Everything posted by JohnCh
Time for an update given it's tied to one of the modifications performed during the original build. When I redesigned the fuel system, I knew there was a risk the 3D printed lid which seals the tank and mounts the various bits, might eventually leach fuel through the layer lines. Although it worked fine for nearly 3 years and over 3500 miles, it eventually started seeping after sitting for a few days with a very full tank. The easiest fix was to reprint the lid, then coat the underside with a plastic fuel tank sealant. The other option was to have it printed on a commercial Multi Jet Fusion printer that fuses Nylon powder rather than Nylon filament, then have it vapor smoothed. That latter process melts the outer surface, primarily to provide a glossy finish, but with the side benefit for me of closing off micropores on the surface, thus further improving the water resistance. In theory, that combination is effectively waterproof and still resistant to E10 fuel. Since I was curious about MFJ printing, and I wasn't certain how well the coating would hold up, I decided to go that route. This was also an opportunity to make a minor design change to the lid that would make future removal much easier. Underside of new MJF printed lid: Fuel assembly bits attached and ready for installation: While it was apart, I decided to tackle the Centroid capacitance fuel level sensor which has never worked well. Although I used an earlier version of that sensor in the Westfield with great success, the newer versions feature auto rather than manual calibration. This is to compensate for the significant capacitance differences between E10 and E0 fuel for those people who switch between the two. Their auto-cal feature has a trigger point at the top of the tube that resets the 5V capacitance map point every time the fuel reaches that level and the ignition is cycled (i.e. as when filling up at the gas station) thus optimizing for the type of fuel currently in the tank. With everything apart, I messed around with the sensor using a topped up gas can and a multimeter. After taking a few readings, I triggered the auto-cal function and retested everything. It is now correctly outputting 0-5V as expected. It looks like the issue was either that the trigger point was never reached when filling the tank, or the empty calibration was faulty out of the box. As a result, the sensor never had an accurate sense of remaining capacity. If my multimeter readings are to be believed — checking at full empty and half a can — this is now resolved. A few tanks should tell me if this is accurate or just wishful thinking on my part.
JohnCh replied to savagete2860's topic in General Sevens Discussion
Sticky posts are intended to keep important topics that I want everyone to see at the top of a sub forum. They are not intended to aid discoverability for non-critical or non-time sensitive topics. As soon as you do that, you open the door for a metric shitload of pinned topics in a forum that negatively impacts usability. A simple search for "trailers" returns this as the first topic. Granted it's new, but search works for simple subjects like this. If someone wants to invest the time to turn this thread's information into an article and include links to any relevant threads, I think that would make a great addition to that section of the site. Any volunteers? -
Factory Tour Today: Anyone's car in production?
JohnCh replied to 240's topic in General Sevens Discussion
I love the two photos of the factory floor. Really interesting to blow them up and see the assembly bay details and also some of unique color combinations under build. -
Are you signed up for the annual event at NJMP? Not exactly in your backyard, but you now have a trailer
Rear uprated ("race") brake upgrade finally done
JohnCh replied to KnifeySpoony's topic in General Tech
I upgraded my old Westfield from the standard Girling 0.7" master cylinder to the AP Racing unit. The mounting lugs differ slightly from the Caterham version to suit Westfield-specific packaging constraints, but otherwise the assemblies are effectively identical—including AP’s practice of individually shimming each unit to account for production tolerances. Both cars use the same rear calipers and feature four‑pot fronts, but the piston layouts differ slightly: the Westfield setup uses four 1.5" pistons, whereas the AP calipers use a staggered configuration with 1.5" and 1.625" pistons. So while the brake systems aren’t identical, they’re very close. The difference between the MCs was immediately noticeable—firmer pedal feel and easier modulation. Zero regrets despite the price and 6 month wait for AP to do a small run. Here are the AP and Girling 0.7" side-by-side: I also played around with brake pads on that car and found feel differed wildly. My assumption is the non-assisted nature tends to exacerbate differences in initial bite. @KnifeySpoony how is the dust with the Pagids? Is it just a little worse than the stock pads or is it excessive? -
I finally got around to reading @chrisp993's blog. It's well worth checking out if you haven't already done so. It's brought back a little trauma from my build, but other than that, I've really enjoyed it.
x Sorry, your tangent threw me and I assumed that was a generalization. I should have read it more closely. I took the car for a longer drive today and can confirm that vibration is now reduced to inconsequential levels. When it did vibrate, it wasn't enough to distort the view, and the rest of the time, it was rock steady. After more than 25 years of se7en ownership, this is a first.
Light from bright headlights immediately behind you will still reflect into your eyes. The extent that bothers someone or impacts their night vision for the road ahead is specific to the individual. Given the plethora of LED headlights and trucks/SUvs on the road, I find this issue more problematic today, and of course, it is compounded when the person travelling just a few car lengths behind doesn't realize their high beams are on. Been there/done that even with a day/night mirror fitted. As mentioned earlier, the convexity of this mirror is quite low. Much closer to a flat mirror than a traditional convex side mirror.
I've done touring through very hot areas and recommend a small, insulated hydration pack with straps like this one, which is thin enough to stow behind the seat and hangs from the headrest. Fill it up with mostly ice before you leave the hotel in the morning, and you'll have cool water later in the day when you need it. The bite tube makes easy to hydrate while driving, and the location keeps it out of the way. https://www.amazon.com/Hydrapak-HydraSleeve-Insulated-Shape-Shift-Low-Profile/dp/B0BRBR82BG
yep, the same setup @Outbound mentioned earlier. Zoom ships via Japan Post who handles the tariff payment and bills through Zoom, which simplified everything. The mirror was $115.23, the mount another $28.81, shipping to Seattle was $28.55, and tariffs were $20.03 for a grand total of $192.62.
I installed the Zoom Compact mirror today. I had previously lowered the factory mirror to the base of the windscreen to reduce some of the annoying vibration, but the Zoom takes things a noticeable step further. While shake isn’t completely eliminated, it’s no longer objectionable. The mirror is slightly convex and, despite its small size, provides a good field of view between the seats. There’s no day/night function, but the surface is coated with a blue tint to help reduce headlight glare. I was concerned the coating might be too dark during daytime use, but it seems fine. My only complaint is that adjustment requires loosening and tightening a set screw. This isn't a big deal unless you regularly share driving duties, but with a wider channel machined into the socket housing, and a Belleville washer to apply constant tension to the ball, it could operate like a conventional mirror.
JohnCh replied to Croc's topic in Cars For Sale
420R SV on BaT: https://bringatrailer.com/listing/2023-caterham-seven-420r/ -
Piling onto this comment, another place where people go wrong -- including Caterham -- is the sensor mounting orientation. Sensor manufacturers recommend positioning it at least 10 degrees above horizontal to minimize the condensation pooling on the tip.
I may be using TPU for a tricky airbox to air hose connection in another car. I'll be interested to hear how things go for you.
Very nice! For under bonnet items, check out PET-CF. Prints just as nicely as PETG-CF, but can handle very high heat.
He has a problematic Zetec that is getting horrid mileage. Someone with a 420 should be able to chime in with their typical street mpg. As proxies, my Westfield, with a taller (3.62 vs. 3.92) final drive returned ~25 mpg when it had 420 cams with ITBs, and about 1-2mpg worse after changing to more aggressive cams. Highway consumption when touring was much better. The 2.4L Duratec in my Caterham is pretty thirsty, barely breaking 20 mpg in normal (back roads/around town) street use. Something would need to be wrong for you to go through 5 gallons in just 40 miles of street use in a stock 420.
BTW all the suggestions above are assuming your car is running well and you aren't getting @Vovchandr-like fuel consumption.
Caterham doesn't offer smaller fuel tanks, so even if they somehow managed to install the slightly smaller S3 tank in your SV, you would still have 9.5 gallons less ~1.5 gallons the fuel pump can't reach. That doesn't mean the tank wasn't crushed, but you that would be pretty obvious from beneath the car. From the owner's manual: It seems there are only two possibilities: The way you checked earlier that the tank was full was done incorrectly, or you have an issue with the tank. Although it's a little tricky to do because of the flap and the curvature of the filler neck, you could make a curved dipstick out of thick single strand wire or thin rod to confirm the fuel level. I have done this before when troubleshooting, but it took several attempts to get an accurate reading. I found putting painter's tape on the rod was helpful to see the actual level. Another possibility is repeatedly tapping the front of the tank going from bottom to top to see if you note a change in the thud that delineates the transition from fuel to air. I've never tried this myself, so the difference may be too subtle to hear. If you do attempt it, avoid the middle of the tank where the baffle is located. If you think the tank should be nearly full and the dipstick or thump test shows about half, then you know the issue is with filling it. If not, then there could be a blockage, or possibly an issue with the baffle, which divides the fill side and pump side of the tank. The foolproof method to confirm the fuel level is to remove the floor and pull the fuel pump/sensor assembly and do a visual check. However, that isn't easy as an uncut floor can be very frustrating to remove, and you need a special tool to remove the fuel assembly's locking ring. Fortunately, that tool is readily available and isn't expensive. My boot floor is currently removed, so let me know if you need pictures of anything.
Yep! The MAP sensor is really just there for barometric compensation. A TPS controls the tables. I can share my map that was done on a dyno for my 2.4L. I'll shoot you a PM.
@redursidae welcome to the world of se7ens where Alpha-N is the norm. Even the MBE in new Caterhams employs this older strategy with time-based injector control. It's certainly not as good as a VE-based PID control, but it's certainly possible to achieve good behavior with these less sophisticated ECUs. Over the last 22 years, I've run Emerald and MBE on Duratecs with ITBs and have never had running issues related to the mapping strategy. Your advice is spot on when it's time to replace the Pectel, but I suspect @Vovchandr's issues run far beyond his map or mapping strategy. Fuel milage doesn't plummet by 40% unless there is some kind of failure. He needs to address that first. I suppose it's possible that the Pectel has a driver failure that is intermittently holding open an injector, but other than that, I'd start by looking at all sensors that can trim the injection map, run a compression and leak down, then check injector flow to see if one or more is bad. If the AFR numbers provided above are accurate, I'd be very concerned about bore wash. Given all the issues with this particular engine over the years, I suspect there are multiple things going on. Occam's razor won't apply.
If your totals and fill procedure above are accurate, and assuming your car wasn't used to smuggle anything into the country via a hidden compartment in the fuel tank, I wonder if you experienced a fuel delivery issue, that is discrete from your gauge accuracy? Either some kind of blockage in the tank or the fuel pump cutting out? Has this only happened once?
I'm having trouble correlating your last two posts. Nearly 6 years ago, you wrote: Now you say: Did you make map changes in those intervening years, or does the Pectel have a self-mapping function that would have altered it without your intervention? If not, and if the supplied data is accurate, then something else has occurred to account for the significant drop in mpg; leaking injectors, fuel pressure has increased, TPS is out of adjustment, O2 sensor feeding the closed-loop mode has failed, compromised cylinder(s), etc. Changing the map to compensate for an unknown issue is just kicking the problem down the road. You need to identify the root cause(s).
The latest issue of Avants magazine has a nice article on Caterham that was pulled together with the help of some Seattle-area owners and features some very nice photography. https://www.avants.com/magazine/the-benchmark-for-lightness?
