JohnCh
Administrators
Everything posted by JohnCh
  1. You're close Greg. I bought the Elan because I've wanted one since I was a kid, almost bought one instead of the Westfield, and wanted something I could use when rain was possible. In fact, that's why I went for the FHC rather than the convertible. Far more practical! From a safety perspective though... Although the Westfield looks far scarier to the casual observer because it's...well, there's not much there, and the Elan looks like a real car, looks are deceiving. The Westfield has steel in key places like the sides, and between the front wheels and the occupants, whereas the Elan is just thin fiberglass everywhere but the central backbone. It is fun though. I took care of the other gear yesterday. Only took a few minutes since this time I knew what I was doing. Hopefully the engine will be fully assembled this weekend and ready to drop in the car. Of course I fully expect to uncover a host of other things I forgot to do during this long layover that will add to the timetable. You may still beat me! -John
  2. Hard to tell if the passenger seat is far more faded or if that's just the lighting in the different photos. I'd be tempted to give both seats a very thorough cleaning and proceed from there. If the fading is inconsistent and it looks like the seats don't match but the fabric is in good shape, I'd investigate upholstery sprays that restore faded cloth, or speak with a good detail shop in your area. That could bring the seats back to a level where they don't stand out even if you decide to go down the polished aluminum path. I'd also speak with the upholstery folks to see what they would charge to properly finish the edges of the crotch belt cut (or practice on an old shirt or rag and see if you can do it yourself.) If $100 makes it look finished, it might be worth it. Regardless, I don't think they look that bad. Someone may decide they want to replace them, but they are at least serviceable. -John
  3. You're the one who brought up spending $1000 to recover the seats, I was just providing another option at a similar cost I do think that spending money to go non-stock, and do so in a way that isn't highly popular, will narrow your market. For better feedback on the seats, it might help to post some photos. The consensus may be they fine as they are, or it could be they are a major problem and you need to do something. My guess is the former, but we really don't have anything to go by. -John
  4. At todays' exchange rate, a new pair of cloth seats from Caterham is -John
  5. Good point Mike, I forgot to account for the Vlad factor. Never mind :jester: -John
  6. Given the difference in offset, any concern about changes to the scrub radius negatively impacting handling? It's not a huge amount, so probably not a big deal, but given the Caterham's best feature is arguably the front end, might be worth considering. -John
  7. Between the Westfield and the Elan, it's hard for my wife to take my car-related safety talk seriously. Yesterday afternoon I wrapped a piece of 600 grit sandpaper around a large shoulder bolt, slipped it through the hole in the cam gear and rolled it around the bench for a while. Worked great and that gear is now a slip fit on the cam. I'll remove the other gear and tackle it today or tomorrow. -John
  8. Good to know you haven't had an issue. SBD Raceline, and Raceco (back when Ammo was still around building Duratecs) all recommend the manual tensioner for engines that spin at high rpms. Outright failures aren't common, but they have seen them, and finding broken teeth in the sump from the plastic ratcheting mechanism is reasonably common. Apparently letting off of the throttle at 7500rpm plus can result in enough chain stretch that the tensioner over tensions the chain resulting in broken teeth or accelerated chain guide wear. It seems like a prudent upgrade. The Kent gears are adjustable in the same sense as the factory units. Unlike the Massive items, they are not marked by degree, which isn't optimal for dyno adjustments. However, I'm fine losing that feature to have that specific cam grind. These things are always a compromise. I agree about tuning on the dyno, but unfortunately I don't have one in my garage. When I asked my wife about buying one, she said something about already having too many tools and that a dyno won't make the kitchen function any better. Hard to argue with that logic. The degree wheel is to ensure that the cams are at a known and safe starting point until I am able to get the car to a dyno facility. Given the current situation out here, I doubt that will happen for quite a while. Thanks, John
  9. Just got off the phone with Kent. Surprise, surprise, they haven't seen this before. He said the gears are heat treated and sometimes can expand a bit during that process, but not to this degree. He suggested attacking it with sandpaper. I'll give that a try this week and see what happens. -John
  10. Way too close to the finish line to throw in the towel. I'm not sure I would characterize the build as rough -- a vortex of WTF moments is more appropriate -- although it still has the potential to turn out that way. If that happens, this thread may become the manual for performing an exorcism. The good news is that I went through the timing exercise before calling a halt due to the cam gear issue, and it was looking good. With cams at the baseline setting, the crank rotated without contacting any valves, dial indicator readings were repeatable, and it appears the machine shop located the keyway in the correct position for the crank position sensor. I even found the alignment tool for the latter, which I was sure I had thrown out. -John
  11. Thanks Shane. I've updated my post with the new emoticon. -John
  12. After unsuccessfully trying to reach Kent's technical department for the past hour (I'm sorry, no one is currently available to take your call), I had an epiphany and did a search. Yep, today is also a holiday in the UK. Do we have a Bollocks emoticon? Edited to add the new Bollocks emoticon -John
  13. Thanks Shane. I must admit I never intended for the thread to become this interesting, or to last this long. :banghead: -John
  14. I removed the timing chain and exhaust side gear from the engine, and put the gear on a DTEC10 cam to make sure my memory of fit was correct. Surprisingly it was. Although tight, the gear was easy to rotate on the cam end by hand. In contrast, the gears are a tight enough fit on the new DTEC20 cams that a gear puller is required to remove them. The calipers showed the problem. The nose of the cam end that forms the stop for the bolt and sticks through the face of the gear (see left side of photo) is .006" wider than the nose on the old cams. Just enough to cause a problem. I think I'll hold off any attempts to enlarge the hole in each gear until I can speak with Kent Cams tomorrow. -John
  15. Head is torqued, cams are installed, and the chain drive assembly with new mechanical chain tensioner is in place. The factory Duratec uses a hydraulic tensioner, which works fine, but can have issues in high rpm engines that result in over tensioning or broken teeth on the plastic ratcheting mechanism. The fix is a simple modification that replaces the plastic ratchet with a threaded metal stop. I ran into a slight issue when attempting to time the cams. Kent uses their own adjustable cam gears that aren't interchangeable with the factory set. For some reason the tolerances between my old gears and new DTEC20 cams are much tighter than with the old DTEC10 cams. They're more of a press fit than a slip fit which means they aren't really adjustable, but I tried anyway until running out of both patience and time. I'll remove the timing chain and cam gears tomorrow, take some measurements, and figure out if lightly sanding the coating might free up enough room. If not, I'll call Kent on Monday. -John
  16. Mike, thanks for posting those. Great reads and photos. I even recognize a couple of the cars from USA2005. Ah, to be on a tour right now, driving like a hooligan on epic roads in the middle of nowhere... -John
  17. FedEx has updated the tracking. It still shows it arrived in Troutdale yesterday around noon, and was in transit to Westminster shortly after, but they have now added that it left Troutdale last night (timestamped more than 8 hours after the In transit to Westminster timestamp) and arrived at my local hub early this morning. If that's true, I should have the head torqued this afternoon. -John
  18. Nice looking pre-lit Westfield just landed on BaT: https://bringatrailer.com/listing/1984-westfield-seven-2/ -John
  19. Thanks, but I've become an expert at pressing the big red Croc...er, Ban button. -John
  20. Good point. Let me get on that. -John
  21. It looks like the torque wrench is delayed. It left Fresno, CA on Monday and was supposed to arrive here today. Checking tracking, it was in Sacramento on Tuesday (good), hung around Sacramento until yesterday (less good), arrived in Troutdale, OR today at lunchtime (good-ish) and is now in transit to Westminster, CO (what???) I'm not great with geography, but even I know that's not on the way to Seattle. Tracking now says it will arrive tomorrow, but the CO mention doesn't inspire confidence. Time for a Martini. -John
  22. Check out Schroth Harnesses with their Flexi technology. They allow you to switch the lap belts between pull up and pull down configuration, and as part of that, you can position the adjuster closer to the buckle. Frees up room and they are very comfortable and well made. -John
  23. Welcome James! The only folks we don't welcome are the se7enless spammers who keep trying to bust their way in here (hence the reason you were initially moderated). I'd love to hear more about the CSR260 project. What are your plans? Any pictures? Cheers, John
  24. Given the rarity of red Westfields in the US and the small size of Menlo Park, you can file this under weird coincidences: My car's original owner had it when he lived in Menlo Park. -John
  25. Wait, that color scheme was intentional?? I thought you were just trying out different paint samples to decide if you wanted to paint it white, or green, or, black, or blue, or... -John
