KnifeySpoony
Glad you got it sorted. Hopefully the spring on the barrel wasn't strong enough to damage the TPS. You should check the idle voltage IMO. I would get set up to do that anyway, as I have seen the voltage drift and need adjusting, and had a TPS go bad.
It should pop off. And yes you want to remove the tps because when the barrels come off, they will rotate beyond their (and the tps's) normal rotation range.
I can try to take a pic/vid but I think with the trumpets/backing plate on will be hard to see anything (and they are annoying to take off/on, sorry). Given that you've already taken the trumpets off, I would just take the intakes off and see if each side is operating correctly on their own, and if so, reinstall them. The mechanism of each side has to interlock correctly (under tension which makes it challenging) during installation. Also have to make sure the gaskets don't dislodge from their grooves during installation. If the spring is still binding, then you may be correct that there is a flaw with the intake itself and may need replacing/fixing.
Dry sump oil tank drain plug leaking
KnifeySpoony replied to KnifeySpoony's topic in General Sevens Discussion
Fwiw my solution solved the leak and i never touched it again. Re:oil overflow, yeah i had to cut the tube inside the bottle much shorter as it was near the bottom of the tank. -
No need to take the intake off. Just make sure the open and close stops are properly set and working properly. Sounds like the WOT stop needs to be adjusted. Super simple. The tps adjustment is only for idle voltage. So hopefully that's ok. You can check with a multimeter.
100% not right, definitely don't drive it. Something is clearly interfering with the barrel or cable movement. If you're not comfortable working on the car, have your dealer look at it. If you are, I would disconnect the cable from the barrels- see if they open and close freely. The spring on the barrels is strong; when I let off the throttle, the barrels snap shut and the stop on the barrels bangs loudly against the stop screw. If the barrels move fine, then the issue is with the cable. It's possible something is assembled incorrectly, but can't tell from the video.
Track day roll bar- third brake light
KnifeySpoony replied to Xhilr8n's topic in General Sevens Discussion
I wouldn't use heat on the lens/LED. I would use floss or a plastic scraper. Keep in mind you're doing that not in between the alu base and the bar but between the alu base and the light unit. The alu base is screwed into the bar. -
FYI there is no factory CHMSL except on the EURO 5 cars I think. That brake light you have looks like the Beachman aftermarket one: https://www.beachmanracing.com/rollbar-mounted-light -
The 620r tank is not trunk mounted. It's still in the engine bay: https://caterhamcars.com/assets/RetailerHub/users/caterhamsilverstone/620R Roulette Green/19.jpg
Seems an odd/dumb design... Can you just change to more traditional dry sump tank layout? Pop in the nice triangular tank up front? Or the rear mounted 620 tank? Seems like it almost might be worth the faff.
Having read a bit about the CSR oil level issues, I still don't understand how the total oil amount in the system is so hard to determine. With the engine running, don't the scavenge pumps deplete the oil in the sump and fill the oil tank? I get that the bellhousing mounted tank is different than the tanks on 420R and 620R, but why doesn't the tank "fill" while the engine is running, which can then be checked in the tank? Is it a matter of the oil settling so quickly back into the sump out of the tank once the engine is shut off? Can the oil level in the tank be checked with the engine running (this can be done on my 420R btw)?
I've read mixed instructions on the internets - some say simultaneously push in the 3 little tabs. Other people say to push in the ring. I tried the later but was unsuccessful.
Pulled the fuel pump. Indeed there is no baffle that I can see. The float arm and completely detached from the pump and was loose in the tank - that's what was rattling around. I don't think I mentioned but the fuel gauge never reading full was another symptom that appeared on the last day I drove the care. My working theory was that the mythical detached baffle was preventing the float from rising fully... Anyway, I reattached it and put the pump back in. So back to square on the fuel starve. I suppose it could just be a product of more lateral grip. I also wonder if the pump could be slowly failing? Also related; how does one disconnect this fuel line? I struggled with it for a while, then just left it connected when I pulled the pump.
OK, i'm pretty sure the baffle in the tank has failed. I can hear something rattling around in the tank. New project awaits. Any chance of repairing a baffle in situ, or this just means new tank is going in?
Oh woops, missed that. I have never heard of those tires - looks like they need to be ordered from Europe in 13" sizes? Please report back on fitment and performance.
Looking forward to your AR1 report - I figure I will switch to these after my ZZR supply is used up (I have sets of A24, A64, and extreme). Definitely curious to hear about differences between running the 205 vs 235. Also surprised to hear they overheat within a few laps on such a light car. I figured the opposite would be the case (ie hard to get heat into).
Changing to a removable track steering wheel
looking proper racecar now -
OK it's working now. That looks like a lot of travel - obviously I can't test the total range on my car right now, but there is not a ton of travel in the master. Too me it looks like you're hitting bottom. You must have a massive amount of air somewhere in the system.
Video not working for me
Not sure, but if it's just still some air in the line, you should be able to "pump up" the system and get harder/higher pedal. If it's really no resistance, then hitting a brick wall, it sounds like bottoming out. Maybe 5cm is not enough though. I'm honestly not sure what my total travel is. Thinking about it, maybe it's more like 10cm.
Based on your description of the pedal, it sounds like you're not building any pressure in the system at all, and what you are feeling is the pedal/MC bottom out. I have found the brakes very easy to bleed on this car, so I wonder what is happening for you. If indeed you aren't building pressure, you would need to either have an opening in the system or a ton of air hiding somewhere. I'm not an expert on master cylinders, but some people tout the need to bench bleed masters. I don't know if something with the MC could cause your symptom or not.
Most trackday wall inspections I've seen (in person or on video) involve oversteer. Rarely do people just terminal understeer into a tire barrier. Any car, though especially a car like a 7 (with even weight distro front/rear), can be easily balanced to the driver's tastes with spring rates, ARBs, and tire widths. IMO ideally a good car with good setup allows it to be adjustable at any phase of a corner depending on my inputs.
