savagete2860 Posted 3 hours ago Posted 3 hours ago I am getting more into tracking my seven and I am going to start participating in time trials as well as (hopefully) attending the USA7s meet at NJMP. This means I have to get dated harnesses, arm restraints, a fire suit, and an FHR device. I actually have the bulk of that list already or on its way, but I am looking to make a few changes. Harnesses Right now I have the standard Caterham harnesses and the sub strap to make it a 5 point. These obviously are not dated so I need to replace them. Before I pull the trigger here, I see companies in the UK sell Caterham specific harnesses, including Caterham themselves. Its not clear to me if those harnesses are actually dated though. I'm not sure how some of these harnesses are "designed specifically for a Caterham" either. I'd also prefer to order something state side for numerous reasons. Can I get any old pull down 6 point harness with bolt in brackets, or will something be weird in the Caterham, like the straps are 50 feet long or something else unexpected that might cause issues? What harnesses do people run here that need FIA dated? I am looking at getting something like one of these https://www.pegasusautoracing.com/productdetails.asp?RecID=34016 https://www.pegasusautoracing.com/productselection.asp?Product=SCH-94530 Then I would also need to get the bolt in style brackets and swap over to those. I actually ordered a set that were one year old so they were 40% off, but they're sewn in brackets with the snap in style so I need to return them Arm Restraints I just ordered these and I think they actually make a lot of sense for our cars (I do enjoy having arms), but I am a little worried about point bys. I am used to giving really obvious point bys which I assume are going to be pretty difficult to do with these. I can probably t-rex a point for a drivers side pass, but not sure about a passenger side pass. A lot of the HPDE organizations I run with do not allow turn signal point bys. Also I am worried the rear wheel fenders will obstruct the view of my restrained point bys as well. Have any of you had issues there? I will know soon enough when I get them in the mail, but I am curious to hear others experiences giving and receiving point bys from a restrained seven driver. FHR Like the arm restraints, this makes sense. Running harnesses, probably a good idea to do what you can to keep your head attached to your neck. I currently have a Simpson Hybrid S from tracking a Lotus Elise with a 3 point belt. Right now, at least with the standard Caterham harnesses, clipping in the rings from the Simpson Hybrid S into the shoulder straps is a real struiggle sometimes, especially when youre running late to the grid. Also, the back of the apparatus hits the seats making it a little uncomfortable. I think I would like to switch to a standard FHR device, but the shoulder strap angle and placement is out of whack on Caterhams woith factory mount points. They supposed to be between 0 and 20 degrees below the shoulders, ideally at 10 degrees and the mounts are supposed to be much closer together. Is it even possible to correct this? What do people do here? Just run at the incorrect angle? If this is a significant hurdle, maybe sticking with the standard mount points and my hybrid S is the best option.
cobra8214 Posted 2 hours ago Posted 2 hours ago I recently did a lot of research on harnesses - I am equally, if not more concerned about safety on the street than on the track, so wanted something that would be great for street driving as well, which was the driving factor for my decision. I decided on the Schroth Profi II 4 pt ASM FE harness, with the sub strap attachment. The plan is to wear the 4 pt harness on the street, and then add in the substrap to make it a 6 pt when on track. This way, I'm covered with a 6 pt harness on the track, and I have a harness for the street that: Is street legal (the FE cam lock makes this so). Probably not a big deal, but I don't want to give any over-zealous policeman around here an excuse to write me a ticket Is easy to put on - I don't have to put on the sub strap every time I want to hop in the car Most importantly, provides protection against both submarining and neck injury. I am concerned about a 4 pt harness making neck injury on the street more likely compared to a 3 pt harness (since your torso is more restrained with a 4 pt), but the ASM component (piece of the shoulder belt that gives way in a crash, allowing one side of your torso to twist forward) helps with this by allowing your torso to move in the event of an accident, reducing stress on the neck.
JohnCh Posted 1 hour ago Posted 1 hour ago Another vote for the Schroth ASM FE. An additional benefit is they allow you to not only get the lap adjustment buckle quite close to the cam lock -- helpful if you have the composite seats -- but you can configure the lap belts as either pull up or pull down. I like pull down on the driver's side because it positions the excess belt material off my lap and I rarely need to adjust them. However, for the passenger side I like the pull up configuration, since I usually have to belt in newbies, and it's much easier to do that from outside the car with the pull up orientation than trying to explain to them how to do it themselves with the pull down style.
Pokey Posted 14 minutes ago Posted 14 minutes ago 2 hours ago, savagete2860 said: Arm Restraints I just ordered these and I think they actually make a lot of sense for our cars (I do enjoy having arms), but I am a little worried about point bys. I am used to giving really obvious point bys which I assume are going to be pretty difficult to do with these. I can probably t-rex a point for a drivers side pass, but not sure about a passenger side pass. A lot of the HPDE organizations I run with do not allow turn signal point bys. Also I am worried the rear wheel fenders will obstruct the view of my restrained point bys as well. Have any of you had issues there? I will know soon enough when I get them in the mail, but I am curious to hear others experiences giving and receiving point bys from a restrained seven driver. FHR Like the arm restraints, this makes sense. Running harnesses, probably a good idea to do what you can to keep your head attached to your neck. I currently have a Simpson Hybrid S from tracking a Lotus Elise with a 3 point belt. Right now, at least with the standard Caterham harnesses, clipping in the rings from the Simpson Hybrid S into the shoulder straps is a real struiggle sometimes, especially when youre running late to the grid. Also, the back of the apparatus hits the seats making it a little uncomfortable. I think I would like to switch to a standard FHR device, but the shoulder strap angle and placement is out of whack on Caterhams woith factory mount points. They supposed to be between 0 and 20 degrees below the shoulders, ideally at 10 degrees and the mounts are supposed to be much closer together. Is it even possible to correct this? What do people do here? Just run at the incorrect angle? If this is a significant hurdle, maybe sticking with the standard mount points and my hybrid S is the best option. I'm still able to point wearing arm restraints. I imagine my hands aren't as noticeable, but I've never had anyone mention an issue seeing me point. For what it is worth, I like the restraint style that has a single loop to attach to the harness. For the head/neck restraint, there is chatter in the UK about having mounting points added by Arch: https://www.google.com/url?sa=t&source=web&rct=j&url=https%3A%2F%2Fwww.academyracer.co.uk%2Fhans-adjustment-arch-motor-manufacturing-co-ltd%2F&ved=0CAEQ1fkOahcKEwj4qcvUycOVAxUAAAAAHQAAAAAQBw&opi=89978449 Makes sense and I am curious as to whether anyone has ever seen a car in the US modified as such? I'm using a NecksGen and the factory mount points.
