  1. Today
  2. Shame to see that SB100 sticker leave CA... pure gold right there. How many SB100 CSRs are there... not many I'd wager.
  3. Yesterday
  4. Black Beauty (her name from before my garage) had the best ergonomics for me of any car I’ve ever driven, even if your feet are skewed a bit to starboard. The layout made great sense, decent luggage allowance and a spare tyre. To my eyes one of the best body designs ever. And arguably the most fun to drive in it’s responsiveness. These pics from LOG 34 in A’ville. Bob Dance checking her out. We’d met him a in 2012 at Classic Lotus in Hethel, after Lotus were the featured marque at Goodwood Festival of Speed. Getting three cars ready to show was a fun day.
  5. I was gonna ask about a "better" app for planning rides, but it got away from me and I just made something. Vibecoded, anyway. The app itself is just planning; actual turn-by-turn routing is Maps or Beeline (or anything that can use GPX export). Who wants to help me test and share feedback? The concept is a fairly straightforward maps (Google maps) experience to add a series of waypoints to build a long route. Once the route is set up, it can be shared, edited, or navigated. Smaller routes (<10 waypoints) can go straight into Google Maps. Each leg from here -> Waypoint can be navigated (click -> send to maps). The whole route can be exported, then imported into Beeline or anything that reads GPX. For Beeline it's a few clicks to create a new ride from the export. Mobile experience is the same, works surprisingly well on a handset. The sample route below should be viewable here: https://route7-prod.web.app/route/Bj6Gm4GZKw3U Message me a gmail address and I can whitelist for editing.
  6. Dang Darren, was hoping to see you with this car in person at least once before it went! Is it at least staying local?
  7. Beautiful car. Enjoy your new ride! When I went to check out an Esprit V8 earlier this year, the owner has a white Europa Special in his side yard, completely taken apart to be restored. The owner also has a Esprit S4 and a Elise. He said the Europa handles the best among all these cars.
  8. Caterham fish and chip run 2026 lots of Caterhams
  9. @Colorado7er Josh, have anything?
  10. It's hard to tell, but the first photo looks like it has lowered floors.
  11. Assuming you have the Standard 10 rear axle and brakes, the following link to a resource in the library here should be helpful. As Scotticus recommended, Ken Gray at Dave Bean may be a very helpful US resource. As may Ray at Rzd Enterprises. But if neither have what you need, Google around for Standard 10 resources in the UK - there is a Std 10 club that is quite useful. When I replaced mine a few years ago, new old stock was readily available - though I don't remember if through one of the above resources or through ebay. Also check Kelvedon, SJS, and TTR. If you have a different rear axle, you may need to find alternate resources.
  12. https://www.caterhamlotus7.club/forums/topic/261100-headlight-dipped-and-main-beam-problems/ this may give you some ideas on where to look. Although it’s likely a bit different wiring layout. maybe use a tracer to find where the cut out is happening. https://a.co/d/07OC6834
  13. Hey all - nearing the end of my 360R build and am trying to sort out an issue with the main beams (high beams). Dipped (low beams) headlights work with the switch. But when I turn on the main beams, either with the dedicated switch or the flash to pass switch, the main beams do NOT come on, though the dashboard indicator does come on. Here is what I’ve tested: - Headlight relay works - Main beam fuse is fine - multi meter shows power at the fuse and at the relay as expected. Somewhere along the line, power is being interrupted to the headlights. Given neither main beam works and neither switch works, I’m guessing a connection somewhere. Thanks in advance for any thoughts. Full build can be found in the build threads…
  14. I'm thankful this sold quickly, saved me from making a terrible decision 😂
  15. Tim, you have to go to the Triumph guys for the cars that used the 7" (Stanpart) Standard 10 ,TR 10 axle and shop for those parts. There are many here who have S2s who could give a quick answer. I hope they do. Tony Weale writes, "The series 2 use the cheaper but similarly sized axle from the standard triumph, eight, ten and companion range of cars , which was almost out of production by 1960. Axle supplies, though , lasted for another eight years." If that is what you have. Rear brakes may have been changed out to suit the 7 and another owner may have so checking that is something. I reccomend pulling a drum and measuring the inner diameter and brake shoe width. Get any part numbers off the shoes, drum back plate, drum, and axle. An interesting factoid, a Standard 10 axle from the 60s still has a lot of part interchangeability with the Ital/Marina axles of the 80s. I will look for the info for the Triumph Standard 10 brakes. Another thing, what you find will not likely have the correct shoe compound. Shaving down the middle of the shoes may help prevent lockup. Here is a relining specialist https://porterfield-brakes.com/manufacturer/brake-shoes/ From Tony Weale Per Weale, rear brake shoe PN for 60-68 S2 Standard Axle is "MGR21", which may be an early Caterham catalog PN. Per the Caterham Lotus 7 S2,3&4 Service Manual reprint, Section J 10, Rear shoe PN for "M.S.1"= "120131", which may be for S1 Metropolitan axle. Then M.S.3 =8260. Unfortunately in the illustrated key to axle components list, he brake shoe PN is not listed, sec H 5. But it would be a Lotus PN. The Dave Bean catalog gives this You may want to call Ken @(209) 754-5802 Must join the club to buy. Excellent prices https://www.standardmotor.club/standard-8-10-etc/braking-system-1/brake-shoes-adjusters-brake-springs-and-fitting-kits So far, it appears that the Spitfire 7" rears are identical to the Standard 10, but the back plate may not be. I don't know if there is any offset issues with springs, etc. I will update this post with new info.
  16. Last week
  17. Need the brake handle and cable please
  18. Need S2&3 wing brackets
  19. Considered, but I hope for smaller so as not to obstruct flow to radiator
  20. Wayne, thanks for the quick reply. I do have a shipping drop in Buffalo NY or they could go to a friend in PA. As to selecting a shipper, I don’t have a clue. The key would be the packaging. My experiences with having delivery companies pack have not been overly positive. If there is anyone one you could recommend, it would be miles better than my guessing. Regards, John
  21. Looks that way to my eye, too.
  22. Any chance you left out that it's fitted with lowered floors?
  23. I didn’t take these, but they’re the first photos I have of my car and I got them today!
  24. Well, This supercar like performing Stalker XL and newly painted trailer at this time is no longer for sale. I had a trailer repair company address the rusty metal bits and then had them repaint the trailer in the flat black specialty bonding paint. It is time to enjoy it on blats and take it autocrossing in the XU class (street unlimited with DOT 200 tires) of SCCA.
  25. Before Harbor Freight trip, it was cars and coffee... Hey, we're all Ford-powered! I was really surprised to see a 620R at the gathering as well! 19504739-3159-4043-AF40-D2215D8D32EA_1_201_a.heic
  26. Doug refers to Caterham as ultra focused sports car 4:32 in the video
  27. The “Picture I took of my car today” thread revealed that some of us have shared time with a Europa. Here’s Black Beauty 3841R again. Brought her home on my 55th birthday. Dad owned some Dodge and Plymouth dealerships back in the muscle car days. Once when I was about 20 I was out with Dad buying cars. We went to a Ford dealer somewhere and there sat a perfect JPS. Dad knew that was my dream car. And that I knew he could buy it for me. We were there to buy cars, but cars to sell for profit. Dad said, and I told this at his funeral. “You’ll have to do that for yourself son”. It took 35 years but it came true. Thank you Dad for helping me believe it could happen. There are other stories with this wonderful little car. I am sure that everyone who posts here about their Europa wishes they knew where she was now. I titled this including that we have had a Seven in our garage at some point too. So the thread might not get scarce so quickly
