fastg Posted February 16, 2021 Share Posted February 16, 2021 Imagine how expensive a Caterham would be if it contained many custom parts? Using of the shelf parts dramatically reduces cost. Graham Link to comment Share on other sites More sharing options...
CarlB Posted February 16, 2021 Share Posted February 16, 2021 Lots of race cars used the Triumph spindle, Including early 60s formula one cars. I have played with a lot of Formula Fords and similar cars. Very common for them to use that spindle. Link to comment Share on other sites More sharing options...
BruceBe Posted February 17, 2021 Share Posted February 17, 2021 Spindle is now a custom AP part, as of 2015. It's important to note that *all* car manufacturers utilize an outsourced supply-chain, as it is less profitable to maintain the design/implementation resources in-house. Most of those custom Titan and AP parts were specifically designed for Caterham, to their specifications. Pop quiz and a gold star to the one who correctly identifies the interchange on the CSR rear brake caliper (Croc - give them a chance). Cheers, -Bruce Link to comment Share on other sites More sharing options...
yellowss7 Posted February 17, 2021 Share Posted February 17, 2021 VW? Link to comment Share on other sites More sharing options...
BruceBe Posted February 17, 2021 Share Posted February 17, 2021 VW? VW produced a lot of cars over the years. Link to comment Share on other sites More sharing options...
yellowss7 Posted February 17, 2021 Share Posted February 17, 2021 Sheesh. Nobody. Expects the Spanish Inquisition. Passat?.. 1 Link to comment Share on other sites More sharing options...
BruceBe Posted February 18, 2021 Share Posted February 18, 2021 Mark 2 Golf. -Bruce Link to comment Share on other sites More sharing options...
Blokko Posted March 9, 2021 Share Posted March 9, 2021 I took my first 7 to Arch to get a lowered floor fitted. I was slightly perturbed when they jacked the car up on a forklift truck to work on the underside Link to comment Share on other sites More sharing options...
NSXguy Posted March 26, 2021 Share Posted March 26, 2021 Anyone know which car the anti roll bar /sway bar rubber bushes come from? they have a tr1616 14 stamped on them. I was thinking triumph? but that's just a guess. Link to comment Share on other sites More sharing options...
Vovchandr Posted March 26, 2021 Author Share Posted March 26, 2021 19 minutes ago, NSXguy said: Anyone know which car the anti roll bar /sway bar rubber bushes come from? they have a tr1616 14 stamped on them. I was thinking triumph? but that's just a guess. Oh I'd love to see an answer to that as well. Mine are pretty destroyed from aging. I have a pending order from CCparts for a replacement. Link to comment Share on other sites More sharing options...
NSXguy Posted March 26, 2021 Share Posted March 26, 2021 Also, I recently replaced the tie rod ends with Triumph spitfire tie rod ends. I'm sure it's probably old news to many but i'll post for record anyway- I'm new to the platform and figuring alot of things out along the way. Link to comment Share on other sites More sharing options...
Vovchandr Posted June 13, 2021 Author Share Posted June 13, 2021 Doesn anybody know the source for the square coolant overflow/reservoir tank? Link to comment Share on other sites More sharing options...
yellowss7 Posted June 14, 2021 Share Posted June 14, 2021 It was a Rover metro part I believe. Link to comment Share on other sites More sharing options...
Vovchandr Posted June 14, 2021 Author Share Posted June 14, 2021 20 hours ago, yellowss7 said: It was a Rover metro part I believe. No luck finding it in a Rover Metro so far. Searched by part and engine bay pictures. The CAP appears to be a match for a Mini among other things. Does anybody know what OEM cap with the right spring pressure cross references to? Link to comment Share on other sites More sharing options...
Croc Posted June 15, 2021 Share Posted June 15, 2021 It was a Rover 200/400. This was the POS car that donated most of its parts to a Caterham after a ford. If in doubt default to a Rover 200 part search. Tank-radiator expansion - EAP8713 - Genuine MG Rover | Rimmer Bros You saw off the legs. In case you doubt me here is a post from Blatchat - refer post #4 from Roger ("ECR") Freelander Expansion Tank - Dimensions | Lotus Seven Club (lotus7.club) I would also look at post #10 as an option for a different shape expansion tank as you can then use the current round Freelander bottle. I would look for a Rover 200/400/216/416 cap. For the cap, it likely was also used on a Mini. Rover/MG Group made Minis late in the original form's life. Caterham still sell the caps for your car - its on their parts site - but Rimmer Brothers will be cheaper. Link to comment Share on other sites More sharing options...
Vovchandr Posted August 10, 2022 Author Share Posted August 10, 2022 On 6/15/2021 at 7:43 AM, Croc said: It was a Rover 200/400. This was the POS car that donated most of its parts to a Caterham after a ford. If in doubt default to a Rover 200 part search. Tank-radiator expansion - EAP8713 - Genuine MG Rover | Rimmer Bros You saw off the legs. In case you doubt me here is a post from Blatchat - refer post #4 from Roger ("ECR") Freelander Expansion Tank - Dimensions | Lotus Seven Club (lotus7.club) I would also look at post #10 as an option for a different shape expansion tank as you can then use the current round Freelander bottle. I would look for a Rover 200/400/216/416 cap. For the cap, it likely was also used on a Mini. Rover/MG Group made Minis late in the original form's life. Caterham still sell the caps for your car - its on their parts site - but Rimmer Brothers will be cheaper. @NSXguy that's the answer to your question. Maybe it will help somebody else as well by bumping this. Link to comment Share on other sites More sharing options...
NSXguy Posted August 11, 2022 Share Posted August 11, 2022 3 hours ago, Vovchandr said: @NSXguy that's the answer to your question. Maybe it will help somebody else as well by bumping this. Thanks! looking into this and other stateside options. Link to comment Share on other sites More sharing options...
UglyFast Posted October 7, 2022 Share Posted October 7, 2022 On 2/12/2021 at 6:42 AM, Croc said: Arch still makes the CSR chassis as Caterham cannot do that one in house. Arch can also make replacement chassis if you were unfortunate enough to write yours off as they have the original jigs. Pretty excited about my Arch! 1 Link to comment Share on other sites More sharing options...
GTIspirit Posted October 7, 2022 Share Posted October 7, 2022 On 2/18/2021 at 6:11 PM, BruceBe said: Mark 2 Golf. -Bruce The parking brake self adjusters on the Mk2 Golf rear brake calipers are notoriously problematic. The tip in the VW community is to replace them with the Mk4 aluminum rear calipers, 1J0615424 and 1J0615423. They bolt right up, but the brake line routing is slightly different. Mk4 calipers also use a banjo bolt fitting, instead of a thread in fitting. I could never get the Mk4 brake calipers to work on my Mk2 because the banjo bolt fitting trapped the caliper mounting bolt. Meaning, you'd have to disconnect the lines to replace the pads. Maybe the mounting/routing is different on a Caterham so the lighter Mk4 calipers with improved parking brake self-adjusters would work on a Caterham? 1 Link to comment Share on other sites More sharing options...
MV8 Posted October 7, 2022 Share Posted October 7, 2022 (edited) GTI, sometimes replacement hoses with metal sections of steel tubing are slightly bent. Assuming the hose is mounted the right way round with the lip around the edge of the caliper body, fully tighten the caliper to the upright and the banjo to spec, then tap the metal crimp sleeve with a hammer handle a few times so it just touches the caliper body below the caliper mounting bolt. Edited October 7, 2022 by MV8 Link to comment Share on other sites More sharing options...
