super7guy
Everything posted by super7guy
  1. I have an almost complete set of DHLA45 jets for sale, at least four of each size and almost all sizes. Would sell duplicates, but would like to sell the complete set. Open to all cash offers from the list before hitting ebay. Thanks, Wayne super7guy7@yahoo.com
  2. Hi Ron,
    Don't know if you went to the Speedfest, but I got the names and emails of two (of 4) lotus 7 owners (Jim & Paul) and wanted to include you directly in my emails to them directly.
    Wayne, SB1497
  3. For those of you with built zetecs, what PV clearance are you using or what was recommended for your zetec? Thanks, Wayne
  4. For those of you with built zetecs, what PV clearance are you using or what was recommended for your zetec? Thanks, Wayne
  5. Did you try Raceline UK?
  6. Michael, While not a race clutch, just replaced the clutch with RAM disc and PP. Their new style PP is thinner and smaller. weighs 8-9 lbs and was already drilled for larger bolts. Disc is 7 3/4 vs 8 1/2. Used a sprung hub this time. Everything bolted up to the raceline zetec flywheel. Wayne
  7. Tom, You are corrrect, Illumination (Jenvey) ITB and at least 11.5:1. probably over 12; use 100+ VP. 185 HP @ 7500 and 155 TQ @ 5500. Thanks, Wayne
  8. Thanks Tom, I have a Esslinger head with the 32/29 combo, special stage 3 duration with stage 2 lift, stage 2 exhaust that puts out 185 hp at the wheels. It is time to do a valve job and spring replacement. If I can gain HP or TQ buy going to 33/30, it might be worth it. My application is autox. Your thoughts are appreciated. thanks, Wayne
  9. Why do you say big valves don't work? The FRH has 30mm & 33m which is larger than the previous hot set up of 29mm & 32mm. So larger valves not worth the costs? Thanks.
  10. Jeff Cashmoew Peter Raymond Elan of Mark Huffman Did nor see any Stakers in E mod; there was Westfield. Trying to get SCCA to have class where all se7ens (and other liteweights) can run together is like pushing you know what!
  11. Did anyone else notice the results of the Nationals? Out of 23 entries, all but 4 (Elans) were se7ens. Good Show
  12. Did anyone else notice the number of se7ens running at the Nationals? Out of 23 entries, all but 4 (Elans) were se7ens. Good show!!
  13. I have the original roll bar off an '83 Cat long cockpit. Located in San Diego. Wayne
  14. Hi, I have added bolsters to sides of the back wood seat panel. Cut out from 3/4" MDF or plywood a pattern whose profile matches the sides of the car (curved part) and the bottom tucks back in to miss the tunnel, Removed part of the upholstery to be able to install cut-down hardware angle brackets on the wood seat back. Upholstery shop made covers in matching naughahyde, slipped then on and stapled in place. Looks good and works good for my D mod cat. When my finacee drives, angle forward the seat, support seat back with wheel chock and put pillow behind to move butt forward. Wayne
  15. That's real good to only have 10% loss in the drive train.
  16. How close did they let you get your 7 into the Village? One of the UK mags had photos from inside the Village (with yellow nose)
  17. Hi For all of those that don't like the new aero rules, engine placements, etc. in SCCA D&E modified classes, some of us are going to have a silent protest by keeping the headlights mounted when we run our street registered sevens. Our neat sevens that we love are aero bricks! Wayne
  18. I think that they are going in the wrong direction around the track. Remember, the water swirls the other way down under.
  19. TwoBone Interested in doing the same for Avon slicks, if possible When you said "back out 7% duty and 8% GST" what is GST? How did the costs break down, tires vs shiiping I paid $125 for 4 slicks from the East coast to San Diego. Thanks, Wayne super7guy7@yahoo.com
  20. Shipping to 92021 for all 4?
  21. Bad or lazy drivers that cross the white lines on public roads.
  22. Can you provide details on why the raceline water rail will not work with the SVT head. Been thinking of using SVT head and presently are using raceline water rail. thanks, Wayne
  23. I have been happy with this one: http://www.ebay.com/itm/Sequential-Shift-Light-LED-race-road-bike-motorcycle-sprint-drag-racer-/260850918055?pt=UK_Motorcycle_Parts&hash=item3cbbed22a7 I set mine to be a max tq for first light and red line for flashing light. It does it own integration. Wayne
  24. On the subject of mufflers, my next try is using the C5 Corvette titanium muffler. The cut down muffler weighs (guess what 7 lbs). I will tuck it under the clam shell. I now have a spiral muffler and Ultraflow. When I was running the BDA, it required two Ultraflow mufflers. I also have a custom made alloy airbox which directs the intake noise into the cabin. Remember, at the "Q", we are limited to 93db @ 50 ft. Wayne
  25. Hi, Over the years, I have used rear axles from Datsun 1200 (very close dimensionally with the original lotus 7 axle) and Dodge mini trucks (wamted to use a torsen). Just depends on what gears, diffs and brakes are available that you want to use. With more small cars on the road now, should be able to find something to fit. They will all require welding of tabs for suspension. I prefer the removal third member type of diff for ease of service. Needless to say, doing your research and planning will lead to a successful transplant. Wayne
