sf4018
Everything posted by sf4018
  1. Season 2 has started 🍿.
  2. When you get to plumbing, the purple meanie build is a great reference... Build Session 17.5 : Caterham 420R Water and Oil Overview | PurpleMeanie
  3. Thanks for the pics, the outer lip of the Recaro seat near the hips appears to be wider than the width of the cockpit, you seem to have overcome this by positioning the right lip over the tunnel, which I can’t do. Grrr. Sorry for hijacking this thread.
  4. @Kitcatwhats the halo seat you have in there? That’s what I’ve been looking for but couldn’t find anything that fits.
  5. +1 for Hoosier slicks for the track, the Hoosier Formula 2000 radials 43370/43380 R35 compound are about 5 seconds faster than the ZZRs at Barber. They also started selling R55 compound recently.
  6. 1. I'd been fighting that for a while where the right foot presses on the gas pedal little when braking (I have super wide feet). I would hazard a guess the same thing is happening for you. If you have the stock gas pedal add a spring return, that'll help you feel it better. Also narrow footwear or even race shoes may be worth a shot. Last resort modify the gas/brake pedal. 2. The brakes for me take a little warming up to work fully, once warm you can lock the wheels up, but it does take more force to operate than typical cars do, it just takes a little getting used to. They may need bedding in too. 3. No idea.
  7. Feels like the end of season 1, can't wait for Season 2 to be released!
  8. Electrical Wiring: Nothing from Caterham yet despite pleas, so I've gone into reverse engineering mode. Here's a diagram I made of the existing pump module/fuel tank harness wiring. Everything is known except for a mystery GY wire that goes to the pump module. My hope is GY is some kind of engine running signal but I won't know until the job is done (it's not ignition it didn't switch on when I cranked the engine). .... Based on some testing I did the current system energizes YW for about 1 second after turning the key to the 2 position (YG154 energizes), which pressurizes the fuel lines in preparation for cranking and starting the engine. Then presumably the mystery GY wire will switch the pump on full time. The system I'm building will have a pressure regulator with a return to tank so this pulse is probably not needed and can just stay on full time with the key in the 2 position. I'll be cocking about with this once the system is ready to startup as I don't know whether the control module should/can be eliminated yet, but in terms of electrical wiring it's a pretty simple change. At least there's a plan, hopefully it's correct! Note from the future: GY wire was a pump run command from the ECU. Plan A is best if you have an unlocked ECU. Plan B also works but stays on even if the engine is stopped so is not quite as safe.
  9. Caterham sent 3 pics of a bag tank installation that's in for service right now.... The first pic shows a pressure regulator (yellow part) with return to tank and presumably line to rail but cannot be seen. The metallic part before that looks like a sampling device (I guess they have that in the UK). I don't believe that'll be needed in the US unless someone thinks otherwise. Caterham did not include either of these parts in the original shipment so this has spawned more questions. This is the mount location for the pump, which is very helpful. No filter though, another question. Bottom up view of pump installation. It mounts to the tank box.
  10. Make sure the port and screw is clean, use a fresh copper washer each time you take the screw off.
  11. It was the inertia switch that caused the cut off, I guess the ribbed curb on the exit of oak tree caused it to trip. That doesn't explain the vibration/loss of power still but at least the cutout is explained!
  12. Could spray soapy water on the good tank cap to see if even that one is leaking air?
  13. The old tank is removed. There aren't many technical points to note for disassembly except that the tank is lifted out not lowered, so the roll cage and dampers needed to be removed to allow aluminum honeycomb and then tank removal. One item that is unknown right now is whether the drivetrain needs to be removed to allow fuel pipe installation. The existing fuel pipe is mounted under the topside of the tunnel so it's pretty much inaccessible without removing the drivetrain. The hope right now is the new pipe can be installed without having to do this. Cross fingers! For the installation I'm waiting on 3 bits of info from Caterham to move forward... 1. New tank mounting: The old fuel tank was 91cm wide, the new bag tank container is 80cm wide. So the lower black tank brackets on the car are too wide for the new tank (55mm gap each side), see picture below. I've asked what the correct mount method for the underside is. 2. Electrical Wiring: The original tank had a ford/rover pump and tank level sensor which was connected with a 6 pin connector with 4 wires to the tank. The new tank has a Bosch external pump and no tank level, and 2 wires for the pump only. See pics below. The questions to Caterham are: a. Do I keep relay AU5A-9D370-FC and existing wiring intact? (I believe yes) b. Which of the 4 wires connect to the 2 pump wires? (I think pink and yellow). Original 6 pin connector with 4 wires: •Pink/White •Black •Green/Black •Yellow/White 3. Pump and Filter Mount Location, plumbing: I've asked Caterham for info about where they normally mount the pump and filter, plus pics of the plumbing. I really have no clue about this part.
  14. Started the disassembly…straight forward so far though the aluminum honeycomb doesn’t come out of the top, hopefully it drops down after the tank is removed. Anyone know how to remove the fuel line shown in the pic below??
  15. I have 65mm gap for lowest point to ground (I have dry sump so this is the bell housing). It was lower than that initially but I had issues when running over curbs. Since I raised it to the current position I haven’t had a problem. If you drive pot holed roads you may need to raise.
  16. I think I’m in the minority but when I asked about IVA trim with the tech folks apparently some of it is only used for kit builds in the UK, for factory build they don’t use it. No idea why except stupid government regulation. I basically only used IVA stuff that actually had an obvious function like grommets. The edge trim for the exhaust for example I started to put on but didn’t like the look of it so I took it off, still off today.
  17. You trying to so some aero thing or just avoid hitting stuff underneath?
  18. Good idea, we checked fuses they are good. I'm currently on my 2nd beer so I think I'm done for the day . Thanks for all the quick replies, you guys are awesome!
  19. Thanks guys for the pointers. A mechanic took a look under the tank to listen for noise when I turned the car on. No noise at all. Took off the fuel hose - no fuel. The end of the last last track day I did run out of gas, which was a bit embarrassing, but maybe that caused some damage to the pump? Not sure if that can cause damage.
  20. Wiring looks good, no fraying, everything connected solid. There’s no gas smell coming out of exhaust when turning over. I think the fuel pump may be toast it did all of 1,300 miles, I guess it wasn’t designed for track days!
  21. I’m at ViR today, did warmups and started feeling a weird vibration when higher speeds (95+) that when it came on the car was losing power, almost like a lost cylinder. Then the vibration disappeared and the engine came back to full power, it did it on the straights mainly. Then during the first session (still not pushing hard) it kept doing it again pretty frequently, then the engine cut completely. Any ideas where to start looking? Is that an indication of a fuel pump problem or maybe wiring? I have no idea. When I took the lid off the spark plug cover was loose (the 2 bolts had shaken off I guess). Don’t if that’s coincidence… Any suggestions appreciated!
  22. Nice improvement, the standard one looks (and is) really cheap looking like it's been taken from a 1980 Ford Escort.
  23. What Croc said. Is it not handling right?
  24. I think you're going in the right direction, shouldn't the white line in the last pic be at 100%?
Ă—
Ă—
