Jesse D
Everything posted by Jesse D
  1. I took off my metal screens and went with film- I replace it each year but the fiberglass underneath is fine.
  2. I put on Brookland screens. Can't put the top up but completely ended the buffeting and I can wear a ball cap up to 60 mph.
  3. While we are on the subject, what have people been buying in a smaller size like 5 3/4 or even smaller. My big ones are like the yellow/red ones pictured- bottom mount.
  4. Easy repair on the backside if you have a crack- I've done it twice from an autocross cone. These fenders are just chopped strand fiberglass and quite weak. Sand the backside and put a couple layers cloth down with resin. Tan inch wider than the crack on each side. Be sloppy, no one can see it. Then sand and fill the outside and put on your tape for now.
  5. Truth in advertising is important.
  6. Doesn't quite match up with mine, but I'll add it to my collection.
  7. I've got to make the usual repairs to my passenger rear fender from Autocross (there is a reason why I hit passenger side cones). Need to replace the foam in my oil pan and, as always, looking for a nice wide set of 13" rims to mount new slicks.
  8. I autocross my Seven a lot and switched to 13s and slicks at the same time- first set of slicks were Hoosiers but now I'm on my second set of Avons (from Roger Krauss). I like the 13s and I like the Avons better than Hoosiers- my feeling is the Hoosiers are made for Miata's and Avon understands how light a Seven is. The Miata drivers that ride/drive my Seven all love it, other than the pedal box and seat width:-) In Maine I'm automatically a modified car, being a kit car, so no class penalty for slicks. I'd switch to 13s rather than my 14s for the street too if I could find a set of 13s- I think our cars were designed for more sidewall.
  9. I just mailed a letter I hope will get to his K'port address, but if he's ok with it, message me with his private contact info. We have one last event this fall and I'd like to get him to see it- think it will meet his desire for local racing.
  10. If Rick ever shows up here, get in touch with me- I used to live in the port and now live in Portland- we autocross regularly in Brunswick and I'd love to add another 7 to our fun.
  11. I'm in Portland Maine and have a 1993 HPC Caterham. It's inside and available most any time for a fitting. Come on up. Mr. Mark, join me at Cumberland Motor Club Autocross in Brunswick at the old airbase, most every month this summer. It would be fun to have someone else to play with. https://www.facebook.com/groups/cumberlandmotorclub/permalink/10151405926509943/
  12. I sent you a message- I'm interested. Jesse
  13. I have those seats in my 93 SV and love them- much more comfortable than padded seats for me.
  14. I'm in the thousand mile range each year, which is just about right for Maine. When I bought my 93 used off this list, Chris T had another with more horsepower, but I'm glad I bought the one I did- I get pangs for more, but it's just about right. I'd wanted one from when I was 15 or so and tried to convince my father that a kit was a good idea, and finally bought in my mid 60's- worth the wait.
  15. Easy to do, harder to do well, especially in clear carbon. You'll want to fill the holes flush and strong before you lay cloth over, and follow vacuum bagging instructions if you want it to look right. Nothing about this is particularly difficult, but getting it flat and smooth and with the carbon cloth running straight takes some skill.
  16. What you are seeing is either scratching or most likely UV damage to the epoxy that is the surface layer of your carbon part. You can temporarily brighten it with polish and if wax or sealant was regularly applied from the beginning you can prevent it, but once it's there you can't sand/buff it back. The black color just attracts UV heat and thus damage. Some manufacturers put a clear coat on top of the epoxy, especially for exterior parts, and that you might be able to sand and refinish. Most carbon bits on a boat end up being painted and more and more are painted from the beginning, as the deterioration in a carbon part like a mast is very real and can end up structural. I don't think a carbon dash is in any way structural:-)
  17. I have a tube bar almost identical in shape to panamericano's. Fiberglass is one part of these cars I'm good at, and I can tell you that these Caterham's glass parts are not very strong and will crack from flex at very little provocation- I took a tiny chip out of the top of my passenger fender from a cone, probably because I was going very fast when I hit it and I had strengthened the lower parts of the fender with carbon and so the energy just went to the top curve. The fenders are made using chopped mat- I didn't see any evidence of cloth when I repaired both fenders. Next winter I'll strengthen the entire lip. The good news is that the gel coat finish makes for easy spot repairs that are invisible if your color match is good- that is a big advantage over paint.
  18. One of the specific reasons I bought my 93 Caterham was to take up autocross. My theory was "buy the perfect car, so all the mistakes belong to the driver- best way to learn". I still tell people that, and believe it. Took a while, but finally the regulars suggested new tires and soon after that suggested slicks, as the car runs in DM anyways. Found some 13" wheels, ran Hoosiers for two years and this summer have done one event on a new set of Avons. Slicks are fun. I disconnected my anti-roll bar to help the Avons fit, but my first impression is that mechanical grip is improved- these cars are so light.
  19. Thank you, the circlips are the answer. No allen wrench holes however. Appreciate the help.
  20. Thanks Bruce, I appreciate the adjustment advice. Unfortunately at this point I'm still in a quandary as to how the droplinks are fastened. Both top and bottom have nylock nuts and nothing protruding more than a hair beyond the nut, so nothing to grip at that end. I'm reluctant to mess with it much given the difficulty of getting any parts right now.
  21. I have a 1993 Caterham with a De Dion rear and an anti-roll bar. The attached photo is of the driver's side. I would like to be able to adjust the anti-roll setting which is currently on the softest setting. The droplink that connects the axle assembly to the anti-roll bar has threaded rods top and bottom that pass through the anti-roll bar and the axle assembly with nuts on the back side. I have a builder's manual for the car (I didn't build it) so I believe I understand the assembly. When I began to turn the nut on the backside of the anti-roll bar it was clear that the nut and rod were turning together and the threaded rod was backing out of the droplink. My questions are this. First, am I correct that the droplink is unloaded at rest and I can safely back the rod out without damaging anything, and disassemble the other end however it comes undone and fix the threaded shafts into the droplink with loctite so they work correctly. It certainly feels unloaded. Second, is the length of the droplink crucial provided both are the same length. One of the reasons I'm considering adjusting the setting is that the slicks I run when autocrossing rub slightly on the droplink at the anti-roll bar end (you can see the gloss). Shortening the droplink would move it closer to the center of the wheel and away from the fattest portion of the tire- going to a higher setting on the antiroll bar would do the same thing. I'd like to be able to adjust the setting but leave it on softest if that suits the car the best. My thanks for your thoughts.
  22. Just put them on and passed inspection in Maine- sorry I know that isn't much help but closer than a lot of folks. As a data point, the speed I can drive with a ball cap on has gone up by 10-15 mph, for which my mostly bald head is grateful.
  23. I bought my Caterham four years ago from the Cars for sale section on this group after having Chris (Sevens and Elans) drive down and look at it with me in NJ as he had built it in 1993. He has been very helpful to me since, and while I wish he was still nearby in Mass., I don't begrudge him the warmth of Florida. Most recently he sourced a set of Brooklands screens and stanchion for me in the last few months.
  24. Sent you a private message- I may be able to help.
  25. I bought a building a few years ago when I owned a business that dealt in fabric. It had been an auto shop with a concrete floor that had stains and cracks. I had the floor polished and the result was remarkable. It was less expensive than any alternative I could find and resulted in a floor very easy to wash, sweep and keep clean. It will stain from oil but given the way the polishing leaves a stone like appearance from the aggregate in the concrete, it is mostly invisible. In one picture the boat is center stage, sorry. And apologies for the sideways picture too. http://www.usa7s.net/vb/attachment.php?attachmentid=13939&stc=1
