KnifeySpoony
  1. Nice glad it's sorted. BTW what the heck was that red car at 2:05?
  2. My build was 2021. I am on the older ECU, I think it's the 9A4. I am black injectors, even though they sent me the green injectors with my roller barrel kit. My ECU is meant to run on the black injectors even with the roller barrels. My idle is between 1000-1100.
  3. Your DMV person definitely didn't understand what you were trying to do. What does it say on the reg/title re: model/year of car? I would be concerned if I was in your situation tbh. You may end up with a real problem when you get a smog notice if they think it's a model 2024 year car. At that point it's too late to reg as SPCNS afaik.
  4. My 420R on roller barrels is nothing like this. It pulls smoothly from idle and has immediate throttle response at any RPMs. Is your car a new/recent build? If so I would press your dealer/CC about it. Are you at altitude? I wonder if that could play a role as well. I would be very frustrated if I were you - if a warranty claim is not an option, I would consider going standalone ECU and having a pro tune it. Will be pricey and possibly inconvenient but at least the car will be right.
  5. By sticker do you mean the SB100 sticker, or just the reg sticker? In the past, the SB100 sticker came straight from the BAR inspector, not DMV. You def need the SB100 exemption or you will get a smog check notice (although not for 8 years).
  6. I did Alameda county sheriff, and BAR in Livermore and had good experiences.
  7. I'm optimistic for all you guys, but just a reminder that I didn't get my tariff charges until about a month after i received my items from caterham.
  8. I aligned by sight and thread counts and got very close on toe/camber. Here is the before numbers when I took it in for alignment.
  9. I mentioned in another thread, I just paid 37.5% on a set of new wheels sold and shipped by Caterham.
  10. I've taken a passenger many times and have no issue with my phone in current position. They just have to be cautious getting in/out. Once seated, it's not in their way. (then again I'm taking passengers for sessions on track, not long journeys)
  11. I wired an sae plug into the power for 12v socket under the dash. Very convenient. However i rarely use it because i just use the battery cutoff switch.
  12. I keep a rag zip tied over the cap but intermittently still get some drips or misting in the engine bay. Never enough to get out onto paintwork. The brake fluid seems to have no affect on the black paint/powdercoat underhood.
  13. Fwiw i have the race cap and still dealing with leak issues on and off.
  14. I can't help with your low idle. Mine idles at almost 1100rpm. If your motor is running fine and pulling at higher rpms, then I think your throttle blip thing is just a brief lean stumble and not a misfire. If i do a big but super brief throttle stab at idle, mine will stumble too.
  15. Interesting. No spacers on engine mounts on my 420 build.
  16. I also vote inertia switch.
  17. Hmmm no sound on videos for me.
  18. Test continuity of plug wires with a meter. I had one go bad.
  19. https://www.thedrive.com/news/33330/the-lightest-porsche-911-ever-is-full-of-holes
  20. Is it enough to drip on the floor? Or just on the top/back of the oil tank? With my car, it's just some oil on the rim of the tank opening and underside of cap/threads that gets blown out with airflow once underway. It doesn't keep leaking once it's been distributed.
  21. How much seepage? Just some mist around the cap and spray onto front of engine? It always does that no matter how much I wipe the threads and undersurface of cap. Once I wipe off the spray, it doesn't come back until I undo/replace the cap again.
  22. Don't underestimate the likelihood of this... Seems most people just hit and run these days too.
  23. I use Hagerty. But it's an agreed value, full coverage setup.
  24. Standard 13" sizes 185/215- I don't think they came in other sizes but I could be wrong
