SENC started following Series 2 brake shoes?
Assuming you have the Standard 10 rear axle and brakes, the following link to a resource in the library here should be helpful. As Scotticus recommended, Ken Gray at Dave Bean may be a very helpful US resource. As may Ray at Rzd Enterprises. But if neither have what you need, Google around for Standard 10 resources in the UK - there is a Std 10 club that is quite useful. When I replaced mine a few years ago, new old stock was readily available - though I don't remember if through one of the above resources or through ebay. Also check Kelvedon, SJS, and TTR. If you have a different rear axle, you may need to find alternate resources.
CBuff started following Main beam wiring
https://www.caterhamlotus7.club/forums/topic/261100-headlight-dipped-and-main-beam-problems/ this may give you some ideas on where to look. Although it’s likely a bit different wiring layout. maybe use a tracer to find where the cut out is happening. https://a.co/d/07OC6834
antonelo1968 joined the community
ketonovaketousa joined the community
TorqueSpec started following Main beam wiring
Hey all - nearing the end of my 360R build and am trying to sort out an issue with the main beams (high beams). Dipped (low beams) headlights work with the switch. But when I turn on the main beams, either with the dedicated switch or the flash to pass switch, the main beams do NOT come on, though the dashboard indicator does come on. Here is what I’ve tested: - Headlight relay works - Main beam fuse is fine - multi meter shows power at the fuse and at the relay as expected. Somewhere along the line, power is being interrupted to the headlights. Given neither main beam works and neither switch works, I’m guessing a connection somewhere. Thanks in advance for any thoughts. Full build can be found in the build threads…
IamScotticus started following WTB Crossflow Imperial Front Clam Wing & Lamp Brackets , Series 2 brake shoes? and WTB S2 RHD Park Brake
Tim, you have to go to the Triumph guys for the car that used the 7" (Stanpart) Standard 10 ,TR 10, Herald axle and shop for those parts. There are many here who have S2s who could give a quick answer. I hope they do. Tony wheel writes, "The series 2 use the cheaper but similarly sized axle from the standard triumph, eight, ten and companion range of cars , which was almost out of production by 1960. Axle supplies, though , lasted for another eight years." If that is what you have. Rear brakes may have been changed out to suit the 7 and another owner may have so checking that is something. I reccomend pulling a drum and measuring the inner diameter and brake shoe width. Get any part numbers off the shoes, drum back plate, drum, and axle. An interesting factoid, a Standard 10 axle from the 60s still has a lot of part interchangeability with the Ital/Marina axles of the 80s. I will look for the info for the Triumph Standard 10 brakes. Another thing, what you find will not likely have the correct shoe compound. Shaving down the middle of the shoes may help prevent lockup. Here is a relining specialist https://porterfield-brakes.com/manufacturer/brake-shoes/ From Tony Weale Per Weale, rear brake shoe PN for 60-68 S2 Standard Axle is "MGR21", which may be an early Caterham catalog PN. Per the Caterham Lotus 7 S2,3&4 Service Manual reprint, Section J 10, Rear shoe PN for "M.S.1"= "120131", which may be for S1 Metropolitan axle. Then M.S.3 =8260. Unfortunately in the illustrated key to axle components list, he brake shoe PN is not listed, sec H 5. But it would be a Lotus PN. The Dave Bean catalog gives this You may want to call Ken @(209) 754-5802 I will update this post with new info.
Need the brake handle and cable please
Considered, but I hope for smaller so as not to obstruct flow to radiator
Wayne, thanks for the quick reply. I do have a shipping drop in Buffalo NY or they could go to a friend in PA. As to selecting a shipper, I don’t have a clue. The key would be the packaging. My experiences with having delivery companies pack have not been overly positive. If there is anyone one you could recommend, it would be miles better than my guessing. Regards, John
Looks that way to my eye, too.
Any chance you left out that it's fitted with lowered floors?
williamwashere started following Photo of your car you took today
williamwashere replied to Xhilr8n's topic in General Sevens Discussion
Well, This supercar like performing Stalker XL and newly painted trailer at this time is no longer for sale. I had a trailer repair company address the rusty metal bits and then had them repaint the trailer in the flat black specialty bonding paint. It is time to enjoy it on blats and take it autocrossing in the XU class (street unlimited with DOT 200 tires) of SCCA. -
Before Harbor Freight trip, it was cars and coffee... Hey, we're all Ford-powered! I was really surprised to see a 620R at the gathering as well! 19504739-3159-4043-AF40-D2215D8D32EA_1_201_a.heic
Doug refers to Caterham as ultra focused sports car 4:32 in the video
Xhilr8n started following Europas that have graced our garages, as well as the Sevens
The “Picture I took of my car today” thread revealed that some of us have shared time with a Europa. Here’s Black Beauty 3841R again. Brought her home on my 55th birthday. Dad owned some Dodge and Plymouth dealerships back in the muscle car days. Once when I was about 20 I was out with Dad buying cars. We went to a Ford dealer somewhere and there sat a perfect JPS. Dad knew that was my dream car. And that I knew he could buy it for me. We were there to buy cars, but cars to sell for profit. Dad said, and I told this at his funeral. “You’ll have to do that for yourself son”. It took 35 years but it came true. Thank you Dad for helping me believe it could happen. There are other stories with this wonderful little car. I am sure that everyone who posts here about their Europa wishes they knew where she was now. I titled this including that we have had a Seven in our garage at some point too. So the thread might not get scarce so quickly
- 3
Sorry, we're getting a little off topic here but I had to join in. Our 1973 TCS (registered as a ’74) was yellow. After a Jeep Cherokee ran a red light and drove over the front end it spent a year in the body shop. During that time I decided to have the colour changed to red. By the time it was finished we had become a family of four. So we sold it to a young mechanic who lived in Toronto. Years later he decided to strip it down to restore/repair/modify it. I’m sure I saw it up for sale as a stalled project a couple or three decades ago. I have no idea if/when it sold or where it is today. I’d like another one but I’m very picky about them now having learned all the problems that came with them after owning one.
COOL JPS!! I loved how Lotus had the nerve to charge ~$100 for the black paint, and admit that they had to do extra sanding of the top, so the waves in the 'glas didn't show! Here's a couple of pics of my old Europa TC - (now living in Holland!) --Bob
I see in your signature, that you & I have a lot in common - I had a '72 Europa Twincam for 21 years. Sold it in 2001, due to lack of garage space. Replaced it in 2007 with an Elise. Added a Seven in 2015. Enjoying both now, immensely! --Bob Collum
A few pictures from our East Coast Lotus Meet - we had FOUR Sevens at Summit Point Raceway... We did several 'touring' laps, during a break in the racing action. A GREAT TIME! --Bob Collum
Could someone with this stuff in their head tell me the specification for the brake shoes for a 1962 Series 2 America? They appear very ordinary, but as usual the parts dealers name the more common cars that use them but not the Lotus Seven. Thanks.
Posts like this should be illegal:).
walstartechnology joined the community
harmoniausaa joined the community
For Sale: Race-Ready 2005 Caterham Seven (SV Chassis/2.3L Cosworth)
BruceBe replied to tozkarao's topic in Cars For Sale
Car has a bunch of stuff not listed in the ad: Tracsport diff (3.91:1) Tracsport racing 5-speed gearbox with all the upgrades (0.87 5th gear) 420R Race springs/dampers Rear race brake upgrade (twin piston AP; 10" discs; prop valve) New MBE 9M4 ECU w/original Cosworth tune and 7K RPM limit New clutch/pressure-plate Cheers, -Bruce -
2024 Caterham 620R. S3. NOT SV(large chasis) The ultimate in high performance Caterham Super 7s. 1200 miles. not tracked. Equipped with 310BHP supercharged motor. Dry sumped motor, huge radiator, oil cooler. Oil cooler for the supercharger and intercooler. 6 Speed Sadev sequential gearbox. Aluminum Bilstein race shocks. Aero front wishbones. 4 piston front calipers with vented discs. Track day exhaust system. Carbon vinyl boot cover.Clear lens pack. Full weather equipment. Vintage Green with Luminous Yellow stripes. Carbon fiber front and rear fenders. Carbon fiber seats with padding. Options include: Heater, Plumbed in fire suppression system, Quick release Momo steering wheel, track day roll bar, LED headlamps, battery master switch, map pocket. Caterham factory Indoor and out door covers. The car is perfect and like new inside and out. New Aluma 14 foot tilt trailer. chassis number: 77105. This is the last Caterham built for the USA at the old Dartford factory so a very historic car. The car is titled in Oregon as 1957 Caterham. This car is RHD. 620s are only suppled in RHD. $86,000. Car can be sold without trailer.
