Everything posted by wemtd
This is fantastic news. You should drive her home over Boxing Day weekend
JB: I currently have the tall Birkin roll bar on my car if you want to test fit for size? caveat is Tillett driver seat with bespoke mounting bracket.
Where in CT are you located? pm me: there are actually quite a few of us in the region & we try to coordinate driving. re: gear ratio - you could try talking to John @ quantum dynamics by the Oxford airport (if he’s still there). If you can’t get him by phone it’s worth driving by. ps: welcome to se7en ownership. Also It’s a good habit to go-over everything with a torque wrench as driving tends to loosen things up. And you’ll learn where you need to focus attention.
Depending on the connector you can re-pin it. My Haltech ecu uses a Deutsch connector for O2 sensor. Sensor is standard Bosch unit. I replaced stock pins with a Deutsch connector.
Ooh🫣 looks like a Ford mondeo annular cylinder (need to check my notes) not available in parts stores here. If your caterham supplier doesn’t have it Tom Carlin probably will.
May not work for Caterham: but I've found best technique in Birkin is to remove all incidentals from engine, elevate the car (on lift, or horses/blocks, etc), place a nylon strap around engine at 4th cylinder(balance point) and using a chain hoist lower the engine/transmission combo down to a dolly. After a few times this is an easy one person task. Keeping the gearbox level avoids dumping gear oil out the tail shaft. Enjoy se7ven ownership !
What cool protective eyewear have you found?
wemtd replied to Xhilr8n's topic in General Sevens Discussion
FWIW I've worn glacier glasses for years without any noticeable vision limitation. Consider that if you wear glasses you can't see lateral to the lens any way: so leather side shield is moot. -
“Glacier glasses” style sunglasses & ball cap tied to seatbelt anchor with para-cord. I probably look like a trainspotter who’s forgotten their anorak. But most would not consider driving the seven the be chique. -
This lookalike a bargain, and SB100 too! Re salty climates: If you pass the test fit, pm me for additional thoughts & experiences
Fwiw - since locktite was mentioned: to disengage/remove parts that have thread locker on them all you need to do is warm them up. (Different temps for different strength locker). Use a heat gun or fire & patience.
Not that we encounter. Everyone seemed to (mostly) behave themselves & a good time was had by all. I think one or two big cars not letting anyone by. Good run group sizes too.
You could try & see if Dick Brink has any laying around
Stirling Moss ?
2025 Annual HPDE - June 13/14, 2025 - Photos Thread
wemtd replied to Croc's topic in National Events
@Mrmustang: why a nitrile & not latex glove? -
Charlie - Thank you for the “Last Man Standing” performance award. The rain stopped, track dried up, & last session was great! It was myself, the Formula Atlantic & lots of open track. I cannot thank Croc & YellowS7 enough for organizing (herding cats) and otherwise smoothing over all the bumps & hiccups that inevitably pop up. -
2025 Annual HPDE Hosted by NJMP Drivers Club - June 13/14, 2025
Green Olive tomorrow night ? -
New Build, Indicators and Flashers Stopped Working
wemtd replied to TN_Scooter's topic in General Tech
If your switches are like mine: (simplified version)… all connections go through hazard switch. After switch is activated there is often a bad connection resulting in indicator light malfunction. cycling the switches on/off several times (probably rubbing off disuse oxidation) will restore normal function through the hazard switch. -
Forecast looks good! -
John Et al. The colors look good! re stickers: would it format on an oval vinyl cling sticker? I’ve had one on my car for years without falling off. & I’ve removed them without any marks.
Have you looked into Tillett b6 seat? I think this is the one caterham uses for many seats also. As bear bones as it is I find mine very comfortable on long drives. And between the various caterham importers and the other USA importer expect you can find one (with a little patience)
wemtd replied to Croc's topic in Cars For Sale
“seats with heated padding” ?!? Does it also come with cup holders for my latte?
