Vovchandr
  1. I meant OEM pricing for the same units. Surely better than halogen no matter what LED
  2. Good info. Website doesn't have pricing. How does it compare to OEM? I've been driving with the knock offs for years now and for how limited my night driving is, it's certainly good enough. I probably have 100 miles where I don't have headlight covers on my car total.
  3. If this Duratecs? Coil is similar to Zetecs it's also wasted spark coil so you it's less likely to get wrong once you wire it up too
  4. Are you willing to entertain a trade on a a certain bike? There is a local with some high end bikes for sale who's looking for a Caterham. One of them is SB8k. Unlikely that this matches up but can't hurt to connect the two.
  5. Semantics but I believe you meant Z06
  6. RIP. The butt extractor is legendary. If I recall he also had a scaled down 7 for kids
  7. Google images was backing up what the guys above said
  8. Your wheel offset should be stamped on your wheels. Depending on the width and face style your et can vary for the same car. Csr never had its own made wheel with proper stamped. They machined down existing wheels so their etc is calculated and not stamped. I believe my information in posts above is correct.
  9. For what its worth I'm happy with multiple SoftBits orders but in regards to ordering anything ever for Cats from overseas almost nobody is ever very responsive although I've had good luck. Just a warning, there's no "shortcut" to a great supplier of anything, you just chose the one you want and be willing to wait and deal.
  10. Stamp reads 2811. I purchased these around 2020 if I recall. They were in California before and basement stable temp through my ownership.
  11. Don't know if its a direct bolt in to your build but I've been using this Antigravity Lithium battery and been very happy with it. I think they come in bigger sizes for an easier fit too https://www.amazon.com/gp/product/B079TZ19BZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  12. Vovchandr
    Noted. Mea culpa. I'll ask for some in the future, especially if you have a time In future that works better for you and not in busy time.
  13. Vovchandr
    Is there a chance for higher quality of these pictures? Most appear extremely grainy and small in size the second you make them big or try to zoom. The compression edit on these put them at about 500kb or less. Events prior were uploaded at about 5 megabites per file making it nice for full screen monitor backgrounds etc.
  14. I read that again "from a different angle" and understood what you said now. Gotcha.
  15. What do you mean by that. You want one with solid rear? Those never came with Duratecs or SVs.
  16. Stranger things have happened. More info is needed Is the owner responsive? Do the pictures look real? Did it have a Kentucky plate? Is he asking you to send money? A real person will have no problem proving they moved with just a few pictures of plates or something if they wanted a sale.
  17. I'm confused by your comment that it's a snap on cap like a washer fluid. Can you provide a picture? Most caterhams to the best of my knowledge use a pressured tank with threads for a pressure release cap and not an overflow snap cap but I'm curious to see what you have
  18. I've also ordered one for a mini on Amazon when really needed one
  19. Pictures can certainly help. Please post
  20. Im not coming an area of knowledge but it almost felt like the timing was off? The engine really didn't want to be running and I could keep forcing it by restarting it when it died. During one of the startups it backfired very loud that my better half came out of the house to see if I was Ok, so I took pictures of your setup and uploaded mine back. I can try again at a different date to maybe mess with further tuning you described above. With that said if my car is happy with my map I can stay on it and just use the differences as a guide as to what values to adjust and in which direction.
  21. Quick shot from today's Bday quick trip and thank you for @wemtd for stopping by to the humble abode and the gift. It's nice to see friendly faces outside of the stressful track days.
  22. Also troubleshoot my troubled map a little more Still no data log. Barely had time to test the @catsv7 gave me and adjustments @NSXguy suggested I do to the fuel map table. Acting like a blind squirrel looking for nuts I was able to throw some numbers into the tables that seemed to fix that part throttle flat spot/stumble/misfire I had. I only did a quick test @catsv7 car didn't really start well with your profile and map and shot a major fireball upon one of startups. Barely ran. I took screenshots and compared data between our setups. They are different but aren't night and day so not quite sure why it acted so bad.
  23. A few updates Discovered a strange bump in my hood with cracked paint and found the root issue..
