. Here is my exhaust. I have a very similar car to yours. From the header flange it has a 2 1/2-inch pipe to a 4-inch MagnaFlow muffler part 10416. It exits in front of the tire and has a turn down to help with the noise. You do not want the exhaust pointed straight if you use it on a racetrack. They have sound meters and pointing at the sound meter will set it off. I had the original muffler cover and I cut it down to fit the new muffler and painted everything black. Sorry my car is apart, and this is the only picture I have of the exhaust.
  13. I have a Raceline cast wet sump pan and a very simple skid plate. It works great. I have gone off at several racetracks and never had a problem. The plate just rides up over. it is held on by radiator clamps. I got it that way and haven't bothered to install tabs to bolt it on. Crude and effective.
  14. Does anyone know if Caterham has a replacement for the Avon tires?
  15. I got mine. The picture isn't great. It is brighter than the picture.
  16. Thank you -The 60s are a long time ago. I should have done a little research before asking a question. Thank you for these post. I think we have all enjoyed experiencing your adventures.
  17. There is a magical sound to a V-12 engine. F-1 or production car through mufflers, they all sound great. I was lucky enough to be around group 44 a lot, and there V-12 cars were very load and made music. A question for Croc. Is the Tony Rolt mentioned about the C type jag the same Tony Rolt who ran BRM in the 60s?
  18. They do make thermostats for oil systems. If you do not know the temperature of the oil, why do you want to add a cooler? If you run synthetic oil 240 degrees is just fine. A cooler is just more weight and complication. Oil lines are points of failure. If you are overheating an oil cooler will reduce the water temperature, but you want the oil temperature about 220 to get the water out.
  19. Thank you - I had looked but it didn't show up. Got one coming now.
  20. Where did the key chain come from?
  21. A lot of race cars use push lock fittings. I agree Oetiker should be added.
  22. 7 or 8 inches seems a lot. You might look and see if Lotus used a different engine, and the frames were made for both engines.
  23. Ford did re-cast the Kent blocks. I think they have done it several times and there have been periods they were not available. F/F in the UK is going back to the Kent engine and Honda is not supporting the Fit engine that was used in these cars. A Kent powered car won at this year's run offs. You can get the BDG (2.0) block, but it is very expensive. There are companies that are making heads and blocks for the BD Cosworth engines.
  24. The Ford T-9 transmission should use API GL-4 oil. Do not use GL-5, it is too slippery and the synchronizers will not work as well. You will probably find oil that meets GL-4 and GL-5. Do not use that. Use oil that meets GL-4. I use Red Line. It is expensive but it works.
