manuMatic Posted August 5, 2016 Posted August 5, 2016 I'm still learning about 7s but for some reason, this one stands out to me: http://sfbay.craigslist.org/sby/cto/5718388900.html
Alfonse Posted August 6, 2016 Posted August 6, 2016 It looks nice, although by the pickup it doesn't look like the owner is particular about all their vehicles.
Croc Posted August 6, 2016 Author Posted August 6, 2016 This is the type of ad where you know you don't want to buy sight unseen!
panamericano Posted August 11, 2016 Posted August 11, 2016 First time I saw one of these, I was so impressed. Something a bit different for you track rats. http://bringatrailer.com/listing/mallock-mk-17-u2/ http://13252-presscdn-0-94.pagely.netdna-cdn.com/wp-content/uploads/2016/08/2010-01-01-00.00.00-67-1-940x705.jpg
BlueBDA Posted August 15, 2016 Posted August 15, 2016 http://losangeles.craigslist.org/lgb/cto/5720370907.html No affiliation, but thought this one is worth passing on.
Croc Posted August 20, 2016 Author Posted August 20, 2016 Steve (Bball on here) has a Mallock. Hope to see it one day. Anyway, this track rat has a new toy freshly finished from a 2 year restoration that he desperately wants to try out on track but I have to wait until late September when I can next get out. Cars this week Virtually new 2014 Caterham 270 (so 135 hp thereabouts) at $45800 http://www.ebay.com/itm/Triumph-Other-270-SV-/391525507438?forcerrptr=true&hash=item5b28bd216e:g:EiAAAOSwnQhXpNls&item=391525507438 Looks like Tom at Birkin USA needs to clear the company demonstrator! Nice spec: Quote Wide track front suspension Full independent rear suspension 210 horsepower 2.0 liter Ford Duratec Crower Stage 2 cams AT Power throttle bodies Specialist Components Typhoon ECU with wide band oxygen sensor 5 speed close ratio gearbox 4:11 limited slip rear differential Gaz adjustable dampers Wilwood 4 piston front brakes Clutch Masters aluminum flywheel and clutch Speed Hut custom gauges with GPS speedometer G Force 5 point safety harness Newton fuel filler Full stainless steel fuel lines with AN fittings Light weight 949 Racing 15” X 7” front and 15” X 8” rear wheels Toyo R1R 195/50 front and 225/45 rear tires Tonneau cover Quick release steering wheel Birkini top Full satin black powder coated trim Full width rear diffuser with extended floor pan Hella 5 ¼” headlights Braille 9 ½ pound battery Raceline wet sump oil pan Cockpit heater with 3 speed fan Heated wind screen Color coat clear coat Viper Red paint with a Black stripe and nose band This car is located in Colorado. If you have any questions or would like to arrange a showing or a demonstration ride please e-mail or call Tom at 970-376-5188. http://www.ebay.com/itm/Lotus-Super-Seven-S3-/191937164568?forcerrptr=true&hash=item2cb058b518:g:u2IAAOSwA3tXoU1l&item=191937164568 Where's Jay? - this looks like your ideal spec! 1999 Westfield S1, crossflow, 5 speed. Like the color - Ferrari Faded Yellow? Not sure why you need an engine vent lower right side? The price on this one after many months/years is finally coming down towards a range where it can be considered seriously - now at $27k http://www.ebay.com/itm/Lotus-Super-7-Series-3-/162167705376?forcerrptr=true&hash=item25c1f2cf20:g:QK4AAOSwawpXroju&item=162167705376 1972 Lotus 7 S4 yellow. Another one seemingly around for months/years but at $25k. Long way down from the circa $40k it originally wanted. http://www.ebay.com/itm/Lotus-Super-Seven-S4-/272340996713?forcerrptr=true&hash=item3f68c9d269:g:s~MAAOSw-itXsDQ7&item=272340996713 1961 Lotus 7 S2 in CA. Bidding at $12k currently. Needs some cosmetics - in original condition. The chassis plate is interesting - never seen one filled out like that before. I wonder if that was done for the importation? Quote This is a 1961 Lotus Seven Mark V11 , Right Hand Drive, 4 speed, This baby has been in our family for over 25 years... I have original side panels, current tags, clear pink slip. Quote yes I do drive it. if you have any questions contact me. Thank you for looking http://www.ebay.com/itm/Lotus-Other-/162169407024?forcerrptr=true&hash=item25c20cc630:g:hnAAAOSwHoFXsNG6&item=162169407024 also here http://losangeles.craigslist.org/lgb/cto/5720370907.html 2005 Birkin at $26k in TX Quote 2005 Birkin S3 up for sale. Looking for the perfect track/street car? This car weighs 1234 pound with half a tank of gas, street tires, and the full height windshield. This is a California SB100 car and should be smog exempt in CA. Originally built by MSI / Birkinsport of Vacaville with a their 200hp Zetec. I have had the car since August of 2010 and have enjoyed every minute I have spent behind the wheel. The Birkin is located in Austin, TX and is ready to drive as is on the road or the track. The car is equipped with ITBs, Emerald M3D F.I., Quaife LSD, semi close T-9 gear box. The car is fully sorted and ready to go anywhere or run track sessions long enough to empty the 11 gallon tank. The stock Birkin fuel tank has been modified to run an internal fuel pump and is baffled with check balls eliminate the fuel starvation issues the stock tank was known for. The car comes with the following The car comes with 2 sets of wheels and tires. For the street I have 949 15x7 fronts with 205/50 R888 and the rears are 15x8 running 225/50 R888 The 2nd set of wheels are light weigh multi piece 13 inch Kodiak wheels running Avon ACB10 tires for track use. A new set of sport seats with mounts not installed in car 2 windshields and a 1st gen Caterham wind deflector 3 Roll bars (one new unused stock, one cut up stock and a custom one that is 8 or so inches taller than stock that will allow anyone to pass a broom stick test A Birkini top A unused FuelSafe fuel cell designed and build for MSI A unused and never installed fire system Wind deflectors and storage bag I also have a set of custom hemi jointed radius arms that I have never installed Birkin spare tire carrier http://dallas.craigslist.org/dal/cto/5702197906.html 2013 Caterham R500 in TX with just 294 miles on it for $50k. F1 scheme paintwork. Has anyone called asking for more info on this one? http://austin.craigslist.org/cto/5717861649.html 2007 Brunton Super Storker asking $30k in TX. No photos but 2007 black and white body should be easily findable on the Stalker build forum. Quote Condition: Used Year: 1962 Mileage: 650 Interior Color: Black Make: Replica/Kit Makes Number of Cylinders: 6 Model: Lotus Super 7 - Brunton Stalker - caterham Seven Transmission: Manual Trim: 54,000 Body Type: Convertible Engine: GM 3800 L32 - Supercharged 260HP Warranty: Vehicle does NOT have an existing warranty Drive Type: RWD Vehicle Title: Clear Fuel Type: Gasoline Exterior Color: white For Sale By: Private Seller Lotus S7 replica by Brunton (Super Stalker.) Like new with 650 total miles. Built out in 2007. Supercharged, electronic fuel injected, Buick 3.8L V6 engine with K&N filter, Jet-Hot coated headers and side pipes, 30% overdrive pulley and forged pistons. Engine is professionally balanced, blueprinted, dyno tuned and mapped and produces 269hp and 335 ft. lbs. of torque at the rear wheels. The chassis is a fully welded, powder coated space frame with integral rollbar and detachable six-point roll cage. It has GM four wheel disc brakes, GM clutch, Tremec TKO 600 5-speed transmission and GM (3.42:1) Posi-Trac differential. Fiberglass body is black and white base and clear paint. Aluminum side panels are powder coated black. Powder coated dash has ATM lighted insturments including oil pressure, oil temperature, coolant temperature, 30lb. boost meter, volt meter, 160mph programmable speedometer, 10,000rpm tach, shift light and turnsignal indicator and courtesy lights. Kirky high-back, bolstered bucket seats have 5-point harnesses. American Racing 17"x8" wheels and Falcon Arsenis treet tires (200 durometer.) Spare wheel and tire. This car was professionally built. It is beautiful, lightweight (1640lb. wet,) street legal, crazy fast and never raced. http://phoenix.craigslist.org/evl/cto/5727518779.html Craigslist search is not working properly thanks to Google capping the limit of cities that can be searched. https://searchtempest.zendesk.com/hc/en-us/articles/205166587-The-results-load-slowly- So I bet I am missing lots of cars today.
Croc Posted August 20, 2016 Author Posted August 20, 2016 (edited) Stalker in Albany new york for $22k Quote "Lotus 7" type - Manufactured by Brunton Auto in Clearwater Fla. This isn't your typical Lotus 7 replica packing a basic 4 cylinder motor. No this one has a GM V6 with a supercharger! Not for the timid. Bring a big set of juevos to drive this one at limit & a change of underwear just in case. Tube frame Fiberglass and aluminum body Excellent paint 260hp 3.8L Pontiac L32 GM motor with supercharger 300 ft. lbs of torque S10 rear end T-5 transmission American racing wheels Coil over suspension Disc/front, drums/rear Street legal (all lights, directionals, etc. work as they should) No wet weather gear G-Force 4 point belts 5500 miles http://albany.craigslist.org/cto/5727688566.html ah! here it is with photos in this ad http://syracuse.craigslist.org/cto/5722413472.html Hmmm....1962 Lotus 7 but I guess it is a replica? http://www.usa7s.net/vb/attachment.php?attachmentid=11546&stc=1 Asking $18k http://hickory.craigslist.org/cto/5721119519.html Lotus 7 replica for $19k http://www.usa7s.net/vb/attachment.php?attachmentid=11547&stc=1 https://fortcollins.craigslist.org/cto/5719314552.html Lotus 7 S4 in GM pearl white in CO with BDR is still for sale at $23900 http://denver.craigslist.org/cto/5702728214.html Whizzy's Westfield at $18950 http://tulsa.craigslist.org/cto/5707516223.html Lemmings has a bunch of ads http://www.hemmings.com/classifieds/dealer/caterham/super-7/1843275.html http://www.hemmings.com/classifieds/dealer/lotus/7/1865338.html http://www.hemmings.com/classifieds/dealer/lotus/super-seven/1864119.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1861752.html Gorgeous cars but as with any original Lotus 7 like the above you should make sure you do your homework on originality. http://www.hemmings.com/classifieds/dealer/lotus/super-seven/1857071.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/super-seven/1843916.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1832388.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1827972.html Better photos of the Fantasy Junction car are here http://www.fantasyjunction.com/cars/1892-Lotus-7%20Series%20I-1200cc%20Inline%204-Cyl Edited August 20, 2016 by Croc
MichaelD Posted August 20, 2016 Posted August 20, 2016 "We have just added to our extensive exotic car inventory a beautiful 2014 Caterham Seven 270 in Vintage Green with Black leather interior with just 740 miles. This Seven is loaded with: 1.6 Liter ZTEC engine, 5 speed manual, exterior trim in satin silver, side view mirror, 14" alloy wheels with Avon tires, external battery cutoff switch, 12V accessory outlet between seats, cold weather pack with convertible top and side curtains, side curtains with armrests, heater and more." I thought Zetec exhaust was on the left side???
Black Hole Posted August 20, 2016 Posted August 20, 2016 "I thought Zetec exhaust was on the left side???" Correct - this looks like a Sigma engine. Jay
Black Hole Posted August 20, 2016 Posted August 20, 2016 Where's Jay? - this looks like your ideal spec! Thanks - I talked to Tom about this car. I was thinking of going to look at the car when we are skiing at Breckenridge this winter. While a little too red, that can be fixed. The main concern is CT registration with no catalyst and the title is for a new car and not a classic. May have to take another look.
TheDingo8MyBaby Posted August 21, 2016 Posted August 21, 2016 Croc said: Craigslist search is not working properly thanks to Google capping the limit of cities that can be searched. https://searchtempest.zendesk.com/hc/en-us/articles/205166587-The-results-load-slowly- So I bet I am missing lots of cars today. I've been using the iPhone app "BRZO". For $0.99, it's a really nice search interface
wemtd Posted August 21, 2016 Posted August 21, 2016 Glad to hear you're still looking Jay... be patient and the right car will come along sooner (or build your own a little later) p.
Black Hole Posted August 22, 2016 Posted August 22, 2016 I tried to send you a PM, but it appears your inbox is full. I have a couple of questions for you so can you email me at jayfrankelcomcastnet Thanks wemtd said: Glad to hear you're still looking Jay... be patient and the right car will come along sooner (or build your own a little later) p.
Croc Posted August 27, 2016 Author Posted August 27, 2016 This week's updates BAT listed a CA 2002 zetec Caterham. The comments as always are entertaining - its good to see at least one poster (probably also on this forum) knows what they are talking about! http://www.usa7s.net/vb/attachment.php?attachmentid=11613&stc=1 http://bringatrailer.com/listing/19662002-caterham-super-seven-dedion/ The 1959 L7 S1 is still up for auction here although the mob consensus seems to be building towards its got authenticity issues. http://bringatrailer.com/listing/1959-lotus7-series-one/ 2008 Stalker here at $39k and change http://www.ebay.com/itm/Replica-Kit-Makes-Brunton-Superstalker-Super-Stalker-/331947532648?forcerrptr=true&hash=item4d499d6168:g:GRsAAOSwOVpXYp8V&item=331947532648 Heres a new one this week. 2005 Ultralite in yellow with blue nose band and bonnet stripe. VTEC engine and gearbox. Being sold by a dealer in St Charles MO so be ready for over the top breathlessness in the ad. Comes with an "aloominum" trailer. Presents very well. Quote 2005 WCM Ultralite S2K has a 2.0 Liter 16 Valve Inline 4 Cylinder (240 HP/153 Lb Ft), Honda S2000 6 Speed Transmission, 1,240 Lbs (1 HP per 5.16 Lbs), Aluminum Body Panels Over Tubular Body/ Chassis, Wildwood Drilled/Slotted Rotors w/ 4 Piston Calipers, Fully Adjustable Pedal Assembly, Fits a 6'2" Driver w/ No Problem, Aluminum Coil Over Shocks, Subaru WRX Limited Slip Rear, 17" x 7" Aluminum Wheels, Aluminum Radiator w/ Two 1" Coves, Aircraft Grade Hardware & Locknuts, Detachable Steering Wheel, 3" 5 Point Harnesses, Aluminum Racing Seats, Front & Rear Crash Zones, Canvas Tonneau Cover http://dealeraccelerate-all.s3.amazonaws.com/fastlane/images/1/1/1/5/1115/37496_ec028869bc_low_res.jpg Asking $29995 http://www.ebay.com/itm/Other-Makes-Ultralite-S2K-/351821084642?forcerrptr=true&hash=item51ea2bb7e2:g:I3wAAOSwIgNXwFyB&item=351821084642 One of the more discreet Stalkers out there is up for sale (no Shane, not you). 2007 kit finished 2010. http://www.usa7s.net/vb/attachment.php?attachmentid=11615&stc=1 Supercharged V6, T5, Detroit Locker diff, bolt on cage, bikini top for road. Well set up for autox. A subtle discreet color scheme comes standard. Asking $22k BIN. http://www.ebay.com/itm/Lotus-Super-Seven-/191953264337?forcerrptr=true&hash=item2cb14e5ed1:g:M9cAAOSwdzVXvbOn&item=191953264337 Anyone want a slightly slower Seven? http://www.ebay.com/itm/Austin-Seven-/232058833160?forcerrptr=true&hash=item3607c8c908:g:CMAAAOSw9NdXvemL&item=232058833160 Lotus 7 S4 in yellow at a consignment dealer (which explains why I see it each week...) $25k http://www.ebay.com/itm/Lotus-Super-Seven-S4-/282144405225?forcerrptr=true&hash=item41b11df6e9:g:v9wAAOSwHoFXuXOE&item=282144405225 Another yellow dealer one - Westfield pre-lit this time. $30k http://www.ebay.com/itm/Lotus-Super-7-Series-3-/162167705376?forcerrptr=true&hash=item25c1f2cf20:g:E0cAAOSwMtxXvdAT&item=162167705376 The Stalker group is out today. Purple one here. Quote This isn't your typical Lotus 7 replica packing a basic 4 cylinder motor. No this one has a GM V6 with a supercharger! Not for the timid. Bring a big set of juevos to drive this one at limit & a change of underwear just in case. Ooooh! trash talking! My type of seller! Has to be the first time someone ever said you need a big set of balls to drive a Buick engined car? Change of underwear I get - I drove a Hertz Buick once and it wandered all over the road like a Crown Victoria taxi. Quote Titled as a 1989 Special Construction Tube frame Fiberglass and aluminum body Excellent paint, some small stone chips on rear fenders 260hp 3.8L Pontiac L32 GM motor with supercharger 300 ft. lbs of torque S10 rear end T-5 transmissionWilwood master cylinders Fuel cell American racing wheels Coil over suspension Disc/front, drums/rear Street legal (all lights, directionals, etc. work as they should) No wet weather gear G-Force 4 point belts Located in NY State. Bid at $6k with 2 days to run and only 8 bids and no watchers. http://www.ebay.com/itm/Lotus-Other-/182255233746?forcerrptr=true&hash=item2a6f422ad2:g:vMIAAOSw0UdXreSB&item=182255233746 2005 Birkin at $23k in TX http://dallas.craigslist.org/dal/cto/5702197906.html 1978 Caterham in CA. 1600 crossflow. Full weather kit included plus a leather flying helmet and goggles. Asking $27500 https://sfbay.craigslist.org/pen/cto/5744214130.html?lang=tl 2011 Lotus T128 F1 car with 2013 Caterham body Quote I am looking to either sell or trade my authentic 2011 Lotus T128 ex-race car turned show car with a 2013 Caterham body. This is the newest retired F1 car in the US! Feel free to email me with any questions or trade offers. This vehicle does not have an engine. Technical specifications Chassis carbon-fibre and honeycomb composite monocoque Suspension (front) carbon-fibre Suspension (rear) carbon-fibre Transmission Red Bull Technologies Seven-speed semi-automatic gearbox with reverse gear Weight 640 kg (1,411 lb) (including driver) Fuel Total Tyres Pirelli P Zero BBS Wheels (front and rear): 13" The Lotus T128,[1] known prior to its launch by its project number TL11, is a Formula One motor racing car designed by Mike Gascoyne for Team Lotus for use in the 2011 Formula One season. 2011 saw the car abandon its Cosworth engine in favour of one developed by Renault. The T128 was launched online on 31 January 2011.[2] Team Lotus retained an unchanged driver lineup in 2011, with 2010 drivers Heikki Kovalainen and Jarno Trulli racing the T128. It was confirmed that the team would start the season without the Kinetic Energy Recovery System, but senior figures suggested they would adopt it if the car proved successful,[3] however the team continued for the rest of the 2011 season without KERS. The team changed from the Cosworth CA2010 engine used in 2010 to the Renault RS27 series, as well as exchanging a transmission developed by X-Trac to one built by Red Bull Technologies. The design of the T128 also incorporated a "bladed" roller similar to the one developed by Mercedes in 2010, but thicker and with sturdier air intakes to conform with FIA regulations. Some clone chassis been for sale for years http://huntsville.craigslist.org/cto/5679160416.html Anyone need an exhaust for a Superformance S1? http://columbus.craigslist.org/pts/5710251279.html Lotus 7 S4 in GM pearl white with BDR $23900 http://denver.craigslist.org/cto/5702728214.html It says it is a 1962 Lotus 7 but some details make it clear to me it is a replica of some kind. Not sure of the maker? Asking $18k http://hickory.craigslist.org/cto/5721119519.html Whizzy's Westfield is here $18950 http://tulsa.craigslist.org/cto/5707516223.html
Croc Posted August 27, 2016 Author Posted August 27, 2016 (edited) A bunch of cars on Hemmings although their format does not remove their cars once sold so some of these may no longer be available. http://www.hemmings.com/classifieds/dealer/caterham/super-7/1843275.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/super-seven/1868023.html http://www.hemmings.com/classifieds/dealer/lotus/7/1865338.html http://www.hemmings.com/classifieds/dealer/lotus/super-seven/1864119.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1861752.html http://www.hemmings.com/classifieds/dealer/lotus/super-seven/1857071.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/super-seven/1843916.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1832388.html http://www.hemmings.com/classifieds/cars-for-sale/lotus/7/1827972.html Classiccars.com also has a few https://classiccars.com/listings/view/715384/1969-lotus-seven-for-sale-in-spokane-washington-99208 plus this one. Is this the latest Stalker iteration with more integrated rounded body? EDITED TO ADD: no its not. Asking $26500 https://classiccars.com/listings/view/892840/1957-lotus-super-seven-replica-for-sale-in-gladstone-oregon-97027 The rear end shot almost is Cobra replica type? Quote Chassis: 1.25” Square Tubing welded triangular space frame Powder Coated. Frame has been reinforced to accept all mechanical bolt on parts and resists torque twisting. It also provides driver and passenger protection including multiple tube side impact protection. Steel firewall. Battery and Fuel Cell mount within the space frame Front Suspension: Mustang II Spindles, Dual A-arms, manual rack & pinion steering, QA1 adjustable coil over shocks and safety steering column. Rear suspension: Live axle with dual 36” trailing links on both sides. Trailing links also add to the side impact protection. Differential located by horizontal Panhard bar, QA1 adjustable coil over shocks. Breaks: Four Wheel Disc Breaks: Ford Rotors with Corvette Calipers Willwood Master Cylinder, Stainless Break Lines. Willwood Clutch & Break Pedals. Bushings: Nylon bushings are used to mount all moving suspension components. Cooling: All Aluminum high capacity custom built “B-Cool” radiator. High Output Aluminum Water Pump Under body custom air scoop feeding air to the Electric push fan. Pull fan is racing type. Large capacity Oil Cooler. Engine, Trans. Differential: Powered by a Small Block 350 Chevy supplied by “Blue Print Engine” 385 HP, 409 Torque measured at flywheel. MSD Ignition & Distributor, 4-barrel Edelbrock Carb, Holly Electric Fuel Pump, braided fuel lines Transmission is custom built T-5 (five speed with Hurst shifter), Ram Clutch with McCloud throw out bearing & shatter-proof bell housing, Drive shaft, custom built with grease fittings on U-Joints, Rear is 8.8 Ford Trac-Lock with custom racing axles,Hi-torque Mini-starter motor, Racing Alternator, Exhaust: All Ceramic coated: block hugger headers, custom stainless exhaust pipes & dual stainless cats. Mufflers are chrome. Can anyone identify this one? Edited August 27, 2016 by Croc
DeanD3W Posted August 27, 2016 Posted August 27, 2016 I think that's a Diva Roadster. Their web site isn't up anymore, but I found this http://www.mrkitcar.com/mrkitcar/Car.aspx?CarID=41 Dean
xcarguy Posted August 27, 2016 Posted August 27, 2016 Croc said: One of the more discreet Stalkers out there is up for sale (no Shane, not you). 2007 kit finished 2010. http://www.usa7s.net/vb/attachment.php?attachmentid=11615&stc=1 Mine's still a trailer queen, but it's keeping good company these days.
hollywood2311 Posted August 30, 2016 Posted August 30, 2016 Seriously thinking about that green Caterham on BaT. Wife might murder me, but at least I'd die happy. Might have to sell my Fiesta ST daily driver and drive my 2000 XJ Cherokee in order to get it though.
Kitcat Posted August 30, 2016 Posted August 30, 2016 Current price on that car is way low. If it goes for under $22K I wld consider it a steal. Esp since another poster on BAT says he drove it recently and it was a solid car. My standard refrain is the only thing better than a new Caterham is a well used one (because all the bugs have been worked out). As we all have posted many times, se7ens make poor daily drivers so the Jeep may have to serve that purpose.
Croc Posted August 30, 2016 Author Posted August 30, 2016 I agree on value Kitcat but I do have some open questions on the BAT Caterham that have not yet been answered: 1) How is it titled (year/description) and is it clean? 2) Who did the front end repair and exactly what was done? (e.g. replace steering column, wishbones, etc) All the other noise around cycle wings out of place, shoe size, "eccenctric wheel arches", etc is irrelevant - you can reposition those yourself. You cannot fix a bad front end repair or salvage title as easily. Sort of surprised the BAT format has not surfaced that detail already?
