wemtd
Everything posted by wemtd
  1. Fantastic news!!! Now if the weather will cooperate (or I’ll bring my PFD) next weekend.
  2. Impressive memory Croc! Yes I have a 2.0 Duratec with Haltech ecu & loom. My vote would be to chuck it and put in a Duratec, ITB(or whatever fits) and new ECU (whatever works: Tom has been using Typhoon’s for a few years with few complaints). During my last gremlin infection I seriously contemplated upgrading ECU & Loom. For better or worse I was able to fix/re-wire the fault. Somewhere there is a breakpoint beyond which we need to start fresh. (Which is why I keep a spare longblock in my shed). p.
  3. A little late to the party here: my car has a kubota tractor/forklift alternator... If yours has a similar provenance that would explain difficulty searchign for one. Another consieration is to find an alternator repair shop. They may be able to rebuild your existing one.
  4. I’m happy with my odyssey battery (replaced once, but abused by a faulty starter & alternator). One friend is a big fan of braille batteries which are even smaller & lighter. it is helpful to have a local supplier with your chosen model in stock. This saved me on my last replacement the day before an AutoX.
  5. Iirc. I’ve seen pics of a plate cut down (top/bottom) trimmed to fit on bottom edge of Nosecone. Another bent the plate around bottom of nosecone. Croc’s version is easier.
  6. B6 (40cm) - be forewarned it Barely fits my narrow body. But it fits. Since I never have passengers I kept my fiberglass Birkin sport seat for passenger
  7. Tom in Colorado is very helpful. I ordered a Tillett seat from him and LOVE it. despite the thin padding it is comfortabel even for 5hr drives.
  8. What frame/vintage are you looking for? Fwiw- my windscreen took a rock & needed replacement. I managed to find an independent glass shop who replaced the laminated glass reusing the frame. granted if you’re going from brooklands back to a windshield this won’t help much p.
  9. Leave the kids at home & bring Larry.
  10. I don’t know if “EDIS Module” is same as the Haltech “ignition module”… what you’re describing sounds similar to mine dying a few years ago. much searching and one MacGyver’d Noid Light at midnight, and a few tech support headaches: I replaced it & problem solved. I also learned it’s a Bosch unit that interchanges to a 25$ VW part.
  11. If weather is favorable I hope to have several days with the seven in Vermont next month. Beyond: AppGap. Rt100, bread loaf, smugglers notch. Lincoln gap, Hero island & the Ben & Jerry’s tour, what good (must drive) roads am I missing? - other than every beautiful dirt road that doesn’t end in a logging track. p.
      • 1
      • Thanks
  12. Are they requiring Hans? For slow drivers like me? I recall last year conflicting tech forms indicating Hans was required or recommended/optional.
  13. Tom What are this year’s track/tech quirks? Harness in date & arm restraints of course. Should we look out for Brake pad measurements? Tire dates? Hans?
  14. Fwiw: my oil temp was getting to 230+ I added a Setrab cooler: Both water & oil temp are now stable at their set points. Discussion is here:
  15. Intermittent spark/wire fault? I had similar issue once with a frayed/worn wire going into ignition coil
  16. Lotus 7 : Anyone who really knows will spot the difference and you can have a good chat. Trying to go into detail with everyone else will just cut into your driving time.
  17. Apply a heat gun & time to warm things up & expand clearances ?
  18. I strongly prefer the zzs over ra-1. Much better grip & performance for street, autoX, and occasional trackday
  19. I’ll see you in September
  20. Another 👍 for safety/laminated green glass. I had mine replaced with this material. The trick is finding a competent/independent glass shop that will cut a piece to fit the frame & put it all back together.
  21. I have similar one as MichaelD for my Birkin (I sent dimensions to company to confirm fittment & needed a different model #) & have been happy with it.
  22. I previously had collectors via USAA (discount rate). Then consolidated all our insurances with a local broker for a collective discount. (IIRC others have had similar experiences). So I’d say (especially if you need homeowners insurance) to check with local broker to see if they can beat their competitors.
  23. Still waiting on parts: just picked up clutch. Shocks just got to heathrow. Radiator needs a bit of fabrication work… still awaiting other incidental parts & warmer weather so I can put all these nice things back together
