Everything posted by sf4018
What “legislative challenges” are they talking about? Brexit fallout? Elimination of gas engines? Who knows!
Mileage roll call. Did you buy the right version of the car?
sf4018 replied to Vovchandr's topic in General Sevens Discussion
I'm really curious how easy or hard it'll be to flush out 5 year old gas from the lines, keep us posted! -
Things you need to know about the new forum
sf4018 replied to JohnCh's topic in General Sevens Discussion
Looks great! I know how much work that was to do, thanks sooo much. What does the blue circle shield mean? Are you guys special? -
So I researched brake pads some more, starting with the 2 caterham types on offer. The “uprated” pad is a bog standard Delphi 407CP. The “standard” pad is AP racing brand with ferodo material DS25 type material (and more expensive). The descriptions seem upside down. I could not find any AP Racing pads online that I was comfortable with, Ferodo didn’t seem to sell the shape needed. Then I found Pagid racing which sells the right shape in 2 compounds - RS14 and RS42 (shape 1163). I guess it’s going to be a guessing game which compound to use. Has anyone used these pads or have any other pad suggestions?
Could try disconnecting the battery after starting the engine then switch on lights etc to load it up, see what happens at idle and higher rpm? Sure sounds like an alternator issue of some kind.
They are part numbers 43370 and 43380, compound R35. They fit on 13/6 front and 13/8 rear wheels, almost identical dimensions to the Avon ZZRs. They are actually meant for the F2000 formula cars.
After all the crappy weather the last few weeks we had an sunny and pleasantly cool weekend, so thankful for that! This was the last stint of the weekend, I put the rather beaten up Hoosier slicks on for it, so they were not the most stable the first few laps while working off the grain and flat spots. They are about 4-5 seconds a lap faster then the Avon ZZRs and about 200% more fun. The new throttle pedal worked great, but with my Sasquatch feet I still leaned on it some when braking, but much better! [video=youtube;-WYPb5F0odA]
I contacted Caterham about the upgraded rear brake package Problem is there's no handbrake and would not be road legal, which after the effort and cost to get the title and tag seems overall a step backwards. I think for now I'm going to try and add some ductwork and see if I can make them last 2 weekends at least, swapping rear pads out isn't the end of the world.
Wow, thanks for all the advice, you guys are great! Anker - Fronts locked up last weekend, nice flat spot to prove it! CarlB - that was a good test, the brake bias seems fine (the fronts were somewhat harder to turn than the rears at different pressures). Croc - Rears Dragging: rear disc rotates by hand though I do hear noise as they do seem to be in contact, but I can’t see how that wouldn’t happen. KnifeySpoony - fronts are air cooled discs with quad calipers (the uprated version), rears are the standard solid ones and standard calipers. Rear pads are the uprated ones from Caterham... https://caterhamparts.co.uk/calipers-pads-discs/668-brake-pads-rear-use-with-4-pot-front-brakes.html?search_query=30B013A&results=1. The picture shows 507CC but they shipped 507CP. I just discovered I can’t get to the front pads - one of the 2 brake retaining pins is blocked by the cycle wing frame grrr. Maybe add air ducts to the rears?
Spa oil/water temp gauges plug and play?
sf4018 replied to KnifeySpoony's topic in General Sevens Discussion
There’s an oil temp sender on the sump oil tank that’s allegedly not used by the ECU (even though there is wiring for it). I had some back and forth with Caterham about it during the build. I still have it connected to be sure, but you could maybe wire to that sender to your gauge so as to not interfere with the rest of the system? Can also be accessed via Canbus/obd2, which is what I ended up doing. -
I just finished the first track day of the year, the rear brakes I’ve changed one time already and are already half worn, the fronts are on the first set of pads still and about 80% pad left. Is this normal? I would have thought the fronts would go first... Thanks!
Remember when hybrid cars were the in thing? That didn't turn out well. Same for "clean diesel" in Europe. Electric cars are just he latest way to destroy the planet. I just can't see gas cars going away, but it would make sense if Caterham developed an electric version though, at least for political cover, but it could also be a good seller too.
There's some dangerous counterfeit stuff out there, only buy from reputable companies!
Don't have them but it seems like it might work well to protect the bow tube from scratches, looks good too.
Trim the ride height 9" inches up and he'll be golden.
I'm a gung-ho kinda guy but that sounds terrifying!
So from my novice metalworking tools and skills I've made a Frankenstein pedal from a Lokar throttle pedal set (it's ugly but works quite well so far). I have to add a spring return somewhere - should it attach above or below the pivot point? Where on the chassis should the other end of the spring attach to??
Questions About Differential install
sf4018 replied to Squeegee's topic in General Sevens Discussion
1. Not sure if one is better but we put in bottom first because it’s easier to get in (I stress the word “we” as I couldn’t have done I alone, it was the hardest part of the build!). We used a jack to support the weight with one person holding it steady and the other person hammering the bolt in. Then we raised the jack to line up the top bolt openings. The top bolt took some major hammering to get all the way through, what a bear. 2. I would guess yes as it connects to universal joints? 3. We put a ton of copper slip on the bolts, didn’t chamfer, so dunno about that one. -
I purchased a Black 8 a few months ago and it’s not been great, it works like a product that was pushed out before it was ready. A YI is a quarter of the price of a GoPro, worth a look. If you do track days and want to blow some major $ check out Aim Smartycam.
Been fly fishing in the southern Ozarks a few times, beautiful countryside there, I'd be excited to visit this part of the State. It's a 9 hour drive so it's definitely not too far. Hopefully the established track day guys pick it up next year.
VRG Turkey Bowl 2020 - racing at Summit Point in a Super Seven!
sf4018 replied to d15b7's topic in General Sevens Discussion
That was fun to watch, thanks for sharing! 1:23 in those track conditions shows how precise your lines and car control were. It's a bit of an empty win for the Elva with that straight line speed advantage, I'm guessing you and the Datsun had a much more fun. -
Amazing kit, congrats!
2020 Racing Montage in Brunton SuperStalker (3.8L Supercharged)
sf4018 replied to searya's topic in Seven Videos
Great video, nice job by your son, thanks for sharing! The side view especially the sundown shots are really cool, I may try to replicate that next time. That blue car spinning out in front of you was a bit of a code brown, good job he didn’t jump back onto the track. -
Nick, that looks like something I could do, I'm not really a fabricator, so attaching some pedal surfaces and bending stuff is is probably the extent of my abilities. Do you have a part number for those pedal surfaces? I guess they were bolted on after drilling some holes in the existing pedals?
