Looking for a pair of Caterham Fiberglass race seats to replace my leather seats. Long shot but figured I would ask.
Blipshift, a "Crowdsourced car shirts, apparel, and accessories" site has a 7 shirt available for the next few hours. The way blipshift works is that people submit designs. Chosen designs are made into swag that is available for a limited time, usually a few days, and the artist gets a cut of every shirt made. Blipshift had had multiple 7 related shirts in the past, and this one is currently available for the next 17 hours. https://www.blipshift.com/products/yeehaw-2
It's up for a spanner check. The best time to have done that would have been BEFORE hearing new noises. Second best time is now, right? On the plus side, look forward to a checklist of bolts with wrench sizes and torque specs soon... Also, I brushed a metric tonne of bugs out of that radiator, and ordered a straightening tool, let's see how that goes!
Raining pitchforks and hammer handles today. Rainy days and Mondays. Well at least it IS Monday and nobody was planning on autocrossing around the Twin Cities. Probably tomorrow I will look into replacing that battery in the Birkin. The easiest way would be to get the same size battery. Would have to be an AGM to mount it the same way, as it is lying down in there.
Yeah, the fictional TV show was different, They were out in the countryside somewhere. DIdn't even talk to the guards, just ran it at high speed. Another actual escape was folks who manufactured their own balloon and flew out of the country.
christensenjsn joined the community
An actual event during the Cold War. https://www.hagerty.com/media/car-profiles/this-austin-healey-sprite-escaped-east-germany-twice/
I recall an episode of Run For Your Life wherein two guys ran a border crossing in a sports-racing car (sans rollbar). One guy was crouched down and steering while the other guy was stuffed in backwards holding a mirror and giving directions to the driver. Zoomed past the border guards and under the turnpike.
Caterham 6 speed gearbox for sale / repair
SK400 replied to SK400's topic in Parts For Sale / Wanted
All This gearbox is sold. -
trust is a dirty word. when it pertains to anything that you risk your life with. I always loved the tech inspections as they added to my safety.
Yes but I had to make a periscope in order to drive while hunkered underneath it.
ratty.grasshopper joined the community
Thanks so much. I'd like that, but don't want to inconvenience you. What works best for you? Weekends? I'm retired, so generally available.
Thanks ... and good point!
seroburnnusa joined the community
Nice work, newer blogs like this are helpful to future builders, as Caterham makes lots of small little changes over time so the older blogs can have some confusing/incorrect bits in them. PS I saw a mention of painted bolt heads to ensure they are tight on future checks. Many bolts go through powder coated parts and you can NOT trust a painted line. Just because the bolt hasn't backed out doesn't mean it isn't loose. Prime candidate bolts for this issue are the engine mounts into the block. There are others as well. Bottom line is, on a 7 you need to do proper spanner checks regularly.
- Last week
Austin David replied to Xhilr8n's topic in General Sevens Discussion
And sun, and keeps the heat in for the winter. Zip up and you get weather protection too -
Did get a drier Sunday. Raining when we arrived at the site. Managed to wait out the rain and get annual tech inspection on the Birkin. Then I put the car in the trailer in cse it rained while I walked the course. Not raining when it was time for my first 3-run heat. I was not getting traction on the dodgy surface of Canterbury Park's overflow lot. Ever since they sealcoated this lot, it releases aggregate we call "Canterberries". These tires may wake up with a better surface and warmer temps. When I went to start the engine for the third run, I needed a push start. Cranking slow. After the run, I found a place on the paddock lot higher than my rig. Turned off the engine to see if it would restart. Nope. Pushed it down the hill to my rig. Removed the air filters. Removed the hood. Fired up the F-150 and hooked up the jumper cables. After a while, I was able to start the Birkin. Let the big Ford charge the little Ford for a while. Turned off the Birkin, disconnected the cables and tried to start it again. No go. Hooked up and let the big Ford charge the little Ford again. As time approached for my three runs in the afternoon, I started the Birkin, refitted the hood, reinstalled the air filters, and drove the Birkin to its spot in grid. DIdn't turn off the car until I had completed my runs and driven the car behind my trailer. Winched it in and tied it down. I carried passengers all day. My best was 39.859. FTD was 33.405. Not exactly great. Still was fun. Now I will have to figure out whether the battery is toast or the alternator circuit is not working. My money is on the battery.
Looks great! Curious what the major benefits are. Guessing primarily wind?
Question...I want to find a magnetic plug for the Titan dif casing...is it a M22x1.5 plug? Checked with Steve Perks...it is
Very nice blog and I enjoyed reading it so far. Scott
I had never installed the tonneau cover that came with this car so i put it on and took it out for a spin. I shouldn't have waited so long to try it. Scott
Grady started following Photo of your car you took today
Finished painting and now it has been rainy for 3 weeks, so it is sitting in storage. It has good company though.
Part of owning a Seven is not handing it to a local mechanic. At least the pre-Caterham examples are so simple that it is difficult for me to come up with a scenario where I would. My local mechanic takes very good care of my Miata with my only complaint being the air hammer his resident Neanderthal uses to over-torque my lug nuts. The problems that are a challenge to me, such as 64 year-old Lucas wiring behind the scuttle, would take him just as long to figure out as it has me, and for everything else I have you folks, bless you. Sevens are a learning experience, not just a driving experience. OK, I'll let him mount tires, but onto rims, not onto the Seven.
