Everything posted by MV8
Having the nut on before cutting is handy for clearing the burr at the cut, after you've squared up and radiused the end slightly with light application of the side of the grinder blade to take the corner off.
Looking at the Raceline site, I see they sell engine mounting brackets/arms and call them "engine mounts", so I assume you are talking about the metal arms that bolt to the block and not the rubber mounts that bolt to the chassis. Why not use the original arms? The new arms should not raise the engine a 1/2 inch in the chassis. They also sell duratec arms for changing engine placement longitudinally. They look very similar to zetec arms so maybe they sent you the wrong ones. I'd take a pic of each against a carpenter square and takes some measurements to email to raceline so they can determine if they sent you the wrong parts. I thought you were referring to the rubber mounts. There is a replacement rubber made by vibratec that uses a stud instead of a bolt and is about 1/8" taller than the standard rubber mount. I'd stick with the standard mount. Duratec: https://www.raceline.co.uk/products/part_section.asp?categoryID=1 &SectionID=27 Zetec: https://www.raceline.co.uk/products/part_section.asp?categoryID=2 &SectionID=46
Mr. Bart, I see you are in the Beltway. Just want you to know that we are from USA7's and we are here to help. Seriously though, your engine mount arms on the block look odd but it isn't a very good pic. They are appear to sweep forward. Maybe some sort of custom brackets to install a zetec?
What is my prize? Some sort of "Delta pilot" discount?
Any pics of the engine mounting brackets sitting on the too tall mounts? I'm not sure why you don't use a standard cap which is very low profile and costs $5.
For metric, it is measured one major to one major (i.e. the gap from tooth peak to adjacent tooth peak) so 2.5 sounds right. The svt cap should be the same. They have either a cam lock or threads. Bart, why not do a quick print of a thread profile gauge with 2.5, 2.75, and 3.0 in 25mm runs then check you new cap? Measure the new caps OD of the thread in inches, convert fractions to decimal and multiply by 25.4 for mm. I'm not sure how long your print will be stable in 225f oil and the allen socket will likely strip and require broaching to machine. I suggest aluminum with two round, 3/8x7/16 pockets as far apart as practical to use a universal pin wrench.
The machinist can measure the cap you have or you can if you have a dial caliper. I expect it to be around M32.5-4.0. Apparently not a common size.
Obviously, drilled holes in a stat is a bypass. No stat would only slightly improve flow since the main restriction is the size of the holes in the head gasket, but traditionally, stats have been a common failure part that wasn't necessary, like vacuum advance. I don't think there is an internal bypass like on the mgb. If they aren't bypassing at all, that sets up hot spots throughout until the stat starts opening. A little flow spreads the heat for more even expansion and less chance of cracking. With no bypass, conservative running until warm can minimize eventual problems.
Why would they if there is no stat installed for warm up? Do you think a cable controlled heater valve completely blocks coolant flow? Bypasses have been used for more than 50 years. Sometimes they are internal and not obvious. Happy to share examples.
With either capped, there needs to be another path for some bypass flow around the closed stat during warm up. Drilling the stat or looping the htr circuit with a hose but restrict the flow with a drilled plug or a washer at one end. Similar to Westfield7, I'd block the pump port, drill the stat, fit an NPT to male AN manifold for an AN6 to 1/2 inch pushloc hose elbow (with a floating nut so the pipe can be indexed before tightening), then add a cushion clamp to the engine at the rear, but no bleeder line on the water neck with the higher tank feed. I'd fit a larger tank to mostly fill. If that proved not to be adequate, completely fill it for more coolant mass with an overflow bottle for expansion.
For those cutting tires but happy otherwise, the travel indicating rubber ring on the shaft (if equipped) can show if/how much foam taper bumper can be used to prevent damage without a sudden spring rate increase from bottoming on a standard solid rubber bump stop. The gradual rate increase can start an inch of shaft travel before the cutting begins, so as not to upset the car. That may be all the change you want to make. Many oems (typically struts) come with foam bump stops. They are usually included with the gaiter/dust boot kit.
I like your hat! Standard calibration of cable driven speedometers is usually 1000rpm at 60mph/100kph and adjusted by the tooth count at the transmission end of the cable. I expect any similar specification vdo speedometer from that time would have the same worm drive trip indication gears but a different face numbering. I think all you need are the bronze gears. The gears you have could be cast in plaster or a flexible mold, a copy of the worn gear made from wax and then built up as a pattern for casting in red bronze or silicon bronze by a jewelry maker with a kiln and centrifugal casting spinner. The new gears could be tested off the car with a drill to turn the cable. Another option is to take the old gears to a machinist for a production run to cut from bronze rod. It is a lot more trouble and expense than installing a modern gps speedometer with no cable. If the throttle breaks again, consider using bicycle brake cable, teflon lined or sleeved that is cut to fit. Should be a 1.5mm cable with 5-6mm housing. Do you like hoshigaki? I've not made any yet. I usually just dehydrate. I grow many fruiting trees and vines including a few types of asian persimmons; Giombo, Tanenashi, Hachiya, Fuyu, Saijo, "coffee cake", and "Honan Red". All grafted to cold-hardy root stocks.
Beautiful scenery! The gears that engage the worms are worn. I expect that soon it will not work at all. Worm gear engagement is adjustable with the screw on the side, over the slotted worm bracket in your picture. I'd look for a replacement of the same model, new or used, then swap the gears or simply note the replacement in the log book. It may not be allowed in Japan for anyone to calibrate the indicated mileage on a replacement speedometer. The clutch cable reliability could be improved by allowing the cable eye to rotate freely without the hardware being loose on the pedal. One way is to replace the socket head screw by modifying the pedal. A stepped diameter steel pin can be pressed into the pedal and spot welded on the side opposite the cable eye. A washer would be on each side of the eye followed by the cotter pin. Another way is to use a larger cable eye to fit a shoulder bolt or sleeve over the original socket head bolt and add washers. Another way would be custom made stud/pin with threads for the pedal side, a thin flange, with a unthreaded pin/shank on the cable side with a cotter pin hole. Disregard clutch cable mods. No need to modify the pedal at all. The nuts should be jambed together against the pedal and not tightened against the cable eye. It would be better to have an unthreaded shank bolt and washers on each side of the eye.
The camber setting from the upper ball joint will impact the toe, so you might want to check the instructions on that as well. If you would like to check your work before driving to an alignment shop, get a digital protractor and mason layout string with two small jack stands. I use one like this for alignments and driveshaft angle checking: https://www.ebay.com/itm/284864070161?hash=item425338c211:g:-J8AAOSwmS1h4EW5 The string comes in bright colors so it is easier to see. When cutting, tie a knot on each side of where the cut will be then melt the ends with a lighter to prevent unraveling. I assume they provide alignment specs for toe-in and negative camber. If not, I would set them at 1deg neg camber on the front with 1/8 (0.125") toe-in and leave the rear as-is. Let me know if you'd like a step by step how-to on the initial alignment.
If you want to adjust it, you can rotate the silver link without removing the tierod end from the spindle boss by loosening the nut I mentioned before.
The yellow ring on the boot is not in a groove on the tierod pin. The boot will slide away from the boss so you can get a lip to pull against but there is no need to remove it. Don't worry about the alignment now. Part of that process will correct anything you've done.
Pull back the black sleeve on the silver link toward the rack to expose the jamb nut and flats on the tie rod body. A wrench is placed on each to loosen the nut to free the silver link to rotate freely on the inner tie rod joint that is inside the gaiter on the rack. For separating a tie rod taper from a steering arm, a tool is used to apply a reasonable amount of force. If it is still stuck, with the tool still applying force, the steering arm boss is struck with a hammer a couple times. One of the tools in this kit will fit but there is no need for adjusting toe: https://www.ebay.com/itm/403709361501?epid=19012854471&hash=item5dfef3fd5d:g:Zq4AAOSw5XViov2P&amdata=enc%3AAQAHAAAAwDlIOqPEKhY%2FOtnU4M%2BY4rlVi%2B070Cz4YtSja1pJOJ7LlQ9jXQVwZgpwW01UHGcXBXY7miNEiDX9XrCj5%2F1FkPRpYWewAAXkqo4JzlacnfM6ncv5CTJ5BbbTlvW%2Bt0j6tV%2BUR7b%2B8vcrn6wMvXuaowc6UaYPLO3bEjjvhwIkSE%2F6o60phA1izOL1FyGFBDvfaOu1AzVhjO1jrZ1Tv3%2Fnb4%2Fmx63rc6nV%2FV8NbR2mt72n6V46f7D9q7T7KsiTiDKv%2Bg%3D%3D%7Ctkp%3ABlBMULz7jJTGYA
No problem at all; just conversation. -
Nothing to be sad about. My point is a person listed as having won several auctions may not have bought anything. You seem to be suggesting that I think it would be ok not to follow through. Nothing could be further from the truth. I like the car, but I don't know how much running around can be done. It may be problem passing inspection for registration when a new screen is not available. An out of State sale usually requires inspection. When I lived on Whidbey Island, the police were sticklers about very minor things, imho. -
Hydraulic clutch set up for Crossflow w/ Rocket box Seven
MV8 replied to Vinman1's topic in General Tech
https://onemoreford.co.uk/product/clutch-fork-boot/ May fit: https://www.ebay.co.uk/itm/Genuine-Ford-Gearbox-Clutch-Boot-6180410-/272380082578 Road trip to Turkey? https://asfordparts.com/ford-sierra/153-ford-bellhousing-rubber-boot-clutch-arm.html A bag of crisps, and he's off! -
It's nice to have but not absolutely necessary. -
That's a bit high for a fixer upper with a cracked, unobtainium windshield, left out in the sunny WA weather for a while. My understanding is the winning of the auction only provides a direct introduction to the seller, and may not result in a sale, with no penalty for winning auctions but not buying. They get paid anyway. Looks like he had instant "buyer" remorse. -
I've used it before and it helps as a band aid, but I'd much rather use green 50/50 with water and make other changes to improve cooling if needed.
Greg, when you say #2 and #4, I assume you mean ecu pins 15 and 35 for a 1342 firing order. I'll assume your test was idling and same reference clip connections, cmos and pulse settings for all tests. All the coil triggers should flash green at the same rate with the same brightness. A higher resistance would be dimmer but same rate. A higher rate may be brighter or dimmer depending on the probe circuit design. Check the specs for your specific probe. I'm not sure I would conclude anything from the test results with the logic probe. Since you probably don't have the extender I was talking about before, you could also remove a good coil and plug, ground the plug body with a jumper cable, connect the coil to #2 connector and crank to observe. Connect to a different one to compare. If it still doesn't work, I'd try an ecu swap.
ACK! Long life coolant strikes again!
