wdb
1 Follower
    Eastern PA
    1995 Caterham twincam live axle
  1. Hopefully you'll do a writeup describing the track. I'd love to hear how a Caterham feels in that bowl turn.
  2. Did you start at the back? Any of his luck rub off?
  3. Sent you a PM.
  4. I have 4 Vredstein 165/70R 13 Quatrac 5 tires I will be removing from wheels shortly. They were on my Lotus Elan; I have replaced them and don't need them. Late 2023 and early 2024 date codes. Almost zero miles, I'd put mileage around 100 or so -- really. I would rather see someone get some use out of them rather than hand them over to the tire people when they take them off the wheels, so I am open to any offer. I don't see shipping as being practical but I am willing to discuss meeting partway etc. for pickup. Someone please take them!
  5. This eliminated the bulk of the fuel smells in my garage; before I did this it was BAD bad. However Webers will still emit some fuel vapors so it did not get completely eliminated. If you really want to go the charcoal canister route try looking for systems for 60's muscle cars. Several of them out there.
  6. Can you post a link or part number? I just spent 10 minutes on their site and came up empty.
  7. Thanks for sharing the photos. That has to be a fantastic experience for both of you. And -- hey, that's my dry sump tank!
  8. Ditto the sims. All I do is run into stuff.
  9. Uhh my last post was about front brakes.
  10. I suppose it's possible to have a completely full master cylinder reservoir and thereby keep pressure in the system such that it would push the wheel cylinder pistons outward, but it's doubtful. Easy fix as well, just lower the level. A twist of the bleeder screw should produce a squirt of fluid if there is pressure in the system also. Absent anything like that, the return springs will press the pistons back into the cylinders when the pedal is released. I have worked on a ton of drum brakes over the years. I do not see an adjustment mechanism in that picture. I can imagine a cam of some sort behind the shoes, with a screw head stick out of the backing plate to allow adjustment, but I don't see anything like that in the picture.
  11. They look very much like the Weller Racing wheels that came with my Caterham. Steel wheels, very lightweight.
  12. A quick google search seems to say that Japan requires catalytic converters on virtually all vehicles. That might explain some of the added bits. Crossflows are used in Formula Ford and can be tuned out the wazoo. I believe parts are easily available from a variety of vendors. If it were mine I'd remove the catalytic converter and engine management foo, go through fuel system/brakes/tires/etc. to verify road worthiness, and take it for a drive. Then I'd decide if it needs more power.
