xcarguy Posted October 25, 2014 Posted October 25, 2014 Croc said: This weekends round up of cars . . . . . Thanks, Mike. That went well with the mornin' coffee. The Storker looks new; never seen that one before. I wonder if the VW comes with jumper cables and a cocktail bar? :cheers:
JohnCh Posted October 25, 2014 Posted October 25, 2014 Croc said: In nursing home beige, it has around the same amount of fiberglass as a Westfield. Owner says he cruises at 60-65mph and gets 17mph so its about the same as JohnCH and his Westfield. Probably goes around corners better though! :seeya: Sadly that's more likely down to driver (in)ability on my part, than it is to differences between the vehicles -John
BusaNostra Posted October 25, 2014 Posted October 25, 2014 Thanks croc for taking care my ad --- I have 2 doz of calls but all BS. I'm going to try craiglists first -- i will try ebay pretty soon. If my eye correction surgery is successful, I will probably keep it.
Croc Posted October 25, 2014 Author Posted October 25, 2014 Hi Busa - I hope the op works and you get to keep your car! :cheers:
GunshipDriver Posted October 31, 2014 Posted October 31, 2014 Here is the link for my WCM for sale: http://www.ebay.com/itm/171524580542?forcerRptr=true&item=171524580542&viewitem= Moving overseas and can't take it with me. Starting at $20k with no reserve.
Croc Posted November 1, 2014 Author Posted November 1, 2014 (edited) So its Saturday morning, pissing down rain here, morning cup, sore broken foot, shingles and looking for a distraction....lets see if I can spend money for someone! GunshipDriver gets my vote for ad of the week with his WCM Ultralite S2K for sale at an amazingly good price for the value offered. http://www.ebay.com/itm/Lotus-Super-Seven-WCM-Ultralite-S2K-WCM-Ultralite-S2K-Lotus-Super-Seven-7-Caterham-CSR-Clone-0-60-in-/171524580542?forcerrptr=true&hash=item27efa964be&item=171524580542&pt=US_Cars_Trucks Quote Ultralite S2K Ultralite S2K Specifications Place Order for the Ultralite S2K Now Engine Honda S2000 2L 16 valve DOHC V-Tec™ Aluminum In-Line 4 Cylinder Horsepower 240 @ 8300 rpm Torque 153 lb-ft @ 7500 rpm Displacement (cc/cu.in.) 1997/121.9 Weight 1240 lbs / 524 kg 458 HP per ton (1000 kg) 1 HP per 5.16 lbs / 2.18 kg Transmission Honda S2000 close ratio 6 speed 0-60mph/98kmh 3.5 sec Wheel base 88" / 223,5 cm Track front 59.5" / 131.3 cm Track rear 61" / 155 cm Height 33" / 84 cm Length 124" / 315 cm Width 68" / 173 cm Turning circle 26' / 8 m Wheels 17" x 7" aluminum front 225/45 * 17 rear 245/45 * 17 Brakes Front 12" drilled solid rotors, with forged alum. 4 piston calipers Back 10.5" solid rotors, with forged alum. 4 piston calipers 60 to 0 mph in 100 feet Fully adjustable pedal assembly Steering Turns lock to lock: 2.75 Suspension Shocks: aluminum coil overs Rear: Subaru WRX with Limites Slip centers, hubs and axles 10 bars IRS differential Cooling Radiator: aluminum with two 1" cores Coolant recovery system Safety features In chassis integrated Roll Bar (not bolted) Master battery cut-off on dash Aircraft grade hardware and locknuts Detachable steering wheel Seats and carpet marine grade flame retardent Aluminum racing seats with 3" 5 point harness Crash zones front and rear Center backbone and dash panel bracing Drive shaft loop LED taillights Chassis material 1" X 16 ga. round and square DOM and 1-1/2" X .095 DOM Powdercoated A 1995 Westfield, registered as a 1965 in CT. 1700cc crossflow, T9 5 speed. A Bob Yarwood built car according to the owner. Very impressive looking interior from the photos. Only 2050 odd miles according to the ad. Bidding at $17100 so far and reserve not met. No BIN price. Bidding history looks interesting. http://www.ebay.com/itm/Other-Makes-Westfield-Lotus-Seven-SEi-Westfield-SEi-Lotus-Seven-Built-in-1995-Registered-as-a-1965-/171522275081?forcerrptr=true&hash=item27ef863709&item=171522275081&pt=US_Cars_Trucks A repeat visitor - 2002 Birkin in GA. Yellow with black (or dark green?) wings. 2L Zetec with a T9 5 speed, 11000 miles, skyscraper scaffolding roll bar with a USA7s sticker - just what every forum member needs. This is a re-list so I guess he missed reserve before. $10000 current bid not at reserve and no BIN. http://www.ebay.com/itm/Lotus-Super-Seven-2002-birkin-factory-built-version-of-1967-lotus-super-seven-ford-zetec-engine-/251698953900?forcerrptr=true&hash=item3a9a6d3eac&item=251698953900&pt=US_Cars_Trucks Here is a bump for Busa's Westfield previously advertized http://newyork.craigslist.org/fct/cto/4734313125.html Some of the past Locost basket case chassis projects are still out there - no point in re-listing those. This is a re-list but it has enough potential to justify it - CMC Locost stage II roller with lots of bits for it. $7000 http://miami.craigslist.org/mdc/cto/4732177967.html Back again, a 1962 Lotus Seven S2 asking $38500 http://rockies.craigslist.org/cto/4685355300.html And a gaggle of Caterhams that have been seen before but are not selling for reasons you can work out: 2001 Caterham $38500 - 500 miles on the clock. Red stripe over white. http://sfbay.craigslist.org/nby/cto/4736386992.html 2013 Caterham CSR $79500 Caterham F1 team livery - probably not a proud moment for a new buyer... http://sfbay.craigslist.org/nby/cto/4736386270.html 1984 Caterham - red with clams. Been for sale off and on for at least a year now. Asking $24500. Crossflow, 4 speed, right hand drive. http://sfbay.craigslist.org/nby/cto/4736387449.html 2003 Caterham Superlight R - Zetec in yellow. Asking $48500 http://sfbay.craigslist.org/nby/cto/4736385932.html Wire wheel has a yellow 2009 Birkin for sale at $24900 http://wirewheel.com/1967-2009-Birkin-S3.html Daily Turismo has a Locost race car for sale at $15k. 2L Duratec with Miata 5 speed, registered for the road in PA. I like the Beetle tail lights! http://www.dailyturismo.com/2014/10/lotus-se7en.html And just so the Storker guys are not left out, back again is a "1962" Brunton Sooper Stalker asking $39500. 3.8L V6 with soopercharger. 269 RWHP weighing in at a porky 1640 pounds. Comes with a new looking Hallmark trailer which is a good sweetener to this deal. http://www.race-cars.com/carsales/lotus/1414030674/1414030674ss.htm Edited November 1, 2014 by Croc
a.moore Posted November 1, 2014 Posted November 1, 2014 Croc said: Daily Turismo has a Locost race car for sale at $15k. 2L Duratec with Miata 5 speed, registered for the road in PA. I like the Beetle tail lights! [url=http://www.dailyturismo.com/2014/10/lotus-se7en.html][/url]http://www.dailyturismo.com/2014/10/lotus-se7en.html Hey I had one that looked just like that..... It sold last week. (Thanks for liking the tail lights - not many people seemed to!)
xcarguy Posted November 1, 2014 Posted November 1, 2014 Croc said: And just so the Storker guys are not left out, back again is a "1962" Brunton Sooper Stalker asking $39500. 3.8L V6 with soopercharger. 269 RWHP weighing in at a porky 1640 pounds. Comes with a new looking Hallmark trailer which is a good sweetener to this deal. http://www.race-cars.com/carsales/lotus/1414030674/1414030674ss.htm A Storker that's a porker, but with lots o' torque'r. :jester:
Croc Posted November 1, 2014 Author Posted November 1, 2014 a.moore said: Hey I had one that looked just like that..... It sold last week. (Thanks for liking the tail lights - not many people seemed to!) Andrew - is...errr....was that yours? What are you going to do now?
a.moore Posted November 1, 2014 Posted November 1, 2014 Yes it was Croc. The new owner is planning to also use it for autocrossing so it'll be happy in its natural habitat. I'm down to the Sprite to vintage race. I caught the wheel to wheel bug and decided to concentrate on that for awhile. Sadly I only put a few hundred miles on the Locost this year. I'm guessing another 7 will be in the books at some point - just not sure what flavor it will be.
BusaNostra Posted November 2, 2014 Posted November 2, 2014 (edited) Was not able to sleep last night.....very sad. Croc, I sold my car. Thank you for everything --- & for all the gear head guys here !! Edited November 2, 2014 by BusaNostra
Kitcat Posted November 2, 2014 Posted November 2, 2014 Let the next adventure begin! Yours was one of the nicest out there, someone got very lucky!
Croc Posted November 2, 2014 Author Posted November 2, 2014 BusaNostra said: Was not able to sleep last night.....very sad. Croc, I sold my car. Thank you for everything --- & for all the gear head guys here !! It has to be mixed emotions - I can feel the pain. May it all work out for the best and you regain your eyesight! :cheers:
speedwagon Posted November 3, 2014 Posted November 3, 2014 Busa; Best wishes from me. Igot lucky several years ago and wish the same good luck to you. john
BusaNostra Posted November 3, 2014 Posted November 3, 2014 (edited) Oh.....lastly I paid my last membership for 1 more year so you guys can BS ALL YEAR LONG! HAHAHAHAHAHAHA! but seriously....i hope everybody in good health & safe racing. Hopefully my eye gets better and go back for another project.....I will be back. I hope it will be a good project next time. Edited November 3, 2014 by BusaNostra
Paul Hill Posted November 8, 2014 Posted November 8, 2014 Hey Croc...you're late! Where is my Saturday morning read????
Anaximander Posted November 8, 2014 Posted November 8, 2014 Paul Hill said: Hey Croc...you're late! Where is my Saturday morning read???? + 1 :toetap05:
xcarguy Posted November 8, 2014 Posted November 8, 2014 Paul Hill said: Hey Croc...you're late! Where is my Saturday morning read???? Astro Bob said: + 1 :toetap05: Yeah . . . . what they said. :toetap05: . . . . . My coffee is geting cold. :cuss:
