Everything posted by SENC
Beautiful Seven! Are you bringing it to the Lotus Owner's Group meeting in West Virginia in September?
Different, but in case it helps the pre-crossflows did not utilize a t-stat. When I got mine a prior owner had installed one at the swirlpot inlet, presumably to quicken warmup. I was noticing some borderline overheating and checked then changed the t-stat (drilling the new one) with limited impact, so ultimately just removed it since its real purposes is keeping temps above a certain level, not below any level. Doing so did seem to reduce/eliminate spikes, though, presumably just because all restriction was removed and the system flowing as intended. I just have to be a bit more patient warming it up. Even in hot weather and in town, I don't see temp rises approaching a worry point.
SENC replied to Croc's topic in Cars For Sale
https://www.ebay.com/itm/144655852811?mkevt=1&mkpid=0&emsid=e11021.m43.l3160&mkcid=7&ch=osgood&euid=e6bfc1d9dcbb4bf393e738759589e25b&bu=44278349486&ut=RU&osub=-1~1&crd=20220723015151&segname=11021 Must be summer Seven cleanout week! -
...and Fisker takes the lead!
Your car, you do whatever you'd like and enjoy it! Who cares a wit what someone else thinks, but as far as I'm concerned all these cars are offshoots of Lotus (legitimate and bastard alike) and I think it is great when they tip the cap to Lotus in some way. I think it only goes too far when someone tries to sell a car as a Lotus inappropriately. My 2 cents.
Congratulations! Jacob Engineering make high quality steering wheel repros. https://jacobengineering.co.uk/index.php/steering-wheels-2/ RD Enterprises or Dave Bean are US sources for motor mounts - I'd recommend the heavy duty version. They may have other items as well, but for whatever they don't have Chris Mintoff at Redline, Mick Beveridge at xtraspecialsevens, and Tony Ingram at lotus7.com are leading suppliers.
Croc - I'm fairly certain this is an old/stale listing that LOONY just hasnt taken down. If I'm not mistaken, this is the Seven @sportscarnut acquired a couple years ago. -
I can grab a real measurement tomorrow if you need one, but I believe full chassis length will be just shy of 10'. Regardless, I think you could fit it. Heck you could take a pickup truck and get everything in the bed and just strap the chassis down to the top of the tailgate and top of the cab! Plenty have transported a bare chassis just on a roof rack!
This is the engine going back into my 65, I'd guess the necessary angle would be similar for yours. On thes older ones, the front brake lines run along the top chassis crossmember, and need protecting as the engine makes a close pass and can easily swing and damage. I use a piece of rubber hose spilt longways, or pipe insulation, to wrap around it.
Thanks MV8! I'm definitely going to drive it a bit more before pulling it, so will see if I can duplicate the symptom well after a shift, good recommendation. Re oil on the cam cover, I'm pretty certain now it was splash rather than pressure/spray. The piece of tin I fit into the filler neck to block a direct line from the filler hole to the underside of the cap has prevented any further leaking through the cap. I have not yet refitted a road draft tube to the breather tube in the block (the breather tube I have is not a great fit for the road draft tube connector), but it seems to be breathing OK even without that bit of venturi pull.
Finally got tools and cars relocated in a new storage and "toy shop" space a friend and I have taken, so can get back to tuning and tweaking on the Seven (and back to valve and shim dx on the Elan) - but one step forward and another back... Took the Seven for a bit of a drive yesterday to reset my thoughts on how it is running, and though the engine is running pretty well I had a clutch slip when shifting to 4th at high revs from 3rd. Was able to replicate and identify the slip is only at higher revs, >4k or so. As it is a new (old stock) clutch disk and pressure plate, I'm thinking I either have some oil/grease contaminating it or that the release bearing is bad. You may recall that, upon getting it back on the road, I had some bearing noise upon full clutch depression that stopped after a hundred miles or so. As it was a NOS bearing, I had hopes that old, dried bearing grease had just needed to warm and soften, but I'm questioning that now. Either way, I suspect I'll need to oull the engine again to fully diagnose, though I may try to look around with a boroscope to see if anything obvious sticks out. I'd welcome any other thoughts.
Sean's post reminded me of a what the original owner of my Seven shared with me. Her husband bought and had it built in 65, not long before their first child. A couple years later they drove it through Norway and Germany (in a snowstorm) with the little one (and her pregnant, as I recall) and were headed south towards Greece when one of them became sick so they cut through France and back to the UK. In 68 they moved to Australia, taking the Seven with them. Hubby drove the sedan for work, so for a year before selling it she would drive the Seven with the 2 boys (4-5 and 2-3) sharing the front seat and newborn daughter in a bassinet she'd put in the back. It didn't have any seat belts, nor does it now. Different times, places, and risks than today for sure - a bit like how most of us grew up in the back reverse facing seat of a Custom Cruiser, or in the middle of the front bench seat of a pickup.
https://bringatrailer.com/listing/2001-caterham-superlite-3/ This one is in Wilmington. I don't know the car, but if anyone comes to town to look at it drop me a note and perhaps we can connect. -
Keep me posted, please. I'm taking mine to WVa for the Lotus Owners Group gathering in September and then have a S Texas trip in early October so might be more than I can pull off, but would love to join if I can. Henry (Wilmington NC)
https://bringatrailer.com/listing/1962-lotus-super-seven-4/ -
New detent springs are readily available if needed, but you can also shim them with small washers. The goal is to have the spring top extend 8.5-9.5mm above the face of the lid (iirc).
The release bearings are available from the major Lotus suppliers (RD Enterprises and Dave Bean in the US, Kelvedon, SJSportscars, TTR, Sue Miller in the UK). I suspect yours is the flat faced bearing, but that depends on the clutch housing and may require the round faced bearing. I don't think you'll know that for sure until you get into the bellhousing and see what you have currently (you may be able to get a boroscope into the clutch release arm hole in the belhousing to id the bearing and clutch housing type). Following are the original part numbers for the flat faced bearing in case you can find some old stock anywhere - some of the new chinese repros didn't last long for others, as a warning. Original Manufacturer Number Ford 105E7580 Ford 105E7580B RHP 6W 1 3/8 FAG 508458 Timken 1375 FKC 6W 1 3/8 SKF 408504
Here is the link to the first disassembly video - did that in 4 parts, and a couple for reassembly. You should find them after finding this one.
It looks like the standard gearbox (2000e series) from the Cortina and Elan. These are pretty simple to work on but requires engine and gearbox out to work on and rebuild. I've rebuilt 2 in the last couple of years (with limited previous experience, so not difficult). I uploaded some videos to YouTube of my first one, disassembly and reassembly - will try to find the links and post them, but you may be able to search for Elan gearbox and find them. The lotuselan.net website has a wealth of information on these, and I have some threads there on my rebuild, too. Another participant there, "promotor", is extremely knowledgeable and helpful - would recommend you join and post questions there, too. To your specific problem, if you can get to the shifter in your tunnel, one thing to be aware of is that the dome can be too tight (should be a small gasket between it and the mount) or too loose, either of which can cause selection problems. A dab of loctite can keep it from loosening. But if you need to replace the clutch release bearing it is probably a good idea to go ahead and take it all out and open things up for inspection and possible rebuild. PM me if you want to connect or need any help. Henry
Overseas orders, when are we liable for import duties?
SENC replied to Vovchandr's topic in General Sevens Discussion
It is typically the responsibility of the buyer to pay import duties... but I've rarely had any imposed unless a quite significant item. When I ship something the other way, I label it "parts for repai/refurbishment" to avoid such on the other end - I learned this when shipping a distributor for repair.
