MV8
Everything posted by MV8
  1. I reread your posts in case I missed something. My understanding is: You've tested the coil in a different position to fire a different plug. You've tested the wire between the ecu and the coil connector and found no issue. But: You have not actually tested the ecu output, plug, or coil connection. If this is the case, before replacing the ECU or changing programming, I suggest: Using a test probe with an led or incandescent handle, put the grounding clip on the battery positive and back probe the ecu control grounding signal at the coil connector while running. Do not test the ecu output without the coil connected. You may need a paper clip to reach the wire side of the connector. If it flashes, continue. Wiggle the wire back and forth. Does it continue to flash regularly? Continue. Replace or swap the plug with another position to see if the problem follows.
  2. Looks like an H&S Seven. Porsche 914 seats. Pinto/ mustang II suspension. Probably $5-10k in pieces.
  3. Allow me to clarify. I'd try moving the wiring around at the connector with it idling and listen if it tries to pickup (intermittent at the pin). Generally, ECU failures isolated to one cylinder are not unheard of.
  4. A larger gap is better if the coil is up to the task. Under boost, gaps may be reduced to have as reliable a spark as NA with the same ignition system.
  5. MV8
    Cooling issues
    Thanks for the pic. The heater circuit cannot handle the amps to wire it per the diagram for both speeds. You need another relay in order to use the heater control for both speeds. I would have put the relay(s) near the fan for less wire to run. If you have no existing hole for another switch and would like to return control of the heater blower, I'm sure a removable mounting tab could be added under the dash panel yet over the tunnel for a hidden switch that you can't kick or hit with your knee, such as a 3-position toggle.
  6. MV8
    Cooling issues
    ATO 12ga fuse holders: https://www.ebay.com/itm/222701017687?hash=item33da03da57:g:RrwAAOSwax5Yucq~&amdata=enc%3AAQAHAAAA4HXq938zEWacFxxo%2BoXAro%2BVA92qXKpfmq%2BMHg568oPD808QBGZlpT%2FnLV8kKq%2BTj02JqWmoA7JWTYXZezWN8Y%2B1vROmudjCOayXoC2e%2BXCWZTX00vpOoH5u4TNFMOMBtKBwNGE2TvYLCz0hvGAOovTpsEyy1VQltgJYQyzDyighuLmw2T0k870DiB1%2BY1YthQ104cy1rFt2zFa05rxJUka0dbr9LzP8hYba%2BMQEqTLim5b9RQaRja019dAqhw3bbWDP9F%2B4OXk3euktOiZQbfWT6OxX83L9rPHM%2BpJU2zNI%7Ctkp%3ABk9SR4imsYvEYA Relays with standard sockets, wire, and spares for $11. (Ignore their instructions. Colors versus pin # are wrong): https://www.ebay.com/itm/193476931588?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D240677%26meid%3D401c0c74c78b44819aa64889a88fa2bc%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D181830593598%26itm%3D193476931588%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeedKnnRecallV1BERT&_trksid=p2047675.c101195.m1851&amdata=cksum%3A193476931588401c0c74c78b44819aa64889a88fa2bc%7Cenc%3AAQAHAAABMEro4ql1SUJ1li87bKftud%252BHNR6f%252BZqZvMWaqvYIq1S%252FWkIBqj9FQDQRu6mAcNzuioXWUR932%252F68tDooavd6O6RvCCK3TeOHWkQHDWVcom10WbzComl5EbRzgV9CqOJMQUuOa5b%252FYT%252F%252Bhj2k145OKDcRDlZcKKZnUOytXBh5Dx3L05aXN6TjgNFcLL4bI0HIubDN7bnbShjZj9ZOJN7mmlH%252BOlDpDw8B%252FSGhZfVKnmZzh2KTv6NBv15S7rILihl08Wij1WPEZeVXuQK5Eq%252BhRzb0Rmlbzi7ae2YoaIu8%252FXUVPWrKHsMEVdgGe0fHpw2OtSLIdN4OVgQGyNQjCC8tjRRwtin4HIqMTRDOhZlJaFJ81aEcM7dlEPP0sV5alacEYGP4uYn%252F4%252FfOjrBOPXefmuc%253D%7Campid%3APL_CLK%7Cclp%3A2047675&epid=11051074327 Heat shrink assortment. Just need a smoking lighter's heat to shrink it: https://www.ebay.com/itm/384790486322?epid=27053026603&hash=item59974cdd32:g:kTYAAOSwTcNiN5SG&amdata=enc%3AAQAHAAAA4LWZf6or4A3ErQXDZXoFvUxEBUV%2FA9us3vMqKtvclrScNrlGL5dhr2jrFVQyooWrnmp3q0PpPWYeAG0Ci0SAVYycZ%2F%2Bt5mqByIJpJwvaAFlscnvnLtZwkjPuGSvdXF1NqlDUbGCZGf4Vn9fxy6T6fm0d9PCDZH4KTIQo821GuE%2BAeMXoh8C%2Fr92rFoSiPQjEFEWVkS7VVV3fKZ2k%2BDG8a25VOHyZ7scxY1K3V9r5mxa2QbHu1AjJjs6lFnaUaQLmeCVRe8rnR4aQXJM5Xp82KQBRq6PWiY3I5RcAMB9L2Bdb%7Ctkp%3ABk9SR7CZwZDEYA
  7. I guess this is all the time and not engine temp or tps dependent. Try moving the plugs around too or simply replacing (check new plug gap). Are you using the rpm drop test of disconnecting each coil while idling? Jiggling the wires where they meet the coil connector since they can get loose? Just fyi: There is an extender for plugs buried in the head in order to use an inline glass tester.
  8. MV8
    Cooling issues
    This is fully manual hi and lo using the heater blower control and powered by the alternator directly, with no mods in the cowl.
  9. MV8
    Cooling issues
    I'm saying if the fan or fan and relay has all power routed through the 10 amp htr fuse, it should blow if the fan is operated at all unless some other voltage source is jumpered on to the circuit that includes the fuel pump and instruments, which could also cause it not to shut off if that source is constant and not switched. However, if that were the case, the instruments and fuel pump would continue to run also. You can use the heater control as a control for fan speed with two relays if pin 30 is powered by another circuit such as the alternator B+ stud. I can draw a circuit like that if you'd like.
  10. MV8
    Cooling issues
    How is it wired exactly? I'm confused about what the benefit of the relay is if all 21 amps flow through the htr control, assuming htr low or high is connected to pins 30 and 86 (15a plus the relay coil), with the other speed direct to the fan motor (6a). The heater shares the same FS2 fuse with the original fuel pump wiring and all the instruments. This should be a 10 amp fuse (very weak htr blower by modern standards) so you must be applying power to pin 30 from somewhere else. I have electrical experience in a many fields but I'm no EE.
  11. MV8
    Cooling issues
    I went ahead and made a diagram as if you had an electric fan originally and just want it to work automatically with the original wiring and thermal fan switch. You need some 12ga "primary" stranded copper wire, an inline ato fuse holder, a 25 amp ato fuse, a standard 4 or 5 pin relay 25 amp or larger or a typical fan kit that includes a relay that can handle at least 25 amps, a 12ga (yellow) eyelet terminal that will fit over your alt B+ stud (probably 5/16?), 12ga butt splices, four or six inch black zip ties, good crimping or soldering skills, and some electrical tape though heat shrink would be nice. It will act like a one speed, 1450 cfm fan.
  12. MV8
    Cooling issues
    I think you are talking to me. I'm Steve. Whatever you are connecting the red wire to has power when the key is off so not good. Can you take a picture of the front of the engine and back of the radiator area? Do you want the fan to come on automatically, with a toggle switch, or both independently since it is a two speed fan? Do you have a spot for an extra temp sensor on the engine or radiator?
  13. MV8
    Cooling issues
    The derale 16212 is a great fan. I have the same one on my geo tracker with a s10 v6 driveline swap. It looks like you have the red wire capped and are only running power on the grey wire. It is a two speed fan. In order to get high speed (1450 cfm), both positive leads must have power to pull the full 21 amps versus 15 amps and 1000 cfm. Obviously, it would be a lot more effective direct mounted behind the radiator. It would be tough to make efficient baffles/rubber ducting behind it with everything in the way plus it is partially blocked at the bottom. If you turned it 90 deg it would help. The good news is that fan is powerful enough to be used by itself with no engine driven fan if you can get it close or direct mount. How did you know my name was Andy? (I'm kidding! I'll stop "helping" now.)
  14. My pleasure. I enjoy problem solving.
  15. Yes, my conclusion. "Trust but verify" before plugging into anything.
  16. The white 3 wire connector is the 94 and older heater plug. Caterham has a subloom/adapter for use of the 95-up heater. The wwp looks to be a 90's vw part but without the check valve. Might be useful if you need to source a connector if there is no pigtail. This connector type should have a wire around the edge. The pig tail for the wwp should break out near the filter but is probably about two feet long. I've seen pics of different wwp reservoirs in various locations.
  17. I don't have a 05 schematic. The white plug middle terminal on the three hole side (green wire) should be the one to the washer pump positive. The orange is the positive feed to the washer control. The washer connector should have a black for ground and the green wire. It should split out of the main harness near the air filter.
  18. There are several different ways to do it. The easiest, most cost-effective thing you could do would be to fit the cable and weld on the brkt but I understand why you don't want to mod the chassis. Fitting a slave to the original fork is probably not an off-the-shelf package you could buy. It sounds like you probably would be better off with an all original type slave system. It's possible the original cable brkt was removed to convert to hydraulic.
  19. MV8
    Cooling issues
    If there is rust, it can insulate the jacket reducing thermal xfr, damage the pump seals causing a pump leak, clog the tiny holes in the head gasket, and block rad passages. If rusty under the water neck, I'd use evaporust thermocure and water for a week with no other changes, then thoroughly flush with water, replace the pump, install a 180 stat, back flush the old radiator, then refill with 50/50 standard green antifreeze (no "long life" coolant). If it still runs hot, replace the radiator.
  20. MV8
    Cooling issues
    The copper brass rad is serviceable, but radiator shops that can do the work are few and far between and the cores are more than a new aluminum radiator. All radiators collect sediment in the lower tubes that will eventually clog more and more of it. You can check during warm up by hand, feeling the core for uneven temps. Back flushing is about all that can be done on the newer radiators.
  21. MV8
    Cooling issues
    Did the car have muddy coolant when you got it? What model fan did you install? A few pics would be great.
  22. I think you've figured it out. The diode polarity on GW does not match the drawing provided by Caterham. Note the rings on the diodes in the drawing are toward the connector.
  23. Does it beep with the meter in this config?
  24. I don't know your experience level with a dvm but your response seems unclear. Select the ohm position, plug the leads into the appropriate sockets for check ohms, place the leads together to show continuity or beep to ensure it is working before trying to check anything. You can back probe the connector then use a thumb tack to penetrate the jacket over the splice to check each diode separately. I think the resistor is related to the operation of the speedo.
  25. I don't know the tach logic. I have no first hand knowledge; only a seven year old layout diagram (hesitant to call it a schematic) that does not show everything and what you provide. I went through the 2015 diagram and made a simplified flow diagram just for the TS (haz off). Your owners manual will show the location of each relay and fuse on the socket panel. I call it the HAZ relay but it may be called something else. It sounds like a reversed diode but I need to absorb all your updated information. I think the other lumps are not diodes but splices. I assume the diodes are so the brake filaments can work with the hazards but not back feed the turn signals, which would cause all the indicators to come on when the brake pedal is applied.
