Quick shot from today's Bday quick trip and thank you for @wemtd for stopping by to the humble abode and the gift. It's nice to see friendly faces outside of the stressful track days.
  • Like 3
1 hour ago, Vovchandr said:
Also troubleshoot my troubled map a little more
Still no data log. Barely had time to test the @catsv7 gave me and adjustments @NSXguy suggested I do to the fuel map table.
Acting like a blind squirrel looking for nuts I was able to throw some numbers into the tables that seemed to fix that part throttle flat spot/stumble/misfire I had. I only did a quick test
@catsv7 car didn't really start well with your profile and map and shot a major fireball upon one of startups. Barely ran. I took screenshots and compared data between our setups. They are different but aren't night and day so not quite sure why it acted so bad.
I believe adjusting the idle/starup portion of the map can be tricky. We are dealing with small magnitudes on the commanded injector opening time. The actual opening is comprised of a ramp from closed to open, a ramp from open to close with a "flat" in between. The fuel flow passed is also dependent on the injector flow number and the fuel pressure regulator setting. On top of this scheduling are adjustments for sensed air temperature, pressure, battery voltage and if a cold start is detected. These modifiers may be different between our ECUs, further complicating comparisons. I have noticed that "small" injector opening time changes can cause big swings in AFR. I have been tweaking the map at idle beyond the one I provided. This is because I put in a smaller capacity alternator and cold air intake system drawing air in front of radiator. Once the engine is warm it idles at close to 1100 rpm with +/- 50rpm hunting.
Im not coming an area of knowledge but it almost felt like the timing was off? The engine really didn't want to be running and I could keep forcing it by restarting it when it died. During one of the startups it backfired very loud that my better half came out of the house to see if I was Ok, so I took pictures of your setup and uploaded mine back.
I can try again at a different date to maybe mess with further tuning you described above.
With that said if my car is happy with my map I can stay on it and just use the differences as a guide as to what values to adjust and in which direction.
Edited by Vovchandr
Putting the car away for the season. Doing some numbers.
Doing a quick audit looks like it was 587 miles this season.
201 of them or so being track miles over 2 days at NJMP according to napkin math.
The oil hasn't been changed in probably two or three years now. Will change it and send it to Blackstone to see what the results say.
  • 2024 - 587 miles
  • 2023 - 250 miles (no track day)
  • 2022 - 600 miles (no track day)
  • 2021 - 800 miles
  • 2020 - 1700 miles
Edited by Vovchandr
On 9/25/2024 at 2:48 PM, Vovchandr said:
Looking at the track pictures
Looks like some years it was closer than others
The one in your screen shot is the fender that's held on by the bolts so it must by the original stay
This picture is from 2022 and is another factory stay with a glued fender yet very similar
So dove into this today
Not any closer to discovering why left fails but also realized I never used Race mounts on left and did switch to race mount on right so I had a mismatched set when not on CSR mounts.
Race sits a bit lower/closer to the tire.
Here are some comparisons
The sharpie line is how far the mounts need to move over on the back.
Edited by Vovchandr
Doing some deterred maintenance. Checked my brake fluid... Not too good..
Edited by Vovchandr
Doing some deterred maintenance. Checked my brace fluid... Not too good..
Yep it was "brace fluid".
Glad you did a track event with that brace fluid....
  • Shocked 2
Autocorrect.
Plus we all know I don't go fast enough to need anything besides engine brake.
Either way fair criticism. Not sure what the floaty stuff is. That needs to go. Using your syringe currently so thank you for the long term tool rental.
Will use the little tester to test other cars in the family.
NOOOOOOO!
The lesbian inseminator/turkey baster was used for oil removal.  Don't use it in the brake system as you could inadvertantly cross-contaminate the brake system.
29 minutes ago, Croc said:
NOOOOOOO!
:leaving:
New Blackstone oil report is out
Even more aluminum and iron, this time on even less miles. Last time I thought it might be high because my Accusump exploded so maybe parts of that were in the oil, but this time I have no Accusump, no oil cooler, regular WIX filter (maybe filter sucks?) and its even higher than before.
I even fixed the misfire (very recently but still)
  • Confused 1
  • 3 months later...
58 minutes ago, Vovchandr said:
Not that specific machine, but back in the early to mid 2K's, I worked for a race shop that had one. Beautiful, stainless steel, think they paid $4,500 for it. It allowed for balancing, testing, cleaning, when you needed to wring every last portion of performance out of the engine they were being installed on.
Yeah "real" machines are solid, I certainly don't need for a pro grade for a rare occasional use.
Definitely wanted to run the test to help partition out misc issues I have. If one isn't cycling right I'd rather find this out from the getgo than chase a tail around for a while.
I know one of my cylinders runs colder than the rest and this has moved from cylinder to cylinder looking back at the thread and the pictures. Hard to pinpoint exactly what has caused it to move with all the changes I've done overtime.
Maybe I'm overthinking this.
2021 - cylinder 4
I believe it's on cylinder 2 now. I'll double check next time I run it.
2021 - cylinder 4
Sounds like a fuel issue, especially if it moves from cylinder to cylinder. Dirt or air in the fuel system can do this, when is the last time you bled the system and changed the fuel filter?  Then again, how old are the injectors, are they high impedance or low impedance units? The injector system you linked to seems like just the ticket for a home mechanic. Let us know how that goes.
Bill
I have no experience with this machine or any of the other ones, but you can have a lot of injectors cleaned, tested and balanced for what it cost.
Bill
Should be high impedance from looking at my notes from last measurements. Dirt is a possibility
True, but diagnostic tools are good to own, especially with a number of vehicles between myself and my family. Depending how hard it is to setup might be a good thing to run/test and clean every once in a while.
I'm going to throw another one out there for you to ponder on, a potential leak in your fuel line when under pressure. My friend who is balancing the TWM throttle bodies finished the front end alignment and was taking the car out earlier today and smelled fuel. Drove it on the alignment lift and found a small leak starting in the -6 braided line. Now awaiting the new -6 line to be delivered and between the two of us will get it buttoned up. Hopefully back at the house before the end of the week.
