20 hours ago, savagete2860 said:
As for securing the car, I am going to have them put in E Tracks. Would the erickson tie downs work if the rear ratchets need to be in front of the to rear tire rather than behind? I imagine it wouldn't make a difference? https://www.etrailer.com/Car-Tie-Down-Straps/Erickson/EM58523-09162-4.html#exp-productdetails=.all-description
Video of the straps: https://www.youtube.com/watch?v=v4cK1aOsdbQ
I have bought from Steve at Autohauler Supply and have been happy.  Last year I treated myself to a new set of over-the-tire straps and these are the best ones yet. Ratchets are silky-smooth.  Right now they are $36.95 a corner.
https://www.autohaulersupply.com/products/2x11-ratchet-hdor-endshdorauto-idler-lps-dw-554676?variant=49012265746738
I always go off the ends of the car, but that's really because I am used to tying down cars like an Elise where you have no choice.
I see no reason why a guy could not tie down a Seven by having both ratchets between the front and rear tires.  The geometry of the strap holding the tire to the track is the same either way.   I don't recall seeing a formula car tied down that way, but there is no reason it would not work.
BTW, the guy doing that youtube video is not that good.  Among other things, there is no good reason to tie up your strap ends like that on an enclosed trailer.  That's only to keep them from flying around in the slipstream.
Also, I looked again at the site and I don't understand why you want those rings at the ends of the straps.  This set is like mine, and it is 31.95 a corner:
https://www.autohaulersupply.com/products/ultimate-horizontal-e-track-wheel-strap-low-pro-553719?variant=50221642744114
Those included European-style friction sleeves are great.  Remember, you are not laying sod.  Green side down.
I have never tried that Erickson brand, but I cannot imagine they would be any better.
Edited by pethier
now $28.95 each in blue or hi-viz green
I can see a reason.  On one side of the car the exhaust system could be in the way.  You might have room for one ratchet and not two.  Then again, there is no reason that the ratchet end has to be exactly in-line with the main piece of E-track. On the exhaust side of the car, you could run the front-tire ratchet behind the front tire.  The ratchet for the rear tire could sit offset from the main E-track and anchor to a short track placed for that purpose.  A single could do it.  If it is a single, I'd be sure that one is through-bolted.
I put my E-track in this trailer and through-bolted all of it, except where the hole hit a steel frame member I tapped the frame for 1/4-20.  When I bought the Caterham, the tracks were too far apart for the single-strap method.  I put in a second set of tracks butted up against the originals.  Since I didn't have a helper, I screwed this second track to the deck except where I hit a steel frame member I tapped the frame for 1/4-20.  Usually, the Seven lands so I put one clip in each track and the strap runs at a slight diagonal over the center of the tire.  With the wider wheels I now have for the Caterham, I will probably be on the original outside tracks.
Time for lunch.  The pounding rain and light hail seems over...
Edited by pethier
The weather has been cold and wet the last few weeks which has been holding up trying out my new trailer. My Caterham's radiator also decided to spring a leak, as they apparently like to do. Because of that, I have not been able to load up my car on the random decent days. I managed to sort the radiator and figured I'd load up the trailer and see where I could get the tongue weight using a scale I bought.
This is important not only to see if I can even get under 15% window for tongue weight but also to see where my payload capacity lands with a loaded trailer. After passengers and fuel, I only have ~970 lbs left for available payload with no trailer, tools, hitch, etc, so I am going to be cutting it close.
I put the car on the trailer, near the rear, and lowered it onto the scale. Bam - 250 lbs! I was starting to think the scale they used at the trailer shop was wrong since it ranged from like 700 down to low/mid 600s depending on car position. I was pretty happy because I am aiming for 365-550lbs and with how far back the car was, that should be simple to hit. I pushed the car to the front of the trailer and lowered onto the scale again, not is at 200 lbs. Huh.. turns out MY scale, not the shop's scale, was a dud and wouldn't measure over 200 lbs. I am now waiting on a replacement scale to try this all again and I still don't know exactly how I will load the trailer up or what my available payload will be.
Figured I would post some pictures of my almost complete tow setup.
Here is the full setup after I bought the trailer. No car loaded.
These are all from today...
Also discover the bell housing/skid plate gets hung up on the ramp door with me in the car. It just clears when the car is completely unloaded though.
I bought a set of Race Ramps to lessen the angle so my car would not hang up when I loaded/unloaded it.  They are light and work just fine.
You beat me to it.
I don't really need my Race Ramps for my Sevens, but I believe that's because my trailer has a beavertail.   The nose cones of my Sevens easily clear my ramp.  It is nicer to use them because it is smoother.
The trailer belonging to savagete2860 appears have a flat floor.
I originally bought the Race Ramps because my first trailer had a flat floor and I would catch something on the bottom of my wife's TR4.  I originally solved this with Rhino Ramps under the back wheels of the tow vehicle, but that's a real pain.
For the Elise I needed the Race Ramps not for high-centering but because the front overhang on my Elise would hit the trailer ramp before my front tires reached the ramp.  The little flip-up wedge with the piano hinge on the end of the ramp did not help.  I took off the wedge and the trailer ramp fits well in the notches in the Race Ramps.  This also made my little winch work easier because instead of two planes to get up from street level to trailer level (trailer ramp + beavertail), I have three (Race Ramps + trailer ramp + beavertail).  The inclination of the trailer ramp is reduced.
Bonus is that the trailer ramp is easier to lift without the weight  of the little flip-up wedge.  I can toss the trailer ramp up with one hand and then use both hands to shove in a Race Ramp before the trailer ramp falls down again.
For savagete2860,  Race Ramps should eliminate the need for the little flip-up wedge with the piano hinge and solve the high-centering problem.
Edited by pethier
There was a funny echo in there.
In your next-to last photo, it looks like your hinges might be too low.  Photos can deceive.
If you slap a yardstick against your trailer ramp and side it forward, does it hit your trailer floor?
Put another way, does the yardstick strike the vertical surface at the back of the trailer?
I believe if I put such a such a yardstick flat against my trailer ramp and pushed it forward, it would pass over (the beavertail portion of) my trailer floor.  I'm not going out at midnight to check it.
Haven't digested this whole thread, but the sump problem on my 7 is easily solved by jacking up the front of the trailer with the trailer's jack, taking all of the "travel" out of the tow vehicle's suspension.  This makes the angle from the trailer ramp to the trailer floor much less, even straight depending on the parking location.  Of course I do have a skid plate on my 7, and I have sanded down the forward edge of the trailer ramp a little bit.
I have done that also.  It has the advantage of not needing to buy Race Ramps, and the disadvantage of putting more strain on the trailer jack and the person powering the jack.
Another factor to toss into the mix is how you get the car into the trailer:  Push it, winch it, or drive it.  For me, the best way for me to get any kind of car into my trailer is to winch it.  With my 3000-pound Champion ATC winch, I can get my 3000-pound Cayman or one of my 1300-pound Sevens in placed exactly on the E-tracks by walking alongside the car with the steering wheel in on hand and a little wi-fi remote controller in the other.  When the Champion remote died, I bought a two-pack of remotes of another brand from Amazon for lunch money.  I devised a system using E-track parts to change the lateral position of the winch to suit the placement of the "extraction" connection on any car.  The Elise is on centerline.  The Cayman and Sevens are offset by various distances.
Winching allows one to observe how everything is clearing.  Also handy for cleaning the stones off your tires while the tread is still warm.
If I was going to put a Seven into a motorcycle trailer, I'd want to winch it.  With a light, narrow trailer, a smallish truck, and a Seven, the Taber10 method makes sense.  Even if the trailer floor is uphill, the winch method makes placement a breeze.  After you get the car placed, put your straps over the tires and disconnect the winch cable.
Be careful when selecting the winch.  I started with a 1500-pound winch of another brand from Horrible Freight.  The design was faulty:  It allowed the cable to climb over the rim of the spool and a get jammed between the spool and the frame.
Don't bother with trying to wire the winch to your rig.  A substantial jump box runs the winch just fine.  I have my trailer set up with lugs inside near the right door to connect a jump box (or in a pinch, jumper cables).  My trailer has a recessed step inside the door, and the jump box rides and operates there.  The jump box is easily recharged in my shop or motel room.
On 4/17/2026 at 8:39 AM, 7Westfield said:
I tow a friend's Formula Ford in a similar trailer. I load it as far back as possible. Then several hundred lbs of "stuff" goes in cabinet at the front, and a rack above the car, roughly at the trailer axles. Never weighed it, but my guess is 4000 +/-.  Towed w/ Suburban 2500
When I load the 7, it goes a bit farther forward, with the rear straps crossed in an X pattern.
We just use a fixed length loop thru each front a-arm, and ratchets at the back
I'd say start with the nose a foot from the front of the trailer, and work from there.
When he quits racing later this year, I'll be using my little open trailer for the 7, prob just put a hitch on the Accord
over the years, I've found the Sub to be real picky about rear tires. Get a set with weak sidewalls, and it can dance in a crosswind
Don't think much of the terrain tires on my F-150.  The Michelin all-weather LT tires on my Suburban 2500 were much better.  On the F-150, I keep the tires at 80 PSI all the time and use the sway-snubber.
Thanks everyone for you commets and advice so far. Made some more progress today.
New tongue weight scale came in, and it wasn’t accurate at all either. These things are junk. It would weigh the tongue weight at ~200-300 lbs which just didn’t seem right. I decided to just strap the car down and drive to a CAT scale and get real weights.
truck
steer axle: 2800lbs
rear axle: 2240lbs
trailer axle: 0lbs
truck + trailer
steer axle: 2560lbs
rear axle: 3020lbs
trailer axle: 3100lbs
So the loaded trailer was 3650, and tongue weight with where I happened to place the car, was 540lbs, pretty much sport on 15%. That also gives me about 100+ pounds more payload than I thought I would have which is great. I can probably move the car back a foot and gain even more payload if I ever needed it.
Strapping the car down was... interesting. I am new to ratchet straps, etrack, etc. I put it all together and wasn’t 100% confident on how tight the straps need to be or where to place them. I just cranked away until it was not that easy to do more. I checked after a few miles and the straps didn’t move or loosen, so must have been okay? Here are a bunch of photos of the car strapped. Does it seem okay or should I change anything? Should I leave the car in gear with the ebrake on? I do have drings I can certain use in addition to the over the tire straps if that would be a good idea as well.
The truck with the trailer loaded with the car drove fine, albeit I was not on a high way and only was going between 30-55mph. You can certainly tell the trailer has more weight with the car loaded though. Its much more sluggish in every area.
You don't need those rubber blocks on wide tires.  I stopped using them long ago because they were a right pain on my lowered Elise.  You can test the theory by leaving them off on one wheel.  If the strap is placed correctly, it's not going anywhere.  If it is placed incorrectly, I don't think the blocks are are going to help much.
It probably does not matter, but I tend to have the parking brake on and the car in neutral.
I use the space behind the car to stack up my race ramps and use a 1" ratchet strap from one E-track to the other to hold them in place.  They weigh almost nothing.
Ignore the D-rings.  The car needs to move on its suspension.  A Caterham does not offer much in the way of good places to hook tiedowns:  That's what is so good about using the tires.
I have a short strip of E-track about shoulder height on the side wall of the trailer near each corner of the car.  About 6 slots: three for a tire strap and 3 for whatever else is hanging around.  Since I run my ratchets ahead of the car, I generally only disconnect the after clip of the three on the front straps and leave the assemblies lying on the trailer floor while I am driving the car.  When the trailer is used for something else, I hang the front straps on the wall E-tracks.  With all three clips fastened, the mass of the straps themself is unlikely to cause any trouble. Don't just clip two; you don't want that idler roller swinging around when you are towing an empty trailer.
If you need to put the car in the trailer and don't have time to tie it down right then, take one of the straps and put it in the driver footwell of the truck so you you don't come back later and drive the rig away.
Maybe the #s you posted were before moving the car around a bit, but it looks to me like your tongue weight is 780lbs (3020-2240).
As to the tie downs, the last picture shows the rear side dropping straight down to the swivel.  I was always taught to "tuck" the straps down inside the outer circumference of the tire... ie., move that swivel roller a slot or two closer to the tire.  I'm not certain my way is "right", but it does provide more strap-to-tire contact area and allows less movement.  Do similarly with the anchor on the front side of the tire if you don't use the yellow ramps.
Like Pethier, with 4 tires strapped I tend to engage the parking break and leave the car in neutral.  I tighten my straps down quite tight, then make a point of stopping in the first 50 miles for a quick check of strap tension.
Edited by SENC
Those rubber guys are captive on the straps and cant be removed. There are 3 per strap. The also have little nubs that are supposed to go in a center groove on a tire to hold the car in place even more. However, on the r888rs, the center groove is offset so you cant really use it. When these straps need replaced I will likely grab some regular straps.
I plan on doing something like this eventually. I am planning on getting a second set of wheels for the caterham along with one or two trailer tire spares. This seems like the best solution for secruing them as well as maybe a few other things.
You're including the 240lbs that is coming from the front axle with the trailer loaded. it would be (3020-2240) - (2800-2560) = 540
Thank you and good catch, I will move the roller closer next time and pay attention to that. I assumed it was close  when i did this yesterday but you're right, looking at the photos at least the one could move at least on slot closer to the tire. If they are touching or could touch the tire in any capacity, is that too close?
I would double-check the specs and manual on your truck to see if there is a max tongue weight (in pounds) for the vehicle and/or hitch (without a wright-distributing hitch).  Also check the rear axle weight limits GAWR).  As loaded, you've moved a lot of weight off the front axle and onto the rear axle - which I suspect is why it feels sluggish to you - much reduced steering.  I might be hesitant to get much above 55 with that much weight moved off the front axle, but you'll know by feel.
As an example, my LR3 is rated for 7700 pounds towing capacity... but the hitch is only rated for 750 or 800.  So if towing near the max I can only go to 10% tongue weight.
At any rate, adjusting your load so that your tongue weight is closer to 10% may improve driveability.
Edited by SENC
Let's start with "It probably does not make much difference due to the friction of the strap".
Now, let's neglect the friction for a moment like a lot of classical physics illustrations do.  If the straps go straight down to the roller and clip, then the portion of the strap between the two is at the shortest length it can be.  The tire can't go anywhere because that would require more strap length.
The yellow things are not ramps, but chocks.   I believe they attach to the E-track.  I therefore suppose they offer more resistance to the car moving forward in braking (or, heaven forfend, a crash).  I don't think that strongly-enough to go out and buy a pair.   What they are good at is stopping the car while you load it at the exact place you had it last time.  Since I use a remote-controlled winch so I can see exactly what I am doing, I don't need permanent stops.
Non-Seven sidebar:  I have left door on my full-width trailer so I can open my car door.   I don't bother with the winch when unloading the car, I just get and drive the car out.  Some cars are set up so the car door will not clear the trailer inner fender and the trailer door.  I have fashioned plywood risers that key into the E-track.  I place two of these on the left track where the tires land.  The front one has a wood strip at the front to prevent the car from rolling off the front of the riser if the trailer happens to be pointing downhill when I am winching a car in.  These risers tilt the car enough to get door clearance.  This is really a good thing, since my Cayman has a dual-clutch transmission, so just like with a conventional automatic, I have to step on the brake to get it out of park.  The risers are sized so that I can still get the tire straps to the E-track slots.
I don't need these risers with a Seven.  I can enter either side of a Seven inside my trailer even if it has top and doors.
Of course they can be removed.  Grab pair of cutters and cut the back side of the block.  Don't use a box cutter or the like or you could damage the strap (not as big a risk if you had Diamond Weave straps).  Then just bend the block and pull it off the strap.  If, after your experiment, you think you need them, just pop them back on.  They will function just the same as if you had not cut them.
It should be a long time before you need to replace the straps.  What usually kills straps is UV radiation.  You are going to use and store these straps in an enclosed trailer.
I renew my endorsement of the Diamond Weave straps with the European-style friction sleeves from www.autohaulersupply.com.  I didn't buy these because my original straps were shot.  I bought them because they are better.
  • 3 weeks later...
Thank you to everyone who helped me figure this towing nonsense and indulged me and my unnecessary long posts! Last weekend, for the first time, I towed my Caterham to a track weekend and now I think I can add my final thoughts, opinions, and experiences.
Towing setup recap:
- 2026 Nissan frontier with a tow mode button and Redarc Tow-Pro Liberty Brake Controller
- Steel frame 7x14 v-nose tandem axle car mate avalanche trailer (2375# empty)
- 1280 lbs s3 caterham strapped down over the wheels via floor mounted etrack with ratchet straps.
- Tongue weight was right at 15%.
- Standard hitch - no sway/weight distribution
- Hitch and door locks.
- Grip tape on the ramp doors
My first towing trip was a hair over 2 hours, 90% highways with 70mph speed limits. The weather was not very good - windy and rainy. I keep speeds around 55-65mph to play it safe and improve mpg a little - you can tell the trailer is acting as a huge air brake the entire time. Through the seat of my pants I could feel some very minor bouncing as well as sway/movement from wind gusts and hitting standing water. Surprisingly, the most movement I felt was not from semis passing me, but rather SUVs that were going ~30 mph faster than me, which I did not really expect. Overall, it pulled fine and I would do a very long trip with a standard hitch without much thought. I do have the Anderson WDH, so I might just install it since I already have it.
So I did a >2hr stint in the truck and it was so, so, so much nicer than if I had to drive the Caterham. I had heated seats, took a phone call, listened to music, and enjoyed a cup holder. I also could comfortable shoes. Pure luxury! I probably would have cancelled the event and been out a decent chunk of change because of the weather without this new setup.
The weather was atrocious all weekend. It was raining cats and dogs. The car only got wet when I took it out to do some ice skating on the track and once when I thought it was clearing up and I was stuck in a classroom. It was awesome to have a little home base at the track to stay out of the weather as well. Being able to lock up the trailer after the track day gave me a nice sense of security as well.
This weekend also made me think of a few things that would be nice to have outside of just the bare bones trailer.
1. An extended roof at the rear to let less rain in the trailer when the ramp was down
2. Maybe a tent of cover the rear ramp when raining
3. mounted paper towel holders
4. mounted clipboard
5. A little shelf
6. hangers for helmet/hans/gloves
7. maybe a hanger for the nose cone and hood
And it starts . . . . . Congratulations on your trip. To my trailer I added a tool chest in the V. Just a metal something from Home Depot for clothing, very limited tools, helmet and shoes. A mirror is nice for sunscreen etc. I mostly autocross so air pressure etc, is my issue. Keep thinking of an EZ Up but have never done it. The Snap-On metal tool chests have gotten cheap as Harbor Freight drove the market and now you can find almost every size and shape imaginable.
Just came across this option for rear coverage.  Haven’t tried it myself so caveat emptor
  • Shocked 1
