Ross is fortunate to have Josh being interested in the L7S3. Many of my friends have offered their specialty cars to their offsprings only to be told, Don't want it.
There is nothing wrong in having two sevens, but there comes a time to find another caretaker and for us with original cars, most of those interested are on the other side of the pond.
Wayne
A gear type of diff could use oil without the friction modifiers that are required for LSD which used plates.
Might need to try thicker diff oil.
Wayne
Not sure that the age makes a difference for the export. Shipping company only wants Bill of Sale and Title docs.
There may be difference based on age for import into the UK.
Short answer, they all will do that. You can't stay 100% original and have HP and use it. A plate to match the contours or bridge is usually welded on to the axle. For gears, maybe tr7, but that requires different axles and machine work. That to a local vintage racer.
Hi,
It has been on outgoing discussion, but you not lose 50 lbs with the duratec; maybe 10-15 lbs. Better breathing via larger valves and shorter stroke. I think that the factory weight for the zetec was with cast iron maniford.
I checked with Raceline a time ago and they weighed 95 Kg ready to install. I weighed mine and it was 215-220 ready to install. Not much difference.
Hi,
Don't know how well a duratec 2.3 will swap into an S3. There may be interference with steering shaft and front cover. You will need to do a lot of measuring.
The zetec is a common swap as it fits without too many modifications. When I installed mine, only the output of the water pump housing had to be modified.
Of course, there are motor mounts, headers and other swap related tasks.
Be interesting to follow your swap.
Wayne
How can you beat this value $85.
http://www.speedwaymotors.com/23-Ford-7-3-4-Inch-Racing-Pressure-Plate,8585.html
bolts in place of 8 1/2; requires spacing the throwout bearing closer to the flywheel.
Wayne
SVT should be a good choice.
Be careful using a stock disc if the engine revs over 6k. The standard type disc will disintegrate over that RPM. I have had that happen.
Might suggest a RAM clutch assembly that can be purchased from Speedway. Mine revs to 8K and so far, no problems after 2 yrs of WOT shifts.
Wayne
Be interesting to hear how the intake manifold works out.
Hi,
Where are you located?
I have replaced the radiator, added fuel injection and changed the steering rack on my long cockpit, big tube, BD chassis Cat of the same era.
Call me to discuss,
Wayne 619-444-0840
RAM has a clutch assembly for the 2.0 and 2.3 Pinto. Bought mine from Speedway.
Bolted right on to the Redline steel flywheel; not sure if you are using the SVT flywheel as it is setup for the larger bolts.
Wayne
John,
yes, SB1497 came with clams, but has the provision for cycle fenders.
These fenders were picked up in Wales in 1978 when I was working there.
Unless I list prices, I don't do not discuss pricing via emails.
Call me at 619-444-0840.
Wayne
Real Bullit, 3 rail, 2821E with ultraclose ratio, full synchro and magnesium tailhousing with internal remote shifter.
This is the "holy grail" of 3 rails. All up weight of 45 lbs.
pics on californiacaterham site or contact me.
call me for more info, 619-444-0840
Wayne
Hi,
If you missed this pair of cycle fenders, I have a pair of fenders that appear to be in better condition and have the mounting brackets.
Contact for pics and/or information.
Wayne, "super7guy7@yahoo.com"
619-444-0840
While watching Car Crazy noticed an all white S4 in the Monico museum; white body and white upholstery, chrome roll bar and headlights, alloy wheels. There was an air intake cut into the nose cone and the drivers (RHD) side.
They said that the Prince was into all types of cars.
Wayne
