Croc
For the heavyweights, here is a Stalker in Florida $32500
Brunton Super Stalker
Built Spring 2011
Florida titled as 1962 Lotus 7
Pontiac 2006 L32 engine w/20K miles
GM Tremec T5
GM 3.42 Torsen rear end
270+ HP 290+Torque
Less than 1500 pounds
Excellent Autocross car-Easy to drive fast
New 1/2013 TOYO R1R tires
No junk parts used.
Well sorted and Reliable.
6000 total miles.
http://fortmyers.craigslist.org/lee/cto/4294127042.html
For the historical buffs here is a 1958 Lotus 7 for $25000.
Not quite sure what to make of the chassis modifications at the rear or even the chassis numbering. Love the ali nosecone.
1958 Lotus 7 open wheel racer
GENERAL:
Model: Lotus 7 Series 1
R or L Hand Drive: Right
Chassis No: None
Reg. No: None
Frame No: L5641763
Years Owned by you: 15+
Last Owner: Deceased
PRESENT SPECIFICATION:-
Engine Type: Austin
Engine Capacity: ? 1200 Head
Engine No: 9C-U-H 42454
Carb(s) Type: SU
Carb. No(s): 2
G/Box Type: Austin 1275
Axle Type: Lotus IRS A26 R004
Axle Ratio: Not Known
Body Colour: Aluminium -- Not Painted
Wheels Type: Wire Knock-Off Spoke 13" Front 15" Rear
Wings Type: None
http://phoenix.craigslist.org/wvl/cto/4344565878.html
Found in San Francisco
2003 Caterham R500 with a Minster K series engine. $50500 And here I was thinking that there would be only 1 person in this country silly enough to want a cheese block engine...there are actually 2! Gorgeous spec car though.
Some of us actually prefer lightness and the Rover K series is definitely light. Maybe due to the cheese holes. :smilielol5: I've spoken with the owner in the past. Definitely a true R500 K from England. That's two of us with Ks that I know of. :driving: Tom
2003 Birkin $20800
Made in South Africa this is one of the highest quality Super 7 Replicas you can buy.
2003 Ford Focus 2.0 EFI Engine with less than 14K miles on it.
Ford T9 5 speed transmission from Quantum Mechanics
Carrera Shocks
Raceline water rail and oil sump.
Emerald ECU
Woody Harris wiring harness.
This car is registered in Calif as a 2006 Birkin - Special Construction Vehicle Calif SB100.
It is exempt from all Calif smog requirements.
http://sfbay.craigslist.org/sby/cto/4339650213.html
The Divas is kind of a blend of se7en and Cobra. But it works for me.
If I can only have one of the above tho, I will take the Rover engined cat and challenge you Duratec guys in the straight line wars:). (I cant believe YellowSS7 hasnt bought this guy's engine yet).
Wow. I don't know how much they are asking for it but those tail light and turn signals look like the same cheap-ass plastic socket garbage that they put on the Superformance S-1. I hope that with all the fine engineering that had to have went into that car, that they at least put more than 30 seconds into the choosing of lights.
Tom
I'm pretty sure that Birkin on ebay sat on the market for a while before selling for a good deal less than the current bid.
I question the sellers use of a "protected bidder/private auction" since Ebay masks the identity of bidders these days.
On another note, anyone wonder like I do who's kit this car started life as?
http://www.ebay.com/itm/231173629252
