  2. Hi, I'm going to contact you via private messaging.
  3. 1) can this seat be mounted at various angles? Realize it won't move once mounted. Trying to get lower in car than my stock seat, but I like long arm/short leg mounting. 2) tried to look on line for price to offer you to little avail. Any thoughts? This is fiberglass, not carbon fiber correct?
  4. Today
  5. Yeah I'm gonna do that. I just wanna see exactly how many miles and how many gallons (from full) each 1/4 tick of the gauge is. Was gonna do half a tank first, then I can see where 3/4 tank and 1/4 tank is... and then finally just drive til basically empty and see what that is. I think by that point, I might have enough data points to be able to guess relatively close where empty actually is.
  6. I do too. I haven't ruled out just me being a really dumb fellow quite yet, but so far, with me only filling up ~5 gallons, it's always displayed full on the gauge and will go steadily down towards empty. I always filled it when it hit then 1/4 mark, and it'll take about 4 gallons (until the nozzle shuts itself off). I just have a lot of experimenting and note taking to do for the next few fill ups just to see where I'm going off the rails.
  7. Yesterday
  8. The wire bundle is routed into the headlight mount through the mount's opening+grommet, then down through the mount and into and through the bracket on the forward upper wishbone mounting point (also with a grommet in that opening), and then into the chassis.
  9. Hard to tell but did you not run the wiring through the headlight mount cavity and ran it underneath the mount?
  10. Horns I installed PIAA Sport horns, based on online recommendations. They're noticeably louder than the stock horns. They wouldn't fit in the standard mounting location for the 310, so I used the mounting arrangement for the 420. The Encore uses a 420 radiator with the fan mounted in front, so I figure the horns won't get in the way of anything. I initially thought there might be other good candidate locations on frame rails but nothing looked ideal. The PIAA horns require using separate ground wires (provided). The existing purple power wire set was just slightly too short so I had to add a short extension
  11. Headlight wiring Finally managed to finish the headlight wiring. I'm not sure I'm happy with the results - the wiring looks pretty bulky. I decided to go with using a "Y" heat shrink piece when routing the indicator/turn-signal wire up into the headlight bowl. I'd also spliced in another wire to the indicator's power wire, and routed that into the headlight bowl as well. My thought is that when I install LED headlights, I hopefully can use that wire to operate the headlight's "switchback" capability to operate the headlight's daytime running light as a turn signal. Unlike the wiring diagrams and in other blogs I've seen, my indicator pods have red power wires rather than green. That now gives me two red wires at the end of the headlight wiring bundle - the sidelight/parking light wire and the indicator wire. The indicator's wire is a darker red, but I'll need to double check which is which when connecting to the econoseal connector. I tried to arrange the wires so that they'd be close to the same length once inside the chassis, but they're off quite a bit. I might decide to trim the lengths and crimp on new pins. One thing I'm wondering about is whether it would be better to send the indicator's ground wire out through the headlight mount and into the chassis along with the other headlight wires and the indicator power wire. That might neaten up the headlight wiring underneath the indicator pod. It would add extra difficulty in pushing the wire bundle through the headlight mount, but that went pretty easily for me. I've found that with heat shrink, the flexibility of the wrap can vary some between different brands. I ordered "flexible" HS from Digikey, along with the Y HS piece. I also used heat shrink fabric from Digikey. I tried some cheaper non shrink fabric from Amazon but I couldn't keep it from getting ragged looking.
  12. I wouldn't trust linearity of the gauge. Also, given that your gauge would read full with your prior filling technique, it suggests that you were probably getting the tank mostly full, unless your gauge is way off. I say drive it till you run out of gas (if practical), then you will actually know how much gas you've used to get to that point.
  13. I have the Bruce fuel mod which works well 420R. The first half of the tank lasts longer than the second half. I usually run it down to fairly solid on E and it will take 7.5-8 gallons (SV so 10.8 gals minus the roughly 1.5 unreachable). One time at the track i got distracted and buried the needle on E. It took almost 10 gals so maybe the 1.5 is overly safe but I dont try for that. Here is NY they have taken the auto locks off the pumps so you have to hold it anyway. With some practice you can judge it but 1/4 of the time i still have spill over.
  14. I remember trying this with my very first fill-up, but I can't remember what the results were. But again, I think that was with only 5 gallons... as my habit was to stop filling when the pump nozzle stops. I'm gonna carry around a small jerry can, and test the range. I'm at 777 having pumped "fully" and then drove 2 miles home. I'll check the mileage at 1/2 tank and then attempt to fill back to "full" and see what that volume is.
  15. I've never been able to use the auto-stop at the fuel pump in my r500. The speed at which I can fill the tank varies from location to location, but its rarely full go. Once I get to about 6gal I'll usually slow it down and listen for when its getting full (I'm usually only putting in around 7gal). I've also noticed the fuel gauge isn't overly accurate. It takes significantly more time to go from 30L to 20L than it does from 10L to 0L. Once I get to 10L I'm starting to look for a place to stop. I don't think I've ever put more than 7.5 gal in. While I also have a 36L tank, I'm not sure if its 1-2 gal of unusable space or if 0L on the gauge actually means another gal or so of fuel left (I don't plan on finding out).
  16. I'll just add that I hold the gas pump nozzle upside down when I'm filling my 1990 Caterham to get a better angle... I kinda lean into it with my body weight to keep the vapor-recovery belows thing compressed to prevent auto shut-off (might just be a California thing). It holds about 10 gallons, but most of the time I misjudge and get overflow. The filler neck on my older car might be a differnt shape from the more modern Cats, however. Cheers, -David
  17. So have you ever driven it from "fully full" until empty, or tested the range since a true fill up?
  18. I'm not sure how @Croc will feel about losing top billing
  19. I really need to dedicate a good amount of time to play with the ECU/Map/Settings in the driveway for a test and tune. I'll update that once that happens.
  20. I'm saying this. I'm possibly saying this. I only ever filled it to 5 gallons because 1) that's how big my jerry can was on initial fill 2) I thought it was 5 gallon capacity because the pump nozzle would auto-stop anytime I filled around 5 gallons. (I'm now aware of why this happens) Currently, meter reads full, and seems absolutely topped out. I don't see how I could have made a mistake given I was literally out of fuel and kept track of how much I filled up.... but I'm gonna drive around until the meter reads 1/2 and then see how much I can fill up. I'm at 777 miles exactly when I topped the tank off.
  21. Something's not adding up. Are you saying from running out of gas to filling the tank until overflowing that it took 5 gallons? Or that the tank only ever took 5 gallons on initial fill after build?
  22. Im not saying that this is the root cause of your issue, but the TPS calibration needs redone. The TPS voltage should typically be between 0.5V and 4.5V. Outside of that range it usually means a sensor or wiring fault. You should set the 0 point to the voltage seen with the engine idling and butterflies at the resting position (4.49V for your case). Similarly for the 100 point and linearly interpolate between the two. Changing this will of course change your fueling. I have seen cars where the TPS voltage changes between drives and that’s an indication of a failing sensor or counterfeit sensor. And regarding an IAC for idle control, I personally find it to be a must for a street car. I run one with my TWM manifold similarly to what you described. The simpler method is using a PWM actuated solenoid, but for this to work the TPS has to read below the threshold set in the map. If you post of pic of the solenoid I can tell you what kind it is.
  23. My TPS situation perplexes me. When I bought the car it had an IAC with ITB's with a vacuum rail plugged into all the runners of ITBs going to the IAC. I couldn't figure out how Pectel controls the IAC so I bypassed it. All vacuum lines are plugged and ITB's idle with air sneaking by the butterflies. Here is my TPS data
  24. Yep! The MAP sensor is really just there for barometric compensation. A TPS controls the tables. I can share my map that was done on a dyno for my 2.4L. I'll shoot you a PM.
